Question about Lasko Heating & Cooling
How to get my lasko heater to go up to 70 - Lasko Heating & Cooling
Lasko manual5155
The manual for the Lasko 5155 is available here: . You will need to review the heater to download the manual. Other Lasko manuals are available from the Lasko site. The current tower heaters have the manuals on their individual product pages. You can access the list here: . Other manuals can be accessed here: .
I hope this helps.
Jan 07, 2014 | Heating & Cooling
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
I do not have a problem i need a manual or instructions on useing this heater for lasko ceramic element model #751320
Here is an email address for the Lasko Products Help Dept. They should be able to provide that for you. If you prefer to call them the number is 800-233-0268.
Hope this helped you.
Mar 09, 2011 | Lasko 751320 Ceramic Heater
I have a heater that keeps turning itself off even though I have the thermostat set at 70
probbaly a limit switch,not easy to open it up, short switch and run awhile if its ok then replace limit or risk fire.if it still quits then its thermostat.sometimes there is a tiny little screw behind the knob you can adjust
Dec 29, 2010 | Lasko Heating & Cooling
The fan makes an odd noise as if it were out of
Recalled: Discontinue use and see
or call Lasko Products toll free any time at 1-800-984-3311 to receive a free replacement heater.
May 09, 2010 | Lasko 5362 Heater
Clean the filter : Lasko Model #5812
First make sure heater is unplugged. Next, on the side of the heater locate two holes (see image) these are what's keeping everything in front together. unscrewing these and genty pulling sides out lwill release the top filter and front where control knob is and bottom filter where the heated air comes out. Clean filter & re assemble.
Nov 30, 2009 | Lasko 5812 Heater
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Heating & Cooling Logo
37 people viewed this question
Top Lasko Heating & Cooling Experts
Steve Oakes
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
