Question about Ryobi Garden
Ryobi cs-3635 chainsaw seems like brake is not releasing properly and is getting very hot
  • 376 Answers
SOURCE: ryobi gas chainsaw- chainsaw brake is stuck on. How do I release
You just have to pull the lever back, like it was on the saw, until it clicks/unlocks. It may be hard to do, but thats what has to be done.
Posted on Jun 11, 2009
dontbother10
  • 2220 Answers
SOURCE: Has Ryobi RCS 3535A chainsaw a fuel bulb priming
The numbers you supply don't cross to an operators manual but that is typical of Homelite/Ryobi. I'm going to make an educated guess that it does not have a primer system. Other Ryobi saws with primer systems include it in the specification. The 3535A does not. Close scrutiny reveals no primer.
IMO fuel primers on chainsaws are one more source of problems. In the USA ethanol additives attack fuel hoses. Without a primer routing is from the fuel tank directly to the carburetor and much simpler to replace. Primers on chainsaws operate differently than 4 cycle engines too. No fuel is injected into the carburetor or engine, its only purpose is to ensure the carburetor is full of fuel,
Typical Fuel hose routing:
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
HTH
Lou
Posted on Nov 15, 2009
dontbother10
  • 2220 Answers
SOURCE: ryobi chainsaw brake not releasing model pcn3335
Answered in clarfication.
Posted on Apr 03, 2010
SOURCE: ryobi pcn3335 chainsaw chainbrake will not release fully
hi i have a ryobi 4545 with the same problem ( the brake will only release if i pull it back hard ) i have had a look but can not see any means of adjustment ...hope you can help.
Posted on Apr 29, 2010
  • 2239 Answers
SOURCE: brake on poulon chainsaw 18"
The brake on this machine is a knee link design, this is an over centre catch, if there is excessive dirt under the over centre mechanism it will not lock properly and so come on prematurley, you need to remove the brake from the machine, activate the brake to release most of the spring tention,remove the hand guard fixing screw and collers, remove the hand guard carefully remove the screws securing the spring cover, be aware there is a compression spring under here, inspect the internal components, clean out any accumulated dirt and debris, replace the cover and hand guard, load the brake by pulling the hand guard fully back, the other option is to just replace the complete brake assembly part no. 530054740
Posted on Aug 30, 2011
Chainsaw brake
if it is new take it back for a warranty adjustment or repalcement
Sep 09, 2016 | Ryobi Garden
How to release the brake on Ryobi chainsaw
Probably what you are calling the brake is the anti-kickback mechanism (it looks sort of like a hand guard in front of the top handle). Just pull the top of it towards the handle, and it releases the chain.
Aug 01, 2016 | Ryobi Garden
I have a Ryobi CS 3635 chainsaw. The chain guide bar is held in place by 2 studs that screw into threaded sleeves embedded in the plastic housing . Somehow I have managed to strip these sleeves to the...
Contact you local Ryobi Dealer / Stockest, and obtain spare replament parts . Other options --- Ryobi Website ( Best ) Yellow Pages to find local Dealer
Mar 17, 2015 | Ryobi Garden
Ryobi cs 3635
plugged pickup tube... oil pump isn't turning... bar is full of debris ???
Aug 17, 2014 | Garden
Ryobi cs 3635 manual
clean the bar groove and also the bottom of your teeth may be worn too but there is usually an adjustment screw in the bottom of most saws
Ryobi gas chainsaw- chainsaw brake is stuck on. How do I release
Jun 11, 2009 | Ryobi Garden
Ryobi pcn3335 chainsaw chainbrake will not release fully
1. Is there a Homelite/Ryobi dealer/authorized repair facility near you? If yes I'd try them they may repair it.
2. Any major chainsaw seller/repairer may be able to repair it... there will be a fee.
Lou
I own a few chain saws without chain brakes. I also own and use good PPE.
Feb 25, 2009 | Ryobi Garden
Ryobi pcn 4040 chain saw
I have the same model chainsaw with the same fault. The brake is not releasing when the brake handle is pulled right back. I can only run mine if the brake handle is pulled back to the main handle with a tyrap - defeats the object of the auto-brake completely. Design fault I reckon.
Sep 28, 2008 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
37 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
