Question about Tablets & eReaders
My account got stopped by tablet reset every thing got erased
    Novelist:
  • Tablets & eR... Expert
  • 231 Answers
It would help to know what kind of tablet.
Posted on Dec 07, 2016
Dream tab is frozen, and wont shut Down what do I do?
There should be a small reset tab you can press using a toothpick.....or chose the safe way and let the tablet run out of battery......the rest setting will erase all your account info.
Mar 31, 2016 | Tablets & eReaders
Forgot my password, how do I fix it.
you remember your password or stop buying things that need passwords
Jul 06, 2015 | NOOK HD 7 Tablet
Want to erase password and start over
n order to reset to factory settings, please follow these instructions :
- Power off machine.
- Hold down + first and then POWER for about 10 seconds, release both buttons once Kurio screen loads .
- When you get the open Android picture, press + to enter menu, use - to move down to "wipe data / factory reset" and press POWER again to choose.
- Next press - to choose "YES" and press POWER to start reset.
- Check for yellow text Formatting /data, formatting cache, Data wipe complete.
- Choose reboot system now and press POWER to complete process.
NOTE: This will erase data from your Kurio's internal storage such as Accounts, System settings and Downloaded apps. But music, pictures, and other user data won't be erased. Check "Erase SD card" if you want to clear all the data of the system.
It is also possible to reset only the Kurio Interface: Go to Parental area > Tablet Setup> Press "Reset the Interface to Factory Default Settings".
Once this has been done you will need to set the device up and perform all the updates, instructions for this are on this page.
Mar 04, 2015 | Kurio 7S Tablet
Forgot my password for my sony s tablet
Hello Let me clarify you question. When you say forgot password do you mean that you put a protective password to sign into your tablet and that is the one you forgot? If so there is no way to get back in without it unless you do a factory data reset on your device.. This will erase everything including your personal data unless you have backed it up somewhere and any apps that you have personally placed on the device as well but you can get those back as long as you use the same google account.
Before doing anything if you have a sd card in side you want to take that out or everything that you have on that card will be erased as well.
1.Press and hold the volume up button and then the power button until you see a black screen with blue lettering
2. To get to factory reset use your volume up and down button
3 Use the power button to select it.
4.Then you are going to want to do the same thing again to get to reset tablet
5.Using the volume up or down to get to Reset Tablet and then use the power button to select it.
6.You will be prompted asking you if your sure you want to reset the tablet just click on Erase Everything. Your tablet will begin the resetting process
7. When your tablet comes back up it will be up at the activation screen ie the setup process.
Hope this helps.
Feb 20, 2014 | Sony Tablet S
How to do firmware reset on a bauhn tablet - model AT - HK8
OK THIS WORKS 100%
1.Use a pin in the rear reset hole whilst holding the power button for A-HK8 Aldi Tablets, hold until the screen flashes white once, Then turn on Power as normal....it will appear to be stuck on the ANDROID logo but it isn't....
2.wait with the android logo showing on the screen for 3 minutes, don't touch anything, just let it be for 3 minutes....
3.the upgrade or optimize app menu screen will come on, let it finish the upgrade usually 1 or 21 ..(let it do it if this comes up don't touch anything) ...if no upgrade is required, it will go straight into the screen ready mode with the clock.....
4.navigate into settings, and select backup and reset......(at this point if you have a SD card i would backup your apps and google account to it) otherwise hit erase everything.....and factory reset the
tabletTechnicians notes:
I must also say that the dual core in these HK8's get very overloaded and overheat when playing it, as there is no gills or vents on the back cover, this is a manufacture fault by Bauhn, and they have since stopped making these,
it's a shame as it will only last a short while maybe 3 months or more until you need to do a hard reset all over again, as the tablet overheats mid use and causes a corrupt shutdown and when turned on again will need another dammed hard reset.....they constantly need hard resets... if you haven't the heart to throw it in the garbage and say goodbye to your $200 then ...this is what you will have to prepare for if you continue to own it..
one good thing though, is anything you backed up like apps, google play accounts, and photos can easily be used on a new tablet say like a "samsung" if you keep getting the crash error saying " Apparently such and such stopped working" means the Core duo chip is overheating at this stage, feel the back cover its unaturally hot and your battery juice is being sucked dry. means pretty much your core duo is fried and anything you touch will stopp working, it can't run when that hot....like i said earlier this is a common fault with the AT-HK8 Tablets from ALDi...and why Bauhn quickly stopped manufacturing them and offering support any longer....believe me after hard resetting it a few times every few months, you will want to take a hammer to it or frisbee it against a wall. up to you.
Feb 15, 2014 | Tablets & eReaders
How do i reset my asus tablet
Step 1. In the device,select settings on the application list >select back up and reset >factory data reset >reset tablet >erase everything. step 2 . The system will erase all user data and reboot automatically. Please note all data will be erased from tablet!!! 12_22_2013_7_37_26_am.png
Dec 17, 2013 | Tablets & eReaders
Pattern attempts
If you have it linked to an email account, then if you enter your password 5 times you should get a forgot password button. Click it and follow the prompts to reset the password. You can also reboot the tablet and hold either power + vol up or power + vol down to get a menu with the option to factory reset the tablet. This will erase all data too.
Jun 23, 2013 | Dell Streak 7 WiFi Tablet
Tablets & eReaders Logo
35 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
