Question about Freezers
My freezer alarm has gone off how do i reset it food seems to be drforsting and the freezer degree is still flashing
Tech007
  • 63 Answers
SOURCE: Kenmore model 2539280412 upright freezer alarm keeps going off
might have a defrost problem check to see if it is building up with on the back panel if it is you need a defrost timer or limiter or heater or fan
Posted on Aug 29, 2007
dididsaythat
  • 291 Answers
SOURCE: temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Posted on Sep 09, 2007
buddymcl777
  • 67 Answers
SOURCE: THE ALARM LIGHT HAS COME ON HOW DO I RESET
When it is fixed and the temperature goes back down it will automatically go off.
If it's stuck trying unplugging for 10 minutes and then plug back in to reset. If it has a battery backup take out battery.
Inside the door near top there is sometimes instructions to hold the button for 3 seconds to reset or unlock controls (on modern Frigidaires and some Kenmores).
Posted on May 04, 2009
  • 103 Answers
SOURCE: Freezer alarm stuck on - can't reset
Hi: Does the freezer have a battery backup for the electronics? A 9v. battery in the grill down below. You won't have to remove the grill but pull a small rectangular panel to expose the battery. High end Kenmore freezers have a battery to back up the alarm. The six you see is actually supposed to be a "b" for battery most likely. L.E.D.'s are tough to tell the difference. Buy an new battery and all will be well. I hope this helps, Jeff
Posted on Jun 12, 2009
  • 4793 Answers
SOURCE: Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Posted on Feb 11, 2010
Upright frigidaire freezer light flashing 6 degrees pressed super freeze will it reset??? How do I know if super freeze button working??
Check along the back and sides of the freezer for any vent-like openings that are covered or blocked by packages. There may be a sensor that's not getting air flow as it should. Although most upright freezers are now frost free, there still can be ice buildup in critical areas such as the thermal sensor or the fan. Can you tell if the fan is running?
Even if the compressor has failed, your frozen items will keep the temp down for several days. I suggest you move the frozen goods to a neighbor immediately. Meat or fish in particular quickly becomes unsafe to eat without at least refrigeration.
Sep 03, 2016 | Frigidaire Freezers
Inhave just reurned from a short holiday and found My Miele f1313s freezer has the alarm light flashing. Thoughts?
Make sure you have enough amps in the outlet its plugged into. The kitchen outlet might of had more amps than the garage outlet. Also, try unplugging it for a few seconds then plug it back it which might reset it.
Sep 20, 2014 | Miele 3.7 cu. ft. / 105 liter Upright...
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
The freezer wont go to it's normal temperature and alarm keeps beeping!
either its not defrosting or its low on freon, is there frost anywhere in the freezer, such as the back wall?
Feb 04, 2013 | Freezers
How tro restart my digital freezer?
Can you hear the compressor start? If not try the extreme freeze button. Check the condenser is clean and fan working ok.
Jul 24, 2012 | Frigidaire Freezers
Miele F7131 S The red alarm and the orange -32 degrees orange light on the front of my under counter freezer keep flashing. I have defrosted it. It appears cold but the lights will not stop flashing.
Freezer Temp. shoud be 0 to -5 Deg. if to warm it will set off the alarm. try unpluging or turn off power to freezer for 1 or 2 min. to see if it will reset.
May 17, 2010 | Freezers
Jun 12, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
The alarm light is flashing, the freezer seem to be working,
Most all cooling systems need to be in an ambient temp of about 60-65 degrees. If not, it needs a low ambient control. This helps keep the high side pressure high enough so you have the proper pressure drop accross the expansion device. This applies to coolers, freezers, a/c units, and so on. I also think, if it keeps things frozen like you want, where's the problem? You make have a control just acting stupid.
Feb 07, 2009 | Freezers
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Temp alarm going off
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
97 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
