Question about HP Office Equipment & Supplies
Hp m5550 copy not complete after calibration - HP Office Equipment & Supplies
Hp m5550 cyan not printing after calibration,, need an urgent answer
TRY REMOVING AND RE-INSTALLING ALL 4 TONER CARTRIDGES AT ONCE. SOMETIMES THE CYAN CARTRIDGE ISNT SEATED RIGHT. ALSO AS YOU CLOSE THE TRANSFER UNIT SEE IF ALL 4 CARTRIDGE COVERS ARE MOVING IN UNISON. GOOD LUCK !
Dec 07, 2016 | HP Office Equipment & Supplies
How to calibrate the touch screen on hp cm4540mfp
In your Setings, find Display, than Calibrate, and folow the instructions on the screen, or look up in the index of the manual, under Calibration...
Good luck.
Tony :))
Oct 27, 2014 | HP Color LaserJet Enterprise CM4540 Laser...
Color copies not clear
I think its alignment problem.Press menu button>scroll to system setup & enter>scroll to quality & enter>scroll to calibrate & enter> scroll to calibrate now & enter.. wait till calibrate completes..check print quality..If its not rectified better to send it to service center..
Nov 15, 2011 | HP Color LaserJet 2600n Printer
0xc18a0401 appears on the screen after start up of the printer When trying to copie : same fault. Can you give me some advise.
Try resetting the printer. With the unit on, unplug the data cable (USB) from the back of the printer. (At times, unplugging the data cable from the computer helps). Then remove all of the ink cartridges and wait for the message "Insert Ink Cartridges" to appear. At this point, unplug the power cord from the back of the printer. Wait 60 seconds (or longer) then plug the power cord back in. Power on the printer if it doesn't come back on. Reinstall the ink cartridges when the unit prompts you to do so. Close the cover. Print a calibration page if you get a prompt to do so. (Do the complete calibration including scanning the calibration page.) Finally plug in the data cable (to both the printer and the computer if you completely disconnected it). .
Try printing again.
If the error persists, the unit needs service from HP. You will need to decide if the cost is worthwhile if the printer is out of warranty.
I hope this helps.
Dec 02, 2010 | HP Photosmart 3210 Printer
Printer hp 4600 dn consumes a huge quantity of toner material especially magenta and black. Toner is exhausted after 3000 copies with mostly copies without pictures. Can it be possible that starting the...
the toners are rated for a certain number of pages based on 15% coverage on the page. print a supplies usage page from the control panel on printer if available to show you how many pages you printer and what the coverage was.
calibration does use ink, but should not be that much.
If you are using non-HP toner, this may be why you don't full life out of them. Try HP toners and see if problem remains.
Sep 02, 2009 | HP LaserJet 4600dn Color Printer
Calibration error how do I fiw it or reset it on
Try to check inside the printer. the sensor maybe blocked by small paper thats why paper jam error appear.
Aug 13, 2009 | HP Photosmart 8050 InkJet Printer
Copier doesn't recognize that paper is loaded
Hello sir; Make sure you close drawer tight then pay attention on listening the noise when you close the drawer, if quiet that's mean paper lifting motor defect, otherwise go to paper sensor.
Aug 05, 2009 | HP Office Equipment & Supplies
When printing a greeting card the copy appears too low on page so one fourth of an inch is cut off on the bottom of the page.
On Printer press Menu button.
Scroll down to tools an press ok.
Scroll down to Align Printer and press ok.
The Printer will calibrate automatically.
May 11, 2009 | HP Photosmart 8250 InkJet Printer
Hp d135 copy function makes copy in green instead of black
ur tri color cartridge may have run out. change it and try again. if it doesn't work try calibrating ur scanner.
May 03, 2009 | HP OfficeJet D135 All-In-One InkJet...
22 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
