Question about Emerson Televison & Video
I have a Emerson tv & Im charging my cell phone using the USB port until the auto function off on the TV happens I can't shut the function off my menu because there is no sleep mode or nothing.
  • Anonymous Dec 07, 2016
    P.s the USB port also loses power so I need the tv on. It is a Emerson model # CLC320EM2F.
SOURCE: Can't use "plug&play" from TV menu
I can switch between shop mode & normal by holding down the menu key on the side of the screen, just press it till it changes.
Posted on Jan 25, 2008
SOURCE: Emerson 20 inch flat screen tv problem
i had the same problem with a 32 inch and i kept "clicking" the channel changer on the remote to force the tv to go to another channel (that had previously been selected during the initial auto scan) --- still trying to figure out why the tv locks onto the scanning for channel
Posted on Sep 09, 2008
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
  • 51 Answers
SOURCE: The tv turns off automatically & standby light blinks 4 times
4 blinks is bad backlight inverter. Download the service manual here:
http://rapidshare.com/files/208591107/KDL40S2000_L5_sm.pdf
Posted on Aug 22, 2009
  • 188 Answers
SOURCE: My Sharp Flat Screen Tv Model LC32SB24U has a USB
The USB entry is mostly used for a foto slide show.
Please read the owners manual before plugging in any kind of USB sticks or other cable's in a TV set.
It can damage the set when there is a ground connection between some devices.
Posted on Nov 12, 2009
I want to activate my USB tv Port on that model, and cant .
This should be in the settings menu on your TV. Just like a computer you need to format the drive for the TV.
Nov 14, 2015 | LG 32LD330 MULTISYSTEM LCD FOR 110-240...
19 Inch HD Ready Digital LCD TV/DVD Combi. Is it possible to use the USB port and if so, how?
Dear Megan,
This Port could be a Service Port or USB Input and /or USB Output. Make sure it is Not labeled "service only"
If you have a Jump Drive with pictures / music on it, plug it into the port and see what happens. This port could also be used as a charging port for cellphones,GPS etc...depending on the function it was designed for.
Good Luck!
JP
Jun 04, 2015 | Alba Televison & Video
How can I connect an alcatel to a tv using the microUSB?
Two ways:
1. If your TV has a USB port, connect the phone to that port using the Micro USB cable that came with the phone.
2. Get a Micro USB-to-HDMI cable and connect your phone to an HDMI port on your TV using that cable.
The question is: what are you trying to accomplish ?
Dec 22, 2014 | MetroPCS Alcatel ONETOUCH Evolve 4G...
How do I connect Emerson 19" model LC195EMX to direct TV
USE THE HDMI PORT WITH A HDMI CABLE FROM THE REAR OF THE DIRECT TV BOX TO HDMI PORT ON TV SET THE ON YOUR REMOTE PRESS MENU SCROLL TO THE APPROPRIATE HDMI NUMBER .OR USE VIDEO AUDIO CABLE FROM DIRECT TV BOX CONNECT TO AV CONNECTIONS ON TV SET AND DO THE SAME BY HITTING MENU SCROLL TO AV THAT SHOULD DO THE TRICK....GOOD LUCK
Oct 13, 2014 | Emerson Televison & Video
How, if possible, can the USB ports on the front AND back of the Motorola VIP1200/1216 TV Receiver boxes be used? And for what?
I think they were fitted for 'future enhancements'. I believe they have no function as yet.
Jan 13, 2010 | Televison & Video
My TV-1100 china phone does not charge. The funny thing is the phones of my friends with the same model which were purchased on the same date do not also charge and all these only happened today. The...
kindly check up with the stores in which the mobile was bought !!!!! & ensure that the charger ports in the mobile are functioning properly
Jul 20, 2009 | Cell Phones
Cannot connect to computer
FIRST OF ALL, NEVER EVER PLUG IT INTO THE COMPUTER WHILE ITS ON. ALWAYS TURN THE PHONE OFF BEFORE HAND. AS FAR AS YOUR COMPUTER NOT RECOGNIZING THE USB CABLE, IT MAY ACTUALLY BE YOUR COMPUTER. AFTER ALL IF IT WAS THE CABLE, YOUR PHONE WOULDN'T CHARGE SINCE IT IS THE SAME CABLE FOR CHARGING AND USB CONNECTIONS. MY COMPUTER HAS HAD TROUBLE SEVERAL TIMES WHEN PLUGGING IN NEW OR DIFFERENT DEVICES INTO THE PORT. TO CHECK THE USB PORT ON YOUR COMPUTER.... GO TO CONTROL PANEL, THEN DEVICE MANAGER. DOUBLE CLICK UNIVERSAL SERIAL BUS CONTROLLERS. IF ANY OF THEM ARENT WORKING PROPERLY THERE WILL BE A YELLOW TRIANGLE WITH AN EXCLAMTION POINT BESIDE THE UNFUNCTIONING USB. IF IT IS NOT FUNCTIONING YOU WILL HAVE TO UPDATE THE DRIVER. IF YOUR PORTS, DRIVERS ETC DONT SHOW THE YELLOW TRIANGLE, THEY ARE WORKING. TRY PLUGGING THE PHONE INTO A DIFFERENT PORT UNTIL YOU FIND ONE THAT WILL ACCEPT IT. I HAVE A LAPTOP AND MY PHONE ISNT RECOGNIZED IN THE SAME USB PORT (ON THE RIGHT SIDE OF THE COMPUTER) THAT I USE FOR MY PRINTER. I USE A DIFFERENT PORT FOR MY CELL PHONE. IF YOUR COMPUTER IS OLDER , THE USB PORT MAY NOT BE HIGH SPEED. OLDER COMPUTERS HAVE USB PORTS WITH A SPEED OF 1x OR A MIX OF PORTS WITH 1x AND 2.O (2.0 IS HIGHSPEED 1x IS NOT). I HOPE THIS HELPS!!!
Jun 23, 2009 | Dual Electronics CECT P168 Cellular Phone
Mar 26, 2008 | Televison & Video
My service port looks like an 8-pin mini din mouse port
If you are just trying to 'jump start' the tv to turn it on, get a usb cable, like the one you use to charge your cell phone. Touch the metal part of the service port, the 8-pin mini din witht he end of your charger cable that is plugged into the wall, until you see a flash on the screen, then turn the tv on like you normally would. It should turn on. If it doesn't jump it again.
Mar 16, 2008 | Olevia LT23HVX 23 in. LCD Television
Televison & Video Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
