How do I go about getting a power supply for my 42 inch LCD TV P/N 2**********1.
    Top Expert:
  • Televison & ... Master
  • 50,218 Answers
One might try a local TV repair shop .
Posted on Dec 07, 2016
  • 8457 Answers
SOURCE: We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Posted on Jan 15, 2010
Testimonial: "Have tried turning on/off a few times but still doesn't work. thanks anyway"
  • 16 Answers
SOURCE: Tv wont turn on
Replaced two N-Channel Mosfet transistors(FQPF13N50CF-ND) and some faulty electrolytic caps in the power supply. I found the Mosfets online at Digi-Key. Mosfets are difficult to read. Only one read bad but I replaced both because they are in the same circuit. Set works great now.
Posted on Mar 30, 2010
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
  • 17 Answers
SOURCE: Phillips 42 inch LCD 42PF9730A Redlight flashing
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Posted on May 13, 2010
mpaint
  • 36 Answers
SOURCE: 42 inch rca lcd tv says unusable signal
This is a very common problem with these models.
The problem is very likely a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
Posted on Jul 23, 2010
It shuts off 2 seconds after i power on.
Several possibilities but most common seems to be power supply defect or poor connection. Check these resources. Note that other Youtubes that may address the problem are also accessible from the youtube link.
LG Smart TV Keeps Turning Off then On Again
Lg Du 42px12x shuts down fix
42 in LG LCD TV turns off by itself
May 06, 2016 | LG 42LG50 42-Inch 1080p LCD HDTV
Philips 42PFL3704D/F7. Why does it keep restarting?
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Oct 9, 2012 - 5 posts - ‎2 authors
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable attached ... or Cable TV to unit the power resets, philips screen comes on and keeps on resetting. ... I tried a cable to the tv without the box and I do get picture.
Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV
www.amazon.com/Philips-42PFL3704D-F7.../B001LP...
Amazon.com, Inc.
Rating: 3.3 - ‎50 reviews
Amazon.com: Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV: Electronics. ... Will do all I can to prevent others from getting ripped off by Philips. ... came up every few weeks and would take an hour or so of reset before working properly.
Visit the support page for your Philips LCD TV 42PFL3704D ...
www.philips.ca > philips > Televisions > 3000 series
PhilipsFind support for your LCD TV 42PFL3704D/F7. ... How do I output sound from myPhilips TV to external audio devices such as Home Theaters, Soundbars, AV ...
42" Philips 42PFL3704D/F7 LCD TV WON'T COME ON - A
Dec 29, 2015 | Televison & Video
I need a power supply board for my 42 inch rca lcd,where do i buy??
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 27, 2011 | RCA L42FHD38 42 in. HDTV LCD TV
What will i do to my damaged 42 inch LCD LG TV it
Check ur power sources?Yes,than tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 14, 2010 | LG 42LC2D 42 in. LCD HDTV
TV makes chirping noise.
Power Lite LED indicator on the front panel bazel flashes?Ur power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Olevia 42 inch Flat Panel has power supply issue... Blue light does not come on and tv does not turn on... I have tried all different things to get tv to work with no positive results
What did you try so far? The main power supply MUST have at least the 5V standby supply section working. This 5v is used by the main control board to send out the command to turn on the main power supply section which will power up the rest of the TV circuits when the power switch is activated either by the power button of remote or on the TV powern button. Look for this 5v first.
Nov 04, 2009 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
No power to tv after unplugging and replugging
either the fuse is burnt out inside or the the problem is the power supply board. You can remove the back cover to see if the fuse is good or not.
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Vizio 42 inch tv Power Not working
It sound like the power supply problem. Replace the power supply will fix it. The power supply is located near the main board.
Dec 15, 2008 | Vizio GV42L 42 in. LCD Television
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
