Question about Aiwa NSX-A777 Shelf System
Tape players do not operate
Doors open ,tape loads, counter show 0000, hot play-nothing moves.
  • her_ky Jul 20, 2009
    The post should have said:
    Doors open ,tape loads, counter shows 0000, does not play-nothing moves.
    Problem Solver:
  • 18 Answers
Sounds like the belt is slipping or broken. You should first listen with your ear near the cassette door to see if the motor trys to work. Many units use the main belt to work the lift mech. for the heads, If that doesnt have enough grip the motor will spin(Which you can hear lightly) and the unit does nothing.
Posted on Jul 23, 2009
Magnavox dv220mw9 the vcr player won't play
Someone will have to open the unit to see what is happening---either tape is not loading all the way or when FF or Rewind hit not moving the reels----could be as simple as a belt or a bad drive idler (most use either a rubber wheel or gears to move the tape in Play, FF, and Rewind.
Dec 03, 2012 | GoVideo VR4940 DVD Player/VCR
I have a sony TC-660 reel to reel player, it had been in great condition, and i love using it. All of a sudden however, the reels will ONLY move in one direction (clockwise for the left, and counter...
In order to maintain tape control and tension the reels always pull lightly in opposite directions during PLAY mode. The capstan moves the tape in the desired direction at a precise speed. If the capstan doesn't engage the tape BETWEEN itself and the pinch roller you'll get the reels battling over control of the tape. Check the tape routing.
May 25, 2010 | Quantegy 456 Reel-To-Reel Recording Tape
My tape won't play, I just get an
ATR keeps showing on the TV screen when I am trying to play a tape.
Jun 17, 2009 | Toshiba SD-V290 DVD Player/VCR
Sony Stereo Cassette Deck TC-WR550Z
Drives belt has become too slack to drive mechanism properly or the drive motor is bad. Have unit serviced for new belt(s)
Apr 29, 2008 | Sony TC-WR565RM Single Cassette Deck
Marantz Cassette Deck Model Sd 35 Tape door will not open
It sounds like the drive belts on the deck have broken (not allowing playing, FF or REW) and/or the tape got "eaten" meaning the tape itself has wound itself around the rollers and cannot free itself. I strongly doubt this is an electrical issue. Definately sounds mechanical.
As far as the door not opening, there's usually a hook that holds the door closed. If the unit is mostly disassembled, look near one of the sides of the door for a metal hook. It's normally spring loaded and can be moved manually. That should free the door. If your tape was eaten, it might take some gentle persuasion to unwrap it from the rollers.
Good luck.
Feb 04, 2008 | Audio Players & Recorders
VHS Tape
Possibly the tape is wound too tight and is not actually playing when in play mode.
Also, tapes can be accidentally erased. If it is placed on a speaker or other magnetized surface it will erase itsself. The magnet draws something out of it.
I'm not sure exactly how it works but I know it happens.
Don't give up just yet. Check with your local video rental store... maybe they know a trick that will help you.
Good Luck :)
Jan 02, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Akai Gx-77 reel to reel tape dech
Gx 77 is working now I have solved my prbblem with my friend. where I will get big flat belt for rewinding spool/
Nov 14, 2007 | Audio Players & Recorders
Video won't show up on comp monitor
check your inputs on that machine. there are settings that you need to do. when you put a tape in the minidv, does it play fine? if it does, you need to check your input setting on that machine..good luck
Apr 03, 2007 | Panasonic AG-DV2000 Mini DV VCR
Cassette loading process won't complete
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. If you're NOT still under warrantee you should at least open the VCR and Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY.
Dec 28, 2005 | Panasonic PV-V4021 S-VHS VCR
Aiwa NSX-A777 Shelf System Logo
168 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
