Question about Belling Ovens
I have a belling format cooker double oven screw driver symbol flashing next to clock what can I do
dutchman05
  • 487 Answers
SOURCE: timer clock on bosch double oven
Please follow this link and download the instructions.
Manual
Please rate me as FIXYA
Posted on Apr 29, 2008
SOURCE: Belling Format cooker
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section. http://www.prestigeappliances.com.au/owner's-manual.shtml
Posted on Aug 01, 2008
SOURCE: clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Posted on May 01, 2009
  • 417 Answers
SOURCE: belling oven stopped working
It is most likely the element needs replacing although it could be the oven thermostat.
I would try a new element first, it is not a complicated job to change the element but you need to switch the power off at the wall before you start work.
If you are unsure or in doubt about carrying out the work seek professional help.
Posted on Dec 22, 2009
Testimonial: "thanks ashburton i will attempt to change the element first."
SOURCE: how do you reset the clock when you switch on a
belling single oven. how do you reset the clock
Posted on Mar 19, 2010
I have just baught a second hand belling double oven cooker, we have switched it on and the timer is constantly buzzing! And the top oven and grill don't work! Any ideas on wot could b wrong?
The timer has been set and the cooking time is finished. That is why it is buzzing and the oven is in a turned off state. You need to acknowledge the cooking time finished, and set the oven back to Manual operation from Automatic. In the old days you pressed one of the buttons by the clock that was used to set. I used to have a Belling Double Oven in the UK, but I can't remember about the timer.
Google
make model manual
Google
Dec 19, 2016 | Belling Ovens
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
Apr 13, 2014 | Belling XOU482 Electric Double Oven
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
Clock on cooker flashing
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Cant find the model number on a Belling Format cooker
Hi.
Try looking inside the oven, or at the bottom front
Nov 28, 2008 | Ovens
Oct 29, 2007 | Belling XOU482 Electric Double Oven
Ovens Logo
26 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
