Question about Wurlitzer Audio Players & Recorders
My Wurlitzer caravelle has just started not picking up the records. it is either the grip not strong enough or the timimg is slightly delayed. how can I rectify this?
5 Suggested Answers
  • 81 Answers
SOURCE: 6 AAs in canon xti grip ...is it ok or is the NB-2LH better?
Yes, it's sufficient to operate the camera provided you have the proper grip for your model.
Posted on Sep 01, 2008
  • 211 Answers
SOURCE: Record Changer Arm
When the carousel reaches the correct count, the computer sends a signal to the gripper motor to start it. You could have a bad motor or a bad computer. But!....if the little switch at the front of the machine is in the off position (Gripper motor On/Off) that will give exactly the same effect. It's easy to knock Off when you are loading CDs.
Posted on Oct 20, 2008
  • 211 Answers
SOURCE: Wurlitzer model 556
Are you sure you mean 556? Sounds an odd model to me. The model number is on a black metal plate the size of a credit card on the back of the jukebox (usually).
Manuals can be found at www.victoryglass.com (USA) and The Jukebox Man in the UK.
Dave.
Posted on Nov 09, 2008
MechMusicSF
  • 16 Answers
SOURCE: Record return arm doesn't go low enough to pick up record
Lubrication issue. Use some light oil (NOT 3 in 1 household - it has paraffin and will eventually clog up the parts) on all of the arms moving parts.
Be sure to get in between the gears and the moving cylinders that clamp the record.
This should resolve it. Rock Olas are known for this issue. The original grease dries up, and people neglect to lubricate their jukeboxes, even though, like a car, they are machines that require it from time to time.
Posted on Apr 18, 2009
1978 Wurlitzer tone arm
Your cartridge may need cleaning and reinstalling....remove the tone arm and check you wires for any kind of damage or wear.. ..you can use a multimeter to check for resistance in each wire..(ohm's)..you should get ZERO resistance...
Jul 09, 2017 | Wurlitzer Audio Players & Recorders
PLAYING IS CATCHING
I'm unsure as to what you are looking for in a solution, but the problem as described could be a multitude of things ranging from a worn belt, a broken lever, inadequate lubrication or many other things. It sounds to me that you might be best served by contacting a repair shop in your area.
Dec 18, 2007 | Wurlitzer Jukebox 1015 One More Time...
Norwich 2 e239.1.a how to replace stylus
Just grip the stylus carrier and slide it forward (probably slightly down too).
It looks like this:
http://www.ebay.co.uk/itm/Stylus-Needle-for-33-45-78-rpm-records-Fits-Most-Steepletone-Record-except-/301606116981
Jul 15, 2016 | Audio Players & Recorders
I have a Slik AF2100 and the locking devise does not hold strong enough, ie the grip on the ball is lose and the cameras weight is making the ball slip, is there a way of getting it tight again? Cheers
Hold the yellow trigger in slightly to release the ball head, then rotate the section with the ball clock wise until the grip on the ball suits your camera setup.
Mar 26, 2011 | Slik AF2100 Pistol Grip Head with Quick...
Records (45's) are sporatically not being picked up by the return
This is either caused by a need for adjustment or a lack of lubrication over a period of time. Please email me for my phone number so I can help you over the phone, Rod, tech@wurlitzer-ohio.com.
Jun 09, 2009 | Wurlitzer Jukebox 1015 One More Time...
Unable to pinch CD, when selection is made.
I may be able to help you. Is this the Wurlitzer princess jukebox which holds 120 CDs? If so, the problem is most likely with the clamper which opens and closes to grip the CDs. If so, email me and I can give you detailed troubleshooting information and repair advice. Rod Stebelton, tech@wurlitzer-ohio.com.
Jan 14, 2009 | Wurlitzer ONE MORE TIME CD Shelf System
Record Changer Arm
Oct 02, 2008 | Wurlitzer Jukebox 1015 One More Time...
Delayed vocal
If you're recording to an audio program on your computer (e.g., Cubase), there typically is a slight delay in the tracks you record with the first one (such as a slight delay in the vocal when layering over the guitar track). ou can change the delay in the "Preferences" for the audio card in your computer or you can remove the delay manually.. I do the latter. I record using the Audacity 1.3.3. program on a Mac G4. I find that get a 0.3 second delay in tracks layered onto the first track. So, after I record a track, I cut the first 0.3 seconds froom the beginning of the track (I give myself at least 10 seconds of "dead air" at the start. and keep playing the tracks until they're synchronized. Takes a good ear, but really is the best way to synchronize the tracks.
Nov 10, 2007 | Alesis Multimix 8 USB 8-Channel Mixer...
44 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
