Question about Kenmore 80809 Microwave Oven
Light no longer works
I heard a loud pop while using the microwave then the light went out. I replaced the bulbs but still no lights. any ideas
  • Kenmore Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 20, 2009
Went to replace the bulb under the microwave and there was a loud 'pop'. Then the microwave was dead. Did not trip the breaker, and checked the fuse inside the microwave, and it is still fine, and so is...
< -- I see and repair this on a regular basis. Details are here .
This failure occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line, as the warning label near the light socket advises.
Feel free to contact me for more information.
Feb 16, 2014 | Goldstar MV-1501 Microwave Oven
JVM1340WW 003 heard pop now bottom lights do not work.
MAKE this test and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Nov 01, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
I went to turn light on and heard a loud pop and saw spark. No lights on unit work. Defrost option does not work. Turntable does not work.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Light under microwave does not work. turned on heard loud pop?
Hello :
It must be an overheated lamp . You need to replace it . I think you still can use your Microwave safely if it works . If it doesn't work , then contact again please !
good luck .
please rate .
Mar 28, 2010 | Kenmore 80402 Microwave Oven
Yesterday, I went to use the microwave and as I pushed start, I heard a loud pop and saw sparks behind the vent cover. The microwave light and turn table work fine, but it does not heat. Is it repairable?
sounds like your magnetron went out . check how old it is, sometimes the manufacture gives a 5-10 yr warrenty on part if no warranty on unit then it may not be worth fixing depending on how much u spent on it. part roughly 89.99-139.99 labor 85-165.00 depending on who u use and were u live. hope this helps . thanx..
Oct 07, 2009 | Whirlpool Microwave Ovens
Heard a "POP" and both lights went out. Replaced bulbs and still, No Lights".
You most likely have a blown fuse. The fuse is located inside the case at the top and likely to the left.
Sep 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
GE SpaceMaker JVM XL1800
Sounds like the ERC board failed. It maybe covered under warranty, check that first cause a new ERC could cost around $150-$200. Anything electric can cause the .."what the*^&% just happened syndrome.
Dec 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 80809 Microwave Oven Logo
110 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
