Question about HP Office Equipment & Supplies
Hp m5550 cyan not printing after calibration,, need an urgent answer
    Sergeant:
    Champion:
  • HP Expert
  • 363 Answers
TRY REMOVING AND RE-INSTALLING ALL 4 TONER CARTRIDGES AT ONCE. SOMETIMES THE CYAN CARTRIDGE ISNT SEATED RIGHT. ALSO AS YOU CLOSE THE TRANSFER UNIT SEE IF ALL 4 CARTRIDGE COVERS ARE MOVING IN UNISON. GOOD LUCK !
Posted on Dec 23, 2016
techguru005
  • 28 Answers
SOURCE: hp 2600n color printing problem
are you using orgnial hp cartridge if not check that it may cause due to that. check the black sheet fro color spreading , if there is any color pls clean that.........
Thank you
Posted on Feb 22, 2008
  • 14 Answers
SOURCE: hp 4600 no cyan printing
Firstoff, if you have tray 1 set to "any size" & "any type" they had problems with it going into calibration to frequently. If you upgrade the firmware this will take care of that. As for no Cyan, check the scanner interlock to insure it is opening the scanner cover. You could also go into diagnostics and disable cartridge check and swap the cartridges around, ie. cyan & magenta, run the print quality pages and see if the problem follows the cartridge. It could also be HV power supply.
Posted on Jun 19, 2008
  • 84 Answers
SOURCE: HP all-in-one not printing cyan color
Place a soft clean tissue paper over the cartridge print head and leave for about eight minutes. You can secure it with the aid of a rubber band. It should be held firm ok. If the tissue paper is not dampened by ink then the cartridge would have gone bad or the ink dried. You also know that they have expiry date and could go bad while yet in the packaging b/c it has expired. Good luck
Posted on Jun 02, 2009
  • 13 Answers
SOURCE: URGENT (3M Company) epson nx410 -
Epson printers& scanners have been my favs 4 many yrs. u cannot bypass an empty cartridge-sorry. i can tell u the absolute cheapest place to get Epson-compatible inks,tho. aaatoner.com been using them 4 years. go to their site> epson>inkjets> find model of ur printer. flat-rate ship $5.95 no matter how little or much u get. they have great bundels,i.e.sets of ink. i currently use stylus c88 was 49 no ship direct from epson refurb in 2007 still goin' strong. np. last ink i got think in july was a set of 10 inks 2/ea. C,M,Y and 4 K(black. including the flat post was $43-$44. came in less than a week since i've ordered from them in different states all over. CA,AZ,ID,OR. different addresses in all those states too. check out the epson site clearance and driver downloads and manual downloads for many dif mac&windows OS. Jacki
Posted on Oct 05, 2010
seeker5211
  • 1089 Answers
SOURCE: HP 4700 not printing cyan
If your printer is missing a color it could be caused by (off the top of my head) 3 possibilities.
1. High voltage board
2. laser/scanner assembly for that color
3. DC controller might need a firmware upgrade, www.hp.com
Run the PQ diagnostics, check the cyan color
Run the Cartridge Disable diagnostic. Remove all cartridges and take the black cartridge and insert it where the cyan normally is. If the black prints in the cyan slot, your cyan cartridges are bad. If the black doesn't work then go to #3 above. It won't cost any money to upgrade the firmware. If it still doesn't work call in a printer tech.
At this point you may need a printer tech.
Posted on Nov 01, 2011
Alignment off on HP CP4005dn Color Printer
dear friend
how much life pending in image transfer belt
check first
Mar 27, 2014 | HP Color LaserJet CP4005dn Network Printer
I have hp designjet 450c..the problem in printing.while printing it prints copy of the image also and not clear.i dnt know whts the problem..please help me..
That usually is caused by clogged or damaged printheads. There are 4 printheads, Black, Cyan, Magenta and Yellow. When you replace the printheads you need to calibrate the machine so the colors line up with one another.
Jan 23, 2014 | HP DesignJet 450c InkJet Printer
Does it have reason On colour laserjet printers the cartridge installed it's a sequence is the same YMCB?why?
Calibration is setting registration points to each cartridge from the transfer unit and or drum. Y-yellow, M-magenta, C-cyan, B-black
Sep 18, 2012 | HP LaserJet Office Equipment & Supplies
Nov 01, 2011 | HP LaserJet 4700 Printer
Whenever I print color, entire page comes out blue. I have replaced the cyan cartridge (twice) and the Laser Transfer Kit. Sometimes there are thick blue streaks in addition to the overall blue color. What...
Run the "disable cartridge check"
It will be in the Diagnostics.
Once you start the test, you can remove all the cartridges. Put the cyan in the black cartridge slot.
print a config page. If it is all blue, you have another bad cartridge. If it prints correctly(minus the other colors)...continue
Now put the magenta in the cyan cartridge slot. Print the config page again. If you have red all over the page, you have a problem with the slot itself.
Press the STOP button and then select EXIT diagnostics. Put the cartridges back where they all go and run CALIBRATION more than once.
Select/menus/down arrow/configure devce/select configure device
Down arrow/print quality/seect print quality
Down arrow/ calibrate now. Select it and wait.
Oct 25, 2010 | HP Color Laserjet 3550 Printer
Jun 02, 2009 | HP Officejet Pro L7680 All-In-One Printer
My HP LaserJet 2605dn is printing pictures with a bluish tone
Check the Colour management in printer driver on the computer - set this to Automatic.
On the printer or The HP ToolboxFX, check to see if Economode is turned on (under Print Quality) which reduces the print quality.
Dec 15, 2008 | HP Color LaserJet 2600n Printer
Skewed printing
Most probably you have to do the Color Registration Settings and the Color Calibration.
The Color Registration will fix the fuzzy printing and the Color Calibration the way how the colors looks. The Color Calibration it is done automatically after each batch of 40 or 80 pages and if you need you can do a manual Color Calibration BUT THE COLOR REGISTRATION must be done manually.
Go to Menu->Others->Service->Color Registration and print a test chart. Will print a page and you have to read the alignment of some lines Cyan Magenta Yellow Black with some numbers. Check the Advanced user guide for details. Basically you have to read the number / letters of each color where 2 lines are matching. Then you can enter those numbers into the printer for each color.
If the Cyan only is off then will be easy ...
Nov 03, 2008 | Kyocera FS-C5030N Led Printer
Hp 4600 no cyan printing
Jun 18, 2008 | HP LaserJet 4600dn Color Printer
HP COLOR LASERJET 3500
Hi!
If you could possibly manage to access the machine status menu and have it print to check the drum's life, fuser life, developer, etc.. pls refer. Kindly replace the toner cartridge accordingly use the menu settings when replacing any color if needed. Please print solid image or block in each color Cyan, Magenta, Yellow and Balck. Well see if what color causing the problem. Please let me know the print result it may be; washed out or too light, too bright or black, double image, or not clean. Don't hesistate to contact me again about the result.
Best regards,
Rosener Guyano
Jan 31, 2008 | HP Color LaserJet 3500 Printer
32 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
