Question about American Range Kitchen Appliances - Others
I have a american range af-45 and we set it at 350 when we turn it to off the lp stays on and doestnt turn off. the only way to turn it off is to turn the main valve in fryer to off or pilot
bigg t
  • 640 Answers
SOURCE: problems with fryer
your problem is the thermostat is bad.the reason it shuts down is that it trips the hi limit.the hi limit is a saftey device that shuts the system down so the oil doesnt get too hot and catch on fire.remove all the oil from the tank and you should see 2 skinny metal bulbs one is the hi limit bulb the other is the t-stat bulb,make sure they are secured to the bracket.if the t-stat bulb isnt you will also have this issue,simply reattach it.let me know.
Posted on Nov 11, 2007
r carbo
  • 21 Answers
SOURCE: Fryer pilot lit but main burner does not come on
IT IS A GAS PRESSURE PROBLEM CHECK TO SEE IF THERE IS A GAS REGULATOR IN LINE WITH THE GAS PIPE TO THE FRYER IF SO ADJUST REGULATOR TAKE TOP ALUMINUM SCREW OF YOU WILL SEE WHITE PLASTIC SCREW TURN WHITE SCREWW TO THE RIGHT ALL THE WAY IF SAME PROBLEM OR NO REGULATOR RESTICTION IN GAS LINE
Posted on Nov 19, 2008
r carbo
  • 21 Answers
SOURCE: My Cecilware GF-10 LP deep fryer the pilot will not light.
on that cecilware fryer there is a regulator to the right of the pilot light unsrew the aluminum cap and take off cap then you will see a white plastic screw turn that screw clockwise until it stops this will give the fryer more gas this could be your problem the regulator is silver and inline with the gas pipe comming from the back
Posted on Nov 21, 2008
  • 125 Answers
SOURCE: Imperial deep fryer IFS40 pilot lights, turn on
Hi there, it sounds like your thermopile, for the pilot, is failing during use, when this happens, the small DC voltage it generates is less than the gas valve requires to stay open, and shuts off the pilot, which shuts off the main burners. Another thing that could be happening, is the hi limit is opening prematurely, instead of shutting of the pilot at 450 deg. it now is opening at 325, or 225 or 250. Sometimes the sensing bulb gets broken where it pass's through the oil tank causing this symptom. If you temporarily bypassed the hi limit to test this also, and it still goes off, you need a thermopile. If it stays on, check your temp with a reliable thermometer, and see if it reads fairly close to your setting, if so, then you need a hi limit.
Hope that helps, and thank you.
Posted on Feb 21, 2009
cesar_quant
  • 61 Answers
SOURCE: pilot goes out when fryer reaches set temp. and shuts-off.
try to change the thermal battery the device that the pilot heats.. other wise there is a screw at the botton of the automatic valve.. try to increase the pilot so it can heat more the thermal battery! u dont have enough voltage to activate the solenoid valve so thats why ur pilot goes off
Posted on Mar 09, 2009
American range Af-25 pilot goes off when we turn thermostat on. what should we do?
call a repair service . GAS appliances are not in the DIY area . they want to go BOOM
Sep 18, 2017 | American Range Kitchen Appliances - Others
WISH TO KNOW BTU"S FOR MODEL AF-45 ????
Good Luck! there is not enough information to answer this question however FYI: A Brand New American Range Deep Fat Fryer Model AF-40 can be obtained with 90,000 BTU's Nat or LP gas
Apr 07, 2014 | American Range Kitchen Appliances - Others
I like to conver my american range v. Broiler. Giro infrared burner to lp gas
that simple, all you can do it go to place where you can buy a LP orfice and LP regulator and remove all NG orfice and regulator out and install all LP orfice and regulator you ready to go for LP..
Jun 15, 2011 | American Range Ovens
How can I convert from natural gas to LP?
change your gas get from natural to lp and use an lp regulator. you may have to adjust your air flow for proper flame
Sep 16, 2010 | American Range AF-25 Deep Fryer
Oven won't stay alight . has never worked from new . have checked all thermocouple connections all seem's well. probe is tight and in correct position.
To post a more specific solution you need to have the model number, but with the info you have given, I'm guessing that you have hooked the range up to LP gas and the range was not fully converted from natural to LP. If all burners burn nice, whomever converted the range may have missed one step. Many ranges with pilot lights have a small slot head screw behind the oven temp set knob which turns one way for natural, one way for LP.
Sep 16, 2008 | Kitchen Ranges
Kitchen Appliances - Others Logo
88 people viewed this question
Top American Range Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Mike
Are you an American Range Kitchen Appliances - Other Expert? Answer questions, earn points and help others
