Up-810 ram error sign come on - Office Equipment & Supplies
Paper jam sign on top of ADF,even when there is no paper jam
Jul 31, 2013 | Toshiba E - Studio 810 Multifunction...
Has pc100 128mb and tried to go to Pc133 and wouldn't accept, what is the max memory i can put on this board
the details of that board are sorta sketchy, it could be an intel 810 series or 815 series. theres really no way to tell except by opening it up and looking for the largest exposed ic chip with intel stamped on it, and look for an 810 or 815 designation on that chip.
if its an 810, it may not support pc133 ram, depending on the exact 810 model. if its an 810, it also will not support more than 256 total ram.
if its an 815, it will accept 512 total ram, if not more; however, you will have to go with no more than 4 ram sides- meaning, if you have 2 double-sided ram sticks, you will not be able to add anymore. if you have 2 single sided sticks, and a 3rd ram slot open, you may be able to add a double sided stick in the empty slot for 1+1+2=4 ram sides.
Sep 29, 2010 | Gateway PGA370 E139761 DIMM Motherboard...
512 MB SDRAM is shown as 256 MB RAM on intel 810 chipset.
just clean the ram slot and also clean the ram and try to put in diffrent slot.
Jan 12, 2010 | Computers & Internet
Whether INTEL 810 motherboard supports ddr2 ram of
The intel 810 motherboard will not support DDR2 memory.
Intel Pentium 3 Socket 370 SDRam PC100 Ultra DMA100 Motherboard With Onboard Video / Sound & LAN! For Intel Pentium 3 Processors (CPU.
This board will only support SDRAM PC100
Oct 01, 2009 | Intel Motherboard
Matshita DVD-Ram UJ-810 I/O Device Error with most DVDs Cds
i'd actually rather recommend trying another external dvd writer. The model/make doesn't matter. take it into a pc repair shop, let them connect an external dvd writer. if it works, and you buy it they won't charge extra, if it doesn't work, well, they can't charge you either
Jan 05, 2009 | Sony VAIO FRV37 Notebook
How can I convert 1 GB Ram into Mother Board 810 E?
YAS IS GOOD YOU CAN UPGRADE YOUR MEMMORY TI 1GB ALL YOU NEED TO DO IS GET THE EXACT TYPE OF WHAT YOUR MOTERBOARD IS USING eg IF YOUR MOTHERBOARD IS USING DD RAM GET 1GB DD RAM IF IT SD RAM YOUR BOARD USES THEN GET SD RAM. IT GONNA BE FINE WHEN YOU UPGRADE IT WILL PARFECT YOUR PC PERFORMANCE.
Nov 20, 2008 | Intel Motherboard
Question from docustor re:ASUS Intel 810 Chipset MEW-AM
the intel 810 chipset requires very specifically made 256meg sticks to support that much memory. the 256 meg standard has changed, and the 810 wont support the ram unless it is made by the old specs. smaller ram sticks such as 64 and 128 will not have this problem.
Jul 19, 2008 | ASUS Intel 810 Chipset MEW-AM Motherboard
Ram gets detected only to half of the value specified
dear pradhan
your ram 256 but i think your ram memory shared with disply memory so . first restart your system and press DEL key untill u enter in bios setup.then go tothe advanced option and disable graphic memory then save settings and restart pc . your problem is solved.
Mar 18, 2008 | Intel SuperMicro SUPER Motherboard - 810...
Motherboard is dead
remove the RAM. boot minimal only (floppy). get to BIOS screen. reset to factory default. try again with boot floppy. if ok, re-install RAM and repeat
May 31, 2007 | Intel SuperMicro SUPER Motherboard - 810...
23 people viewed this question
k24674
