How long do I wait to my heater come back on after resetting
  • Heating & Co... Master
  • 3,239 Answers
Should be instant .
Posted on Dec 07, 2016
I have a Titan water heater model N-160. I turned the water off hoping to change the filter. Now There is no hot water and the screen reads : STAND BY FLOW=OFF how can I reset it?
Hey Shawn..did you turn the water back on BEFORE cutting the electricity back on? Cut the breaker off,,, wait 3-4 minutes before restarting.. MAKE sure the water is on ALL the way...
Troubleshooting the Titan tankless water heater
SCR3 160 Titan Tankless Water Heater
Jul 02, 2017 | Water Water Heaters
Is there a reset button for a 6G50NVH-FV-02 hot water heater
Depends on gas control valve, and if cause is overheating high-limit event or FVIR flammable vapor event.
Turn off water heater when using flammable vapors, clean burner parts to prevent overheating.
1) GSW Residential power vent gas water heater with FVIR system:
Some models have intelli-vent gas contol
Others have robershaw gas control with auto-reset
2) Parts manual shows #15 'auto-reset' high limit switch on the blower
http://www.gswpartsonline.com/model/27484
http://www.gswpartsonline.com/schematic/137/view
3) Possible manual:
http://www.gsw-wh.com/pdfs/GPD135NInstall.pdf
Shows resettable lockout page 15
Water temperature must be 120 degree F or lower for reset. Unplug power cord, and then plug back in and wait 15 minutes or 60 minutes depending on gas control valve.
Some intelli-vent controls must be replaced when 195 degree high limit event locks out the water heater.
If high-limit lockout repeats, then gas control must be replaced.
Also clean burner parts, air intake, and make sure flame is clear blue. and not yellow-or-orange.
4) Intelli-vent service manual might apply to your water heater:
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
If FVIR flammable vapor event locked out heater, then unplug heater and plug back in.
Immediately press two temperature buttons. Wait for green light to blink. Release buttons.
Page 34 in troubleshoot chart.
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 31, 2011 | Fasco GSW Hot Water Heater Exhaust Draft...
I have Rinnai natural gas room heater 516tr. It's continuously showing filter light on indication. I have clean heater but still filter light kept on. What I should do?
Turn the heater OFF and unplug it from the wall. Remove the filter and reinstall it, making sure it's fitted properly into the heater. Wait 5 minutes and plug the heater back ion and turn it ON. You may have to reset the controls back to way you had them. Completing what you just did, should have allowed the heater reset itself and function as it should. If this sort of thing continues to reoccur, contact your local Rinnai Dealer for service.
Hope this helped you to solve the problem.
May 01, 2011 | Heating & Cooling
I have a electralog fireplace model #cs 3311. It doesn't stay on very long. Even if i turn the thermostat up it doesn't turn on
It's probably the Temperature Cut Off Switch. It turns the heater off if it's overheating. To reset the switch turn the Main On/Off Switch to OFF . Wait 5 minutes and turn it back ON.
If you need to continuously reset the heater, unplug the unit and call Dimplex North
America Limited at 1-800-668-6663.
Hope this helped to solve your problem.
Mar 08, 2011 | Heating & Cooling
Why does my dimplex model bf8000st fan and heat turn off after 2 or 3 minutes? the flame lights keep working, just no fan or heat.
"Resetting the Temperature Cutoff Switch
This unit is equipped with a thermostat which controls the temperature
of the room by turning the heater on and off. The heater is protected
with a safety device to prevent overheating. Should the heater
overheat, an automatic cut out will turn the heater off and it will not
come back on without being reset. It can be reset by switching the
Main On/Off Switch to off and waiting five (5) minutes before switching
the unit back on."
http://dimplex.com/cms/publications/7208680300r03_EN.pdf
Dec 13, 2010 | Heating & Cooling
Mystery message "wait" appears above "following schedule" display line on our Th8000. Ac does not come on even when temperature is in range. Fan operates ok. Is "wait" setting one I can reset? Maybe a...
Mystery message "wait" appears above "following schedule" display line on our Th8000. Ac does not come on even when temperature is in range. Fan operates ok. Is "wait" setting one I can reset? Maybe a compressor issue rather than thermostat? Thanks
Jun 21, 2010 | Honeywell Electronic Programmable...
Heayrt won't fire e4 can't hear fan runnung
I am not sure if you have gotten this issue corrected, or not, but the first thing I would try to do is to reset the heater computer system. This sometimes corrects and EO4 error code.
What you will do is open the right hand side door and find the POWER toggle switch, turn that off. Then find the CIRCUIT BREAKER for the heater and turn that off as well, then wait about 15 to 20 minutes. After waiting, you will turn the CIRCUIT BREAKER on first, then the heater. Try and start the heater up.
If the EO4 code comes back, there may be an issue with the heater. If the code does not come back and the heater starts, then the error code was what I call a "computer hic-cup".
Jul 04, 2009 | Pentair MINIMAX NT TSI IGNITER
I painted the floor & my hot water heater (Reehm
The water heater is locked out. The following process should reset it.
1. Reapply power to the water heater and wait for 3 seconds for the system self-diagnostic check.
2. Within the first 30 seconds, the temperature dial must be rotated back and forth crossing the 120
degree mark at least six (6) times. This will reset the control and display a normal flash code
(slow blinking).
Mar 22, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
