Question about Sansui Televison & Video
Sansui Model Sv2960Nicam Tuning no faster and no picture when putting the av no picture I changed all the three Hcf4052 ic and the tuner box help
    Top Expert:
  • Sansui Master
  • 74,482 Answers
Main system control IC fault. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result will display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on Dec 13, 2016
5 Suggested Answers
ltfrc
  • 227 Answers
SOURCE: is my sansui sdtv 3200A dtv ready?
SDTV The "D" means 'Defenition' not Digital, S is for 480i. You will need a convertor box. Sorry.....
Posted on Feb 16, 2009
Maliron
  • 12 Answers
SOURCE: tuner will not pick up cable box on channel 3, front and rear AV
In order for the TV to work with the cable box by using a piece of coax and tuning the TV to channel 3, you must make sure the TV is in "Cable" mode on the tuner and not "AIR or Antenna" the frequency maps are different between these types of service and channel 3 cable will not be the same as channel 3 on Air or UHF/VHF.
Often there is an auto program feature on TV's that will "scan" for all available channels, and this should select the proper input type.
Hope this helps!
Posted on Mar 29, 2009
darjr
  • 378 Answers
SOURCE: IN TV i have not get a picture on av mode mean av
look to the IC near the AV jack there is a AV switch IC. try to replace it. but some tv use a large IC jungle which is the AV sw. is also inside that large IC.So study carefully if your tv has a separate AV sw. IC..
Posted on Jun 04, 2009
SOURCE: I DO THE SERVICE WORK FOR THE SANSUI TV MODEL
cheak the voltage 180v supply root 10mf/250v and tda 6107jf and cheak the R.G.B voltages fualt in video output stage
Posted on Jun 12, 2009
How to unlock ASM in SANSUI SV-2010K
Hello
Universal remote codes for Sansui TV with RCA RCR311B remote control are:
1020, 1054, 1133, 1145, 1167, 1230
But I really don't understand to what do you mean by this ASM lock. ASM [Automatic Search Memory] is meant for tuning fuction. When we put the set to ASM mode, it should search all the available programmes at that time at appropriate chanels, and will stop; must stop; at the end of the tuning is over, and must show the first received programme. Then we can change the programmes as our own select. If ASM function does not works with your TV as specified above, surely its memory IC is in trouble; damaged; and should replace it with same type and number. This IC is an eight terminal one, can be located very near to main system control IC of your set. OK.
Aug 08, 2011 | RCA RCR311B Remote Control
We bought a used AV-32D305. It didn't come with the remote. We hooked it up to cable our cable box and it worked fine for three days. Today we turned it on and there's was just a blue screen with the...
hi
well to bad it looks like you have a bad tuner
I would suggest to use your cable box if you have a remote or it and connect your cable box in video mode or use a vcr in the same maner
Sep 30, 2010 | JVC AV-32D305 32" TV
TV not tuning
This guy is raking in the change on you. The tuner is for over the air signals, now you have a 3 prong connector RED,WHT,BLACK make there connected you can find the AUX,VID-IN by scrolling throught the channels on your TV hope this helps.
Apr 22, 2009 | Televison & Video
Tuner will not pick up cable box on channel 3, front and rear AV
Hope this helps!
Mar 29, 2009 | Philips Magnavox MS3652S 36" TV
Sansui DFTV275A
A DFTV275A has a built in digital tuner and does not need a converter box.
Sep 18, 2008 | Sansui D 27" TV275 TV
Help
i have sansui sv-2102.now i change ic tea5101a and i put tea5101b.now i have probelem with green picture. tea5101a not avilable.now what can i do ?
Feb 10, 2008 | Sansui COM311AD 13 in. Combo
Sansui
I need a card with SMD ICs located on the circuit board of my sansui RZ6800 AV Reciever.(its a digital card with function IC and many more SMD components)
Sep 01, 2007 | Audio Players & Recorders
Tv seems ok by static and now, no sound (or very faint)
The problem you're describing sounds like a tuner problem. BUT you say that you have the same problem with A-V input too. That's weird!!! Possibly the electronic TV-AV switching circuit is messed up and stuck in the TV (tuner) position. If this is the case you DO have a tuner problem and a switching problem too.
Jan 14, 2007 | Hitachi C29-F200 29" TV
RPTV PROBLEM
If you already tryed to change the AFC mode for the tuning ,thats the cable mode the TV's in, then your Microprocessor, tuning ic,or the tuner is defective.
Aug 19, 2006 | Hitachi 43FDX01B TV
B/w picture on all av inputs internal tuner from av box colour picture from internal tuner via scarts to video recorder tv on screen menus in colour teletext via internal tuner av box.
sounds like this set is in the UK??? or somewhere out of the states. If it working good on the tuner or telex box , the equipment your plugging into the AV inputs are not compadible to the tv set or there is a setting in the TV menu to change the format to pal
Aug 13, 2006 | LG MZ-42PZ14 42 in. Plasma Television
Televison & Video Logo
81 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
