My TV network is off how do I it turn on - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,999 Answers
If you wish to get some details; check the site linked here. Pull up older posts.
Posted on Dec 12, 2016
My seiki tv detects wifi but won't connect. even after i enter the password. how do i fix this?
One reason I can think of for your problem is this: your TV detects several other protected WiFi networks (probably from your neighbors) in addition to your own, and it is likely that you entered the password for your network when trying to connect to another network. To check if this is the case and if you don't know your network's name (actually this is called the network's SSID), do the following: turn off your modem/router, then check what WiFi networks are detected by your TV. Write down the names of those networks. Turn your modem/router back on and see what networks are now detected by your TV. The new one on the list is your WiFI network's SSID. Make sure that you connect your TV to that new network.
Dec 26, 2014 | Computers & Internet
I have a wireless network in my home. I just ordered a SAMSUNG UN46D7000LF 46inch TV. The TV is wifi capable. When my TV arrives, can I just turn it on and set it to wireless network and it will find my...
If you have a wireless network, and the TV is wireless, then there will be no need to get extra cables for the TV. I'm sure if you read the book or even look at the menu observantly you will have that beast up and surfing the net in no time flat.
Mar 24, 2011 | Samsung Televison & Video
I have a samsung tv , and im setting up my INTERNET@TV , it ticks off everything but the Gateway Ping ! Please Help
If the Gateway Ping test fails, then your TV is not communicating properly with your Router or Modem.
To resolve this, follow these steps:
  1. Power off your TV, Modem, and Router.
  2. Unplug the power for your Modem and Router.
  3. Make sure the ethernet cable is securely connected to both your TV and your Router or Modem.
  4. Plug in your Modem and turn it on.
  5. Plug in your Router and turn it on.
  6. Make sure your IP Address information entered into the TV during the Network Setup matches the information from your Router or Modem.
  • If you are using an Automatic Setup (most users), skip this step.
  • If you are using a Manual Setup (advanced users), contact your network administrator to determine what the correct IP Address information is.
7. Run the Network Test again.
  • If the Gateway Ping test passes, but another test fails, click here to go back to the list of Network Tests.
  • If all tests pass, the TV is successfully connected to your network.
  • If the Gateway Ping test fails again, see below....
If the Gateway Ping test fails again, there may be a problem with your network setup. To determine if there is a problem with your network, follow these steps:
  3. Connect your ethernet cable directly to the TV and Modem.
  5. Power on the TV and run the Network Tests again.
  • If all tests pass successfully, then there is a problem with your Router setup. Contact your network administrator or router manufacturer for information on setting up your network.
  • If all tests do not pass successfully, there may be a problem with the TV. Connect another device (such as a Computer) directly to the modem.
  • If the other device connects to the internet, then the TV will require service. Click the Create online service request button below to have the TV repaired.
  • If the other device does not connect to the internet when directly connected to the modem, then there may be a problem with your modem. Contact your Internet Service Provider for help on troubleshooting your modem.
(from Samsung support)
Hope this helps. -Sa_Les_Ski
Feb 28, 2011 | Televison & Video
I have dish network and I am unabe to get the dish network remote to control the tv power and volume. Whenever dish gives me a code it works for a few days then the tv rejects it. I have a 27 in orion...
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
If this doesn't work and you have an LCD TV turn off the back light. As it is probably causing interference this is found in the TV menus.
Daniel Busa
DISH Network Customer Service
Feb 06, 2011 | Orion STV2763 27" TV
My tv went off. My cable (dish network is still on, and the power to the tv is still on, you can hear the program, but the screen is blank. But.. if you turn off the tv, then turn it on, you see the tv...
Hello, this is Dan with DISH Network, try this link it should resolve this.
Daniel Busa
Jan 07, 2011 | Westinghouse LTV-27w7 7 in. LCD HDTV
Programme remote to work with sony tv
To program your DISH Network remote to your Sony TV you will simply- press and hold the TV Mode button until all the other mode button back lights illuminate, then release.
-Now while the TV mode button is blinking please enter in the remote code 500 which is the remote code for your Sony TV after entering 500 then press the pound (#) key.
-After pressing the # key on the DISH Network remote, the TV mode button should blink 3 times and then turn off completely. This will mean the programming of the DISH remote to your TV has been completed successfully. While still in TV mode try any of the functions on the remote, such as turning the volume up or down on your TV or attempting to press the power button.
-The DISH Network remote should now be programmed to control your TV.
-If the remote code 500 doesn't program the DISH Network remote successfully you can also try each of the following using the same procedures, 000, 590, 640, 502, 002, or 567.
I hope this resolved the issue for you! Please feel free to contact us if you need any additional assistance.
-Kirstie DISH Network
Sep 16, 2010 | DISH Network IR Remote Control
Have to manually turn on tv when turning on digital converter box
Our dish remotes are compatible with most TV manufacturers. On some older TV, we may not have codes that allow for full functionality for the DISH remote. I have provided the most common codes to work with the Sharp TV. The codes are: 628, 605, 740, 591, and 606. I have also provided instructions on programming the remote to the TV.
Remotes: Basic (Television Only)
  1. Turn the Television On
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network
May 15, 2010 | DISH Network EZ Remote Remote Control
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
Mar 29, 2009 | Audio Players & Recorders
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Dec 31, 2008 | Disney 13" TV
Program dish network remote
Hi rip_1958there is something you can do and we at DISH Network call it a "power scan" itwill allow you go through all the codes we have for the TV set. The first thingyou will do is hold down the TV mode button for 6 seconds and then you willwant to press and release the Big RED power button, then you will want to push andrelease on the channel up button until the TV turns off, once the TV turns offyou will want to Stop and press the # button to lock in the code. MikeHouston of DISH Network
Dec 25, 2008 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
