Question about Cooking
The injector shaft will not push the tobacco into the tube, it seems to be jammed, how can I fix this?
    New Friend:
    Problem Solver:
  • 13 Answers
Make sure your tobacco doesn't have too much moisture in it to start with then try using less tobacco. Too much tobacco will cause the plunger to halt when it is only partially deployed.
Posted on Apr 16, 2017
2 Suggested Answers
denmason
  • 6 Answers
SOURCE: top o matic cigarette injector is only filling the cig half way
Hi Mindy,
Make sure that your tobacco is not too wet. Set some tobacco out (about the amount you plan to roll) and let it air dry for about 5 - 15 minutes. You'll have to figure out how long to let it dry as your home temperature is different than mine. Don't let it dry too much though. Give this a try. It works for me.
Take care,
Dennis Mason
Posted on Jul 24, 2009
Ordering cigarette tobacco , tubes , and injector system. How and where to order?
Fixya is unable to suggest sources for cigarette tobacco, tubes, and injector systems.
Apr 20, 2018 | Cooking
The machine got jammed and I heard it snap so I know it broke. this is the 2nd machine I have bought in 2yrs. I try not to put too much tobacco in there but it snapped. How can this be repaired?
you are loading way too tightly, do not force when pushing the handle down, if you have too you are over packing. I have loaded 200 cartons of cigs on these machines and never broken a thing
Oct 04, 2016 | Powermatic 2 Electric Cigarette Injector...
Why cant i get a decent cigarette out of my powermate II mach.
I am going to go under the assumption you are using 100mm tubes. I just switched to kings to make life easier but here is how I filled my 100mm to the filter with good compaction and a trick to get it to the filter. I tightly pack the tobacco against the left side, sticking my finger in the chamber and pushing pretty hard to compact to the left side, I then just do a light poke for the rest of the compartment. Here is the trick part, take a finger and put light pressure pushing on the filter towards the machine, but not so hard it bends the tube and also no so hard that when the injector probe comes out it pushes your finger away from the machine. Using this method I would get around 9 good packs with one redo out of 10 injections. The key is to have enough pressure to hold the filter at the point where the plastic tab usually pushes out and then let the probe push your finger away from the machine. Only very light pressure is needed to make the difference. If the cigarettes are not packing tight you are not compacting enough tobacco in the chamber. There is a fine line though, you need to find the balance as stuffing too much in will cause it to bind up, you just need to find the balance. Once you figure it out it will go very quick, I stuff mine while on the phone and can do around a pack every 2 to 3 minutes or so and get a cigarette that can not be distinguished from a store bought one.
Another tip: I use old cigarette packs as containers for my DIY smokes, you can do the same here with a plastic case. If I do get some that are not fully pushed against the filter using the above method, or if the pack just seems a little loos I put them aside and at the end I load them all in cigarette packs just like they come from the store, filter up (otherwise I have a habit of smoking filters from years of them being positioned this way!) and once the pack is full (add good ones if there is space for them to move around, it will not hurt them) turn the pack upside down so the lid is on the bottom. Now tap them firmly about 10 to 20 times against a hard flat surface. This will move the tobacco towards the filter if there is a space or pack loose cigarettes.
Warning: From my experience :) Do not over stuff the machine or using the compacting method do not over pack the tobacco, find a good medium. If you over pack the smokes will be solid and very hard to drag from. Do not smoke cigarettes that are hard to rag from, the extra force needed by your lungs followed by introducing smoke into your lungs will result in pain and maybe worse, but I only made that mistake once.
Jan 07, 2016 | Powermatic 2 Electric Cigarette Injector...
Need to know what moves the thing that holds the tubes on the machine
It is called the "cigarette holder" and has a replaceable "rubber bumper" on the end. Powermatic will send you a new one if you call when it does not hold the paper on as well as new.
http://powermaticinjector.com/c2instruct.asp
Jan 04, 2016 | Powermatic 2 Electric Cigarette Injector...
that is typically a moisture level issue or too much tobacco loaded. clean it out, use the tools provided or a thin rod to clear the tube, inspect and retry.
Oct 14, 2015 | Powermatic 2 Electric Cigarette Injector...
Tobacco only goes half way down thetube
inspect that the rubber piece that holds the tube.Chance's are that it is worn and needs to be replaced. it wont hold the tube all the way if it is worn. A quick fix is to cut a piece of eraser of a pencil and glue it to the holder.
Oct 10, 2014 | Powermatic 2 Electric Cigarette Injector...
Jam up
Use a small screwdriver and insert it in the tabbaco outlet to get the tabbaco out. be care full not to overstuff when filling.If you get a lot of jams the tabbaco can be to moist. if so let it dry out a little before inserting. Also the bottom of the bag 'shake' will jam the machine.A nice tabbaco that is very easy on any machine is a virginia blend.
Feb 17, 2014 | Powermatic 2 Electric Cigarette Injector...
The injector will not retract
One of 2 things. First is to push the reset button to get it to retract. Then make sure you are not over packing it with tobacco. If all that seems fine, maybe the gear mechanism inside has failed. I know from mine they were known to have plastic gears in the beginning, then were changed to hold up better.
Feb 09, 2014 | Powermatic 2 Electric Cigarette Injector...
Top o matic cigarette injector is only filling the cig half way
Hi Mindy,
Take care,
Dennis Mason
Jun 17, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Cooking Logo
1,748 people viewed this question
Top Cooking Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Cooking Expert? Answer questions, earn points and help others
