Question about Sony PlayStation Portable (PSP) Console
Psp says battery is charged but the icon in the corner says itts empty
Yeagh the icon says its empty but the menu says its charged
  • ROD91 Oct 12, 2008
    When I turn my PSP on I get a setup screen. I can't play a game or anything.
  • 709 Answers
Try pressing the R button and power on at the same time. This resets the PSP and may get the data about the bettery resynched. If you still have a problem, you may want to go to www.playstation.com and setup a Repair with Sony. Otherwise Click on " Repair Directory" at the bottom of this Screen and pick "Video Game Consoles on the next Screen, Find a good Repair Shop.
Posted on Nov 20, 2007
PSP turns on but stuck at gray screen with loading icon
I would advise on reinstalling the firmware with a pandora battery setup. Else, you may be able to insert a copy of Hellcat's recovery flasher onto your MMS and have it install a new firmware for you through the recovery menu. It just depends on how broken your PSP's firmware is at this time. The Wololo.net forums are your friend on this one.
Mar 29, 2014 | Video Game Consoles & Games
Gateway NV5378u lap top, brand new battery installed and status says 100% charged. When I unplug the computer it shuts off as if there is no battery. Could the new battery be defective?
There are a few things to check. The LED lights can tell you a lot. This will tell you more about the battery:
  1. On the taskbar, double-click the power cord icon or battery icon to open the Power Meter dialog box. Note: If the power cord icon or battery icon does not appear on the taskbar, click the show hidden icons button.
  2. Press Fn+STATUS to view the power status box, which opens in the upper-left corner of the screen. The power status box shows the current power source, the battery charge level, and the power management mode.
  3. Look at the battery charge indicator (if applicable).
    • LED green - Battery is fully charged.
    • LED orange - Battery is charging.
    • LED blinking red - Battery charge is very low.
    • LED solid red - Battery is malfunctioning. Note: This LED only lights up when the notebook is connected to AC power.
  4. Press the battery meter button on the battery. The battery meter lights indicate the percentage of battery charge remaining.
  5. Wait for a Low Battery warning message to appear.
If your battery charge indicator displays what looks like an inaccurate charge, you may need to recalibrate the battery.
To recalibrate the battery as mentioned, try this:
  1. Connect the AC adapter and then turn on the notebook.
  2. As soon as it starts and you see a startup screen, press the F2 key.
  3. In the BIOS Setup utility, use the TAB key to select the Advanced menu.
  4. On the Advanced menu, select Battery Auto Learning, and then press the SPACEBAR to select Enabled.
  5. Use the RIGHT ARROW key to select the Exit menu. On the Exit menu select Exit Saving Changes, and then press ENTER.
  6. At the Setup Confirmation prompt, select Yes, and then press ENTER.
  7. The battery recalibration process begins and a screen opens showing you the progress.
  8. When the recalibration has finished, and the message "Press [Esc] key to exit" appears, press Esc. The battery charge indicator now displays an accurate battery charge.
Hope this helps!!
Oct 20, 2013 | Computers & Internet
PSP Orange light when charging but battery wont charge
Your Battery may have developed dead cells and is no longer capable of charging.
Replace battery with new one
Jun 28, 2013 | Sony PlayStation Portable (PSP) Console
How to know battery is full
You can either look at the battery icon in the corner, or you can go to the settings menu on the left side go to what i think is the system settings and it should have a battery options display that will tell you what percent the battery is and how much longer it will last.
May 28, 2011 | Sony PSP (Piano Black)
I have a psp and i dont know if the psp is broken or is it my charger or battery please help sony model psp-110 battery pack 3.6
Hello there,
When you charge the PSP, does the charging light indicator at he lower right corner lights up as red? If not, then the battery is not being charged at all. But if it does lights up but does not power up the PSP, then the first this to troubleshoot this problem is put in another battery pack. If it powers up, then your battery needs to be changed.
Please let me know how this goes. Thank you for using FixYa.
Dec 19, 2010 | Sony PlayStation Portable (PSP) Console
PSP 2001 not recognizing battery
yes,and try using the right battery for ur system
Feb 10, 2010 | Sony PlayStation Portable (PSP) Slim...
My psp charging indicator it works but i wait an
let it charge for about 8 hours and then try it again and if that dose not work try buying a new battery
Feb 04, 2010 | Sony PlayStation Portable (PSP) Slim...
Psp wont charge, no usb. battery empty after last game.
believe it or not, if the psp works you can play it with out a battery using thee charger. Try that and see if it works at all. If it does then you may need to replace your battery, or leav it and let it charge for about 5-6 hours.
If it's 4 months old and it does not work at all you should still be under your manufacturer's warranty.
here is a link: https://service1.us.playstation.com/rma.htm?_flowExecutionKey=_c85468FC2-00F1-73C8-F8E5-75CD6F7D29EA_kA93A8E0B-D0A2-DB00-D631-BB67FD1DF0A2
Jun 02, 2009 | Sony PlayStation Portable (PSP) Console
BATTERY IS CHARGED, BUT SYSTEM DOES NOT RECOGNIZE BATTERY
this is a common problem. the battery itself is bad and needs to be replaced
Mar 01, 2009 | Video Game Consoles & Games
PSP hanged when switch on. The usual screen appears but without the menu icons except for a small circle at the bottom right hand corner which keeps spiinning. Icons will only appear when I open the UMD...
conect your psp to you pc/lap top and find a default setting for your psps this are just like other peoples psp saved dater try that look on game sites and console cheats sites
May 09, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
