Question about Samsung Cell Phones
Cannot connect to my Wi-Fi from my computer or my Samsung note3
dante777
  • 623 Answers
SOURCE: 2wire 2701HGV-W Gateway wi-fi modem
The 8200 by itself does not have networking capability.
This means that you cannot connect it directly to your router and give it an IP address, so others can connect to it.
The good thing is, that this printer is listed on the list for compatibility for upgrade with the wireless network kit (see here). The bad thing is - this kit costs about 70$ (see here).
A solution which does not cost anything, is to share the printer from your computer with the other computers. The downside is that the machine to which the printer is connected has to be running in order to let the others print.
If you decide to buy the Networking Kit - here are the setup instructions.
Sorry - but there is no simple (plug & pray) solution.
Posted on Feb 13, 2009
  • 630 Answers
SOURCE: samsung BD p3600, can not connect to the Wi Fi
Forgive me if you know this already IP address needs to be different to the Apple one. If the Apple one is 192.168.0.1 make the Samsung 192.168.0.2. subnet 255.255.255.0. Gateway should be the same as the apple number.. DNS can be left to automatic but if stuck use 4.2.2.3. Check the security settings on both the Apple and the Samsung are set to the same type
Posted on Oct 11, 2009
gomartymo
  • 20 Answers
SOURCE: could not connect to the internet using wi-fi connection
need to configure modem/router. just put ip address off modem into address bar on web browser. use admin as name and password for password. Check out portforward.com and all info will be easily found to solve problem.
Posted on Oct 26, 2009
SOURCE: I want to get a wi fi connectivity on Samsung
Shout it out loud.. WIFI!!!!!! then KABLAM!! ur connected...
Posted on Dec 22, 2010
gaganddun
  • 114 Answers
SOURCE: I had recently purchased Samsung
Dear Meghna you have not mentioned the wifi router make and moel
no problem
for this you have to go to your router web admin to add your device as WPS client this will solve the problem
for that all the models are differently configured so you have to try playing with the settings yourself, if you jumble up the settings of you wifi router there is a reset switch in all the routers that restors your router to factory settings.
if you find my information useful dont forget to vote me with the thumbsup thankyou and take care Gagan Gupta
Posted on Mar 15, 2011
Can't seem to connect to wi-fi
Cannot Connect to Wi-Fi - Troubleshooting your ... - Samsung
www.samsung.com > Home > Support > Cell Phones
Samsung ElectronicsFAQ00061225 I cannot connect to Wi-FiĀ® on my Samsung device. ... On the mobiledevice, attempt to connect to the Wi-Fi network. If you are not able to connect ...
What to Do When Your iPhone Won't Connect to Wi-Fi
Dec 19, 2015 | Cell Phones
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
How do I connect my Samsung Galaxy to BT broadband?
Are you trying to connect via wi-fi or via bluetooth? Typical hotspots are wi-fi, and that can be as easy as turning on wi-fi (in Settings, Wi-fi - see manual or quick setup brochure) then waiting for it to find an active hotspot and plugging in any necessary password. Bluetooth is much less common. Post more info and I'll try to help more.
Jul 18, 2014 | Samsung Galaxy Tab Tablet PC
Connect to wi-fi?
Are the Drivers up to date?
Jan 09, 2014 | Samsung N120-12GBK Netbook
When i connect my samsung galaxy express to wi-fi my computer's wi-fi stops working
Hello Ricardo.
How are You? I Guess you need to
1- Check your wi-fi router model.
2- Check your wi-fi settings.
also please check how many devices are connected to your wi-fi at same time. because some routers can only support upto 5 device. you can check this in the settings and also routers manual.
Please let me know, once you done with it.
Regards
Nov 22, 2013 | Samsung Cell Phones
My samsung netbook n150 plus will not connect to the wifi
Turn on your computer and locate the Wi-Fi icon.
This is located in the system tray in the bottom-right corner of the screen.
The icon looks like a series of rectangles that increase in size from left to right.
Right-click the Wi-Fi icon and select "Connect to a network." You will see a list of available wireless networks.
Choose a Wi-Fi network you want to connect to and select "Connect."
Enter the password into the password text box if a password is required. If a password is not required, you will automatically connect to the Wi-Fi network.
Click "OK."
Oct 31, 2012 | Samsung Computers & Internet
My samsung star wifi can not connect to my router
1. Tap the "Menu" button from the home screen of your Samsung Star phone.
2. Tap "Wi-Fi" and select the "ON" option.
3. Select the Wi-Fi router you want to connect to from the list available Wi-Fi networks.
4. Enter the case-sensitive password to connect to a secured network. Your phone will only prompt you to enter a password if connecting to a secured network.
5. Wait while your phone automatically connects to the Wi-Fi router.
and enjoy your wi-fi connection.
Aug 10, 2012 | Samsung S5230W Star WiFi GSM Unlocked Cell...
How to use net in laptop using my samsung champ
if you have a wi-fi connection. go to the start menu and select my computer. then on the side menu youll see my network places click it. when it opens click view my network connections if you are connected it will say connected if not it will say local area connection unplugged. if you do not have wi-fi youll need an ethernet cord to run the modem to your computer
Jan 25, 2011 | Samsung Modem Configuration Software...
Cell Phones Logo
26 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
