Sharp AFR120FX Air Conditioner
Problem for Sharp AFR120FX Air Conditioner
How do i reset the e1
By jtecce1 on Jul 20, 2009
how do I reset the e1 on the A/C
Best Solution
posted on Jul 20, 2009
Very Helpful)
okcfirewall
Rank: Guru
Rating: 87%, 196 votes
I have a sharp and I don't know what model you have but you may check the manufacturers web site for a instruction book
but on my unit you have to do the following
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
after following this procedure to clear the nefarious E1 indication, you should obtain
another 720 hours of cooling bliss
Was this helpful?
Yes
No
4 people thought this was helpful
Popular Solutions for Sharp AFR120FX Air Conditioner
Questions and Unsolved Problems for Sharp AFR120FX Air Conditioner
Do you recommend Sharp AFR120FX Air Conditioner?
Answer
Answer
just bought a doublewide trailer. No air is going to 1/2 of the trailer-everything underneath the... (More)
Answer
unit led flashing 6 + 1 = soft lock-out, max of 4 trials for ingition lock led(3 hr delay) what... (More)
Answer
I have 1980 rrgf rooftop unit rrgf -series, the heater takes long time to quick in some times it... (More)
Answer
The ignitor lights up, but the pilot light doesn't light. I know it isn't a gas problem within the... (More)
Answer
i have a pioneer air con ducted model no:ps11. i neen the cap sizes as the old ones dont have a... (More)
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , IL
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
