Question about Zanussi Refrigerators
No warm air coming Zanussi Z910T - Zanussi Refrigerators
    Master:
  • 552 Answers
Most likely, heating element burned out
Posted on Dec 09, 2016
No warm air coming Zanussi Z910T tumble dryer
element and or thermostats need changing ,,,,
cheers
Dec 07, 2016 | Zanussi Dryers
Zanussi condenser dryers
It can be mechanical or electrical malfunction. I would check tank microswitch, float and lever.
Below is explained how the condensate drainage system works and that will facilitate fault detection.
The warm and cold air circuits cross inside the heat exchanger, which results in a thermal exchange which condenses the humidity contained in the warm air. The condensation which forms in the heat exchanger is collected in a sump, from which it falls by gravity into a tank. When the water in the tank reaches the max. level, the level of the water in the sump increases, which causes the float to move upwards, thus actioning a microswitch; The microswitch for dryers with electronic board sends a signal to the electronic circuit when the tank has been filled, switches off the appliance and lights a pilot lamp which indicates to the user that the tank is full. The microswitch with electromechanical control switches off the dryer (the timer motor is powered and ends its cycle) and lights a pilot lamp which indicates to the user that the tank is full.
Dado
Aug 10, 2014 | Zanussi Dryers
Just got Zanussi 1050 just wondered if the clothes should come out warm after a once worn wash
No they shouldn't be hot. Sounds like you have the pipes on the wrong way round at the back of the machine. Should be red to red and blue to blue
Aug 11, 2010 | Zanussi Washing Machines
I have a zanussi ZI 920/9K and the fridge has water under the salad drawer every day but the drain hole is not blocked - what else might it be?
two solutions
1...a door seal leak
2...you are puting food in that is warm or not covered and its the condensation from these that collects on the shinny surface of the salad drawer.....
remember,every time you open the door warm air from the kitchen replaces the cold air inside the fridge,it does not dry the air like a dehumidifier....
hence water droplets gather.....
Jul 05, 2010 | Zanussi ZI921 / 8FF Bottom Freezer...
Cannot open the door Zanussi Z910t
If the door will not release under any circumstances, then you will have to force the door lock open.
Remove top cover, and with a long screwdriver or similar, force it between door lock and door sneck, you will probably break door lock, so have spare one ready to replace faulty one.
Please rate my solution.
Thanks,
Jul 25, 2009 | Dryers
Zanussi TD 4112 W Not warming up
I've taken the back cover offf the dryer and found a burnt connection to the heating element. Will try and repair.
Oct 14, 2008 | Zanussi TD4112W Electric Dryer
Zanussi Z87 problem
my fridege needed defrosting for a couple of days maybe this is the problem with yours.
Sep 22, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi zk73/46ef freezer working fridge is warm
if this is an air blown cabinet defrost it for 48hrs leave the doors open then try it. hope this helps
Feb 09, 2008 | Refrigerators
Fridge is warm, freezer is cold!
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves no working. Good job trouble shooting!
Jan 13, 2007 | Zanussi ZX55 / 4 Bottom Freezer...
Refrigerators Logo
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
