Question about Mtd Garden
Mower deck adjustment ride on mower MTD 13538 cutting deck a lot lower than rear of the deck shaving the grass to dirt.
  • Mtd Master
  • 1,972 Answers
Are all the rods that hold the deck on all the same length. Has any been replaced with the wrong ones. Did this machine hit something that things were bent an out of shape.
Are your tires blown up where they should be? Soft tires will do that.
Posted on Jan 07, 2017
miket756
  • 2702 Answers
SOURCE: I have a MTD Pro riding lawn mower that I
the only way to fix it is fit the right blades
they have fitted the wrong blade's to it,,,
the blades should overlap when cutting the grass they cannot crash into each other as there are (timed up) not to do that the new blades they fitted are to short so you have no over lap on the gutters that leaves a strip of grass left uncut between the blades,,
call them out to put this stupid mistake right,,,
Posted on Oct 25, 2009
Testimonial: "Thanks. That explains everything. Kudos for your assistance"
  • 3911 Answers
SOURCE: When I lower the blade deck on my Troy Bilt mower
If it is a 2 cylinder with a set of bent valve push rods on one side it may well start and sound good, but it will not be able to do the work as only one cylinder is functional. I had a similar problem on a B&S V2. Pull the plug wires off one at a time. If it makes no difference with one plug wire off and is totally dead with the other plug wire off, then you have a dead cylinder.
Posted on Jun 28, 2010
  • 640 Answers
SOURCE: how do i adjust the
On the right side of your mower you should find a lever that allows you to adjust the cutting height of the deck up and down.
I hope this helps, if that is not sufficient just reply for some clarification and I will answer you question further.
Posted on Jul 15, 2011
ftw1952
  • 10319 Answers
SOURCE: I have a 15.5 hp
your blades are bent so replace them
Posted on Aug 12, 2011
  • 40 Answers
SOURCE: Wierd grass catcher problem
There are a couple of causes for this. Is the blade height the same on the new mower? Higher blade height could cause a lot of the grass to be blown out from under the deck, and not into the catcher chute.
On the trailing edge of the mower blades is a small 'wing' for lack of a better term. There are two types of blades, mulching blades that have a lower 'wing', while catcher blades that have a slightly higher 'wing' but it makes a difference.
If the season has been hot lately, the grass may not be growing as fast, hence less clippings, and less dense grass could also cause this.
Posted on Jun 16, 2012
Mower deck adjustment mtd 13538
Dec 06, 2016 | Mtd Garden
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
Jun 16, 2012 | Mtd Garden
I want to set the wheels for the deepest cut. In what direction should the wheels be adjusted-up or down?
If you move the wheels up, thereby lowering the cutting deck, it will cut the grass shorter on each pass.
If you move the wheels down, thereby raising the cutting deck, it will leave the grass longer on each pass.
May 04, 2011 | Garden
Mtd riding mower: right mower blade cutting uneven, but don't see problem
The blade can be bent or the deck is not level. Adjust the deck and level it from side to side. Now level it from front to rear with the front of the deck 1/4" lower than the back. If after leveling it, you find it still cuts uneven remove all blades and inspect them. You will more than likely find one is bent. Replace a bent blade.
Sep 18, 2009 | Garden
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
42" mtd yardmachine belt keeps coming off
twords the rear of the deck there are two bars with pins that hold the deck.they should have 3 or 4 holes where you can adjust the rear of the deck.check to see if there set to the middle somewhere,if so you can disconnect the 2 pins and try going up 1 hole iif that didn't work try down 1 from original point.
Jun 03, 2009 | Mtd Garden
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
To adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Apr 12, 2009 | Garden
Garden Logo
96 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
