Phone number returned item
I need to return an item and there was no info included in the box as to a return address.
Check the shipping label on outside of package,also if you paid with Credit Card check your statement..sometimes they include the phone number with the charge
Sep 08, 2017 | The Computers & Internet
How do I set up the answering system on the Vtech?
Try this:
press [menu]
scroll to "Answering Sys"
press [select]
scroll to "Ans Sys Setup"
press [select]
--- ( begin the setup item list )---
==1== as you scroll to each item to be set up,
press [select] to address that item
scroll through that item's choices,
then press [select] to confirm the choice selection
(chirps) and returns to the setup item list
==2==scroll to the next item
==3==scroll to the next item
==4== etc.
when finished, press [OFF] a few times to back up to "Handset #"
Feb 22, 2016 | Vtech CS6629-3 Silver Cordless Phone DECT,...
I have not received a credit for a returned item
Contact the party you returned the phone to. Did you have an RMA? Did you receive notification of receipt? Do you have tracking number for your return?
Dec 03, 2015 | Cell Phones
Ebay resolution center
You might want to let the BBB know about Michigan Motors also. I hope you did not lose much. My Son lost 200.00 the same way. Be careful.
May 13, 2017 | Computers & Internet
Honda HRR216VK
http://www.searspartsdirect.com/partsdirect/part-model/Honda-Parts/Walk-behind-lawn-mower-Parts/Model-HRR216/1795/1500600/P0510128/ 34aa7d01-b4cc-4610-b618-fe9cb9f2d509.png 1
on diagram CarburetorPART NUMBER: 16100-ZM0-803
Substitution: 16100-Z0L-023 Screw PART NUMBER: 93500-05006-0H
$2.19
In stock This item is not returnable. Qty: ScrewPART NUMBER: 16016-ZG0-W00 $10.97
In stock Qty: ScrewPART NUMBER: 16029-ZG0-901 $16.99
In stock Qty: NozzlePART NUMBER: 16166-ZM0-003 $20.24
In stock Qty: Main jet #60PART NUMBER: 99101-124-0600 $10.24
In stock Qty: ValvePART NUMBER: 16155-ZM0-003 $21.24
In stock Qty: FloatPART NUMBER: 16013-ZL1-003 $29.99
In stock Qty: GasketPART NUMBER: 16010-883-015 $9.74
In stock pd_0071_550_16010-883-015?hei=60&wid=60&op_sharpen=1&qlt=100 Qty: ChamberPART NUMBER: 16015-887-782 $33.66
In stock Qty: ScrewPART NUMBER: 16024-ZE1-811 $19.26
In stock Qty: ScrewPART NUMBER: 16028-ZE0-005
Substitution: 16028-ZK7-S91 Carburetor gasket PART NUMBER: 16228-ZL8-000
$3.99
In stock This item is not returnable. pd_0071_550_16228-zl8-000?hei=60&wid=60&op_sharpen=1&qlt=100 Qty: Gasket, carburetorPART NUMBER: 16221-883-800 $2.99
In stock This item is not returnable. pd_0071_550_16221-883-800?hei=60&wid=60&op_sharpen=1&qlt=100 Qty: GuidePART NUMBER: 19650-ZM0-000 $12.74
In stock pd_0071_550_19650-zm0-000?hei=60&wid=60&op_sharpen=1&qlt=100 Qty: Insulated carburet...PART NUMBER: 16211-ZL8-000 $3.99
In stock This item is not returnable. pd_0071_550_16211-zl8-000?hei=60&wid=60&op_sharpen=1&qlt=100 Qty: Gas insulatorPART NUMBER: 16212-ZL8-000 $4.48
In stock This item is not returnable. pd_0071_550_16212-zl8-000?hei=60&wid=60&op_sharpen=1&qlt=100 Qty: TransmissionPART NUMBER: 20001-VG3-B03 $279.74
In stock
May 21, 2014 | Garden
How to hide my number in samsung e2121b
Hide or Display Your Number on Samsung GT-E2121B
1.Go to your menu and select Settings (round gear wheel thingy).
2.In the settings environment, select item no 6 - Application
3.In the Application environment, select item no 1 - Call
4.In the Call environment, select item no 1 - All Calls
5.In the All Calls environment, select item no 1 - Show my number
6.This gives you the following three radio button options:
i.By network
ii.Send
iii.Hide
Select iii. Hide, then exit to return to your phone interface. All calls will not display your mobile phone number to the recipient.
To reverse this and display your number in subsequent calls, repeat the whole process and at step #6, then select i. By Network. Your mobile phone number will now display to call recipients for all calls.
Jan 02, 2012 | Samsung Cell Phones
How to check RMA number
A Return Merchandise Authorization (RMA) number is basically an access number sent by the manufacturer after the approval of an item for return. We cannot process your return or any return fees without a valid RMA number and thus they will be treated as a received recycled item.
you can get online RMA no form manufacture site example: http://www.hitachigst.com/warranty
Jun 16, 2011 | Computers & Internet
How do i return items bought ebay
Before you return, make sure you and seller agree and understand all the terms of the return. Even if you know the return policy by heart, confirm it with your seller. Make sure you know exactly what your refund or compensation will be. Most sellers do not refund shipping and handling charges, so don't ask for them, unless you believe the item has been grossly misrepresented. Even then, don't press the issue. Most sellers WILL refund your return cost if they've made a mistake. Even if the item IS misrepresented and you file a claim with PayPal, PayPal will require you to return it at YOUR expense before issuing a refund to you, so you have NOTHING TO LOSE by being polite and coorporative.
PACK YOUR RETURN SAFELY, even if your item is non-breakable. Any poorly packed item could be damaged in shipment. How would a seller know that it wasn't YOU who damaged the item and not the shipper? Even if the seller knows it was the shipper's fault, you have now given the seller the perfect opportunity to reneg on issuing a refund. You always have the option of going to eBay or PayPal for a refund, but your goal is to get your money back, and hopefully your return shipping too, so don't be hasty. In the box with the return include: your name, address and EMAIL, the eBay item number, date you purchased it, what method you used as payment, the amount you expect to be refunded to you, and how you have agreed the refund is to be issued. It makes it easier for the seller to trace and issue a refund, especialy if the seller transacts multiples of identical items.
CONTACT THE SELLER to let him/her know when the return was mailed, via what shipper, and about when it should arrive back. If there is a tracking number, provide that to your seller. If you've created a label through USPS and give USPS the seller's email, USPS will send the seller the tracking number automatically. Easier for everybody. DO NOT send back the item WITHOUT a tracking number. You don't want the seller to claim he didn't get the item back and thus refuse your refund. And if you go to PayPal for the refund, you're screwed. No tracking, means no washy.
FOLLOW-UP in the appropriate amount of time to see if the seller has received the return. If the item has been lost or delayed in shipment, it is YOUR responsibility to track it down. A short email will do: e.g. "Just checking to make sure you got those brown Ferragamo pumps, item number (xxxxxxxxxx) back. Let me know, thanks." Even if the tracking number shows the item has been returned, this is still a good idea. Some sellers get many returns a day and you don't want yours to get neglected.
Once you have received your refund, CONTACT THE SELLER to thank him/her and mention you would appreciate a positive feedback if one has not already been left. Even if you know you'll never trade with your seller again, say you look forward to doing more business. Keep stroking your seller until your glowing feedback is left. Once that's done you can go into eBay's community chat and spread the word about the seller's bad business practices, report to Safe Harbor, or anything else you feel appropriate. You goal is to GET YOUR MONEY and GLOWING FEEDBACK FIRST, before you do anything to get even.
Jan 04, 2011 | eBay Auctions
How do you set the speed dial phone numbers on the Clarity D613 amplified cordless DECT
Clarity D613 Cordless Telephone
SPEED DIAL INSTRUCTIONS
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays.
3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL.
5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4.
8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook.
10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options:
a. To leave the selected key without an association, press the BACK button and return to step 6.
b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6.
12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected.
13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE.
15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key.
17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice.
2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays.
2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL.
4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4.
6. Press the MENU button. The associated phonebook entry appears.
7. Press the BACK button.
8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
Dec 27, 2009 | Clarity Lands Phones
I need contact information for z cover, it is nowhere to be found on their website
To return an item
  • Fill up our Return request form. You can download it here.
  • E-mail the form to our customer care department to obtain a Return Merchandise Authorization (RMA) number.  This RMA number must be requested within 30 days of receiving the order.
e-mail: customercare@zcover.com
  • Upon receipt of the RMA number, you must follow the instruction return the item in the original box with all the packaging, accessories and a copy of the original invoice.  The RMA number must appear on the outside of the package or the package will be refused.
  • Return the package to the following address within 15 days after you receive RMA number via mail, UPS, Federal Express, or any other courier that allows for tracking of the package.
Customer Care
#100 - 13551 Verdun Place
Richmond BC V6V 1W5
CANADA
  • No collect shipment or any out of Canada shipment requiring a broker or customs fee will be accepted.
  • All returns are subject zCover Inc’s approval. We reserves the option to refund, credit or replace items that were damaged due to accident, misuse, abuse, product modification or neglect or damage resulting from the performance of repairs unauthorized by zCover. zCover Inc. reserves the right to refuse returns.
  • For returns, we will issue a credit for the cost of the item and the sales tax, if applicable. Please allow 5 to 10 business days for the process. Shipping charges are not refundable. For exchanges, we will ship out the replacement after receiving the exchange balance. shipping will be charged for the new item(s) sent.
The link to this information is: http://www.zcover.com/store/catalog/return.php
Apr 13, 2009 | Lands Phones
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
