Question about Kenmore Washing Machines
I have a Kenmore HE washer I load my clothes and push start, the sensing light comes on and just blinks? What could the issue be ?
SOURCE: Kenmore front load washer won't start. Lights just blink
I had same problem........push options and select button at same time, hold for 5 sec.......choose option.....machine stuck inbetween cycles.
at least it worked for me!
Posted on Aug 13, 2008
  • 277 Answers
SOURCE: Kenmore front load washer will not spin. Clothes come out wet.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Mar 02, 2009
SOURCE: kenmore super capacity 3.5 front loading washer
it may be locked. hold the "options" and "select" buttons down together for 3 seconds.
Posted on May 23, 2009
SOURCE: The Kenmore HE2 Washer Model
This IS the code for drain problem, pull front panel and remove round filter by turning to the left, probably full of change, feel the pump to the right of the filter if it is HOT, replace it...
Posted on Aug 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore washer won't spin out water, lights blinking
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Why does my GE washer turn off during a cycle?
I purchased a 4.8 cu. ft. High-Efficiency Top Load Washer with Steam in Metallic Carbon, ENERGY STAR.
I had issues when I used the machine for the first time. I started by loading some clothes and then the detergent, bleach and softener into the respective dispensers. I used the smart dispenser for the detergent, there are 2 detergent dispensers. Then I waited and ended up with water and a machine that would not spin .I kept getting the error message " Sensing " and it made light clicking sounds but was told that this was normal. I then waited 40 minutes and still no improvement. clothes stayed in the same spot.. nothing was happening but the Sensing Scroll Message.. I had to push the power button to stop it. I then pushed start but I still kept getting the error message scroll " Sensing "
I started over by setting it to drain & spin. It worked and my clothes got spun finally. Since I kept getting the sensor message and that is all it would say is " Sensing" .... I decided to try something else.
I powered it off and started a new load.
Next Load Trial:
I added soap to the detergent dispenser " Not the detergent smart dispense. Then i pushed the control lock button and last I hit the start button and whoala It works now.
Try getting familiar with your washer. do some light loads until you figure it out. It will eventually get where you need it to ,just be patient. Now I wash loads easy as pie.. I hope this helped you out with your problem. ;) . I am still learning mine and will post future issues and fixes if I come across any. Thank You.
Christine G. Hobbs, NM
Aug 26, 2014 | GE Washing Machines
Kenmore front load washer wont start
open the back on the right side on the bottom panel,you well see lots of wires,NOW START tagging wires uses two people for this.it may be easy to change switch out
Jul 04, 2010 | Kenmore HE2 Plus Front Load Washer
Code error problem
THIS IS TEMPORARY FIX, NOT A TOTAL SOLUTION. jUST TO GET WATER TO DRAIN AND RESET WASHER. , WITH WASHER POWERED OFF, PUSH AND HOLD START BUTTON FOR 4 SECONDS, RELEASE FOR 4, PUSH FOR 4 RELEASE FOR 4 UNTIL THE FRONT ALL LIGHTS UP AND DISPLAYS 88. sOON YOU WILL SEE YOUR CODES FLASHING, PRESS START BUTTON AS MANY TIMES NEEDED TIL NO MORE CODES FLASHING. tHEN WASHER WILL GO INTO DIAGNOSTIC TEST. aFTER THAT I DO NOT KNOW, BUT YOU CAN WASH 1 LOAD OF CLOTHES AND THEN PERFORM DIAGNOSTIC TEST AGAIN. THAT IS WHAT I AM DOING JUST TO HAVE A WORKING WASHER TOO MUCH TO FIX FROM WHAT I AM READING, SO GOING TO BU A NEW ONE ANYTHING BUT KENMORE. gOOD LUCK, HOPE THIS HELPS FOR IMMEDIATE RESCUE.
Jul 24, 2009 | Kenmore HE2 Plus Front Load Washer
Blinking red lights and no washer operation
Dave, glad I could help, I'll mark this one as solved.
Jun 12, 2008 | Kenmore 4292x Front Load Washer
Kenmore HE3t lights up ,won't start
sounds like a door lock/latch issue, its not recognizing your closing door so its not starting unit
Feb 28, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Lid Lock light stays on
You are eligible for a refund. TAKE IT ! ! This should be a learning experience.Since when did the consumer have to be come the repairman WHEN ITS UNDER WARRANTY ,C,MON NOW!!!
Aug 25, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
