What it means by Wiring Fault error code no 194 shown by E.T.N 9355
3 Suggested Answers
  • 64 Answers
SOURCE: error 194
hi there is no error code 194 in this m/c any way you have to check the scaner may the errror on the scaner unit
thanks
Posted on May 24, 2008
  • 120 Answers
SOURCE: Service Code H5-01
You had a jam in your fuser and let copies pile up behind it. You get five tries to get paper through before the copier gives up and throws H5-01.
First, let your fuser cool and clean the mess of accordioned paper out of it. Make sure all your sheets are whole and all pieces recovered. You may need to put the white pressure levers down and turn the green knob. Dont forget to reset the levers.
Then put the machine in test mode with the key combo P-*-C-*
and go to test command 14-Start to clear the code.
If its still jammed you may need a service tech to take out the fuser for cleaning.
Posted on Jul 09, 2009
Hi i have a lg washing machine wft8061dd,can u please tell me why PE appear when it turn on
Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch. It is rare to see this error code on LG washers.
On non-display panel models this fault code can be shown by the lights for fuzzy, heating and speedy or super, normal and hold being lit or flashing.
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
Jun 13, 2016 | LG Washing Machines
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
Dado
May 05, 2015 | AEG Washing Machines
Wiring error code 2099
you have mis wired the control wires, N1, N2, T1, 194 & 23. Somewhere you crossed the low and high voltage wires
Aug 17, 2014 | Generac Power Systems Electrical Supplies
Bmw e90 fault codes
the error codes are BMW specific and yes an error code would show up as a cam position sensor fault.
May 11, 2014 | 2008 BMW 320D E90
I went to scan my toyota yaris car and the following codes were give ; temperature ckt low input po117
EOBD II Error Code: P0117
Fault Location:
Engine Coolant Temperature (ECT) Sensor (G62) - Low Input
Possible Cause:
Malfunction Indicator Lamp (MIL) Triggered on first occurrence.
Coolant thermostat.
Wiring short to earth.
Engine coolant temperature (ECT) sensor.
EOBD II Error Code: P0340
Fault Location:
Camshaft Position (CMP) Sensor A (G40), Bank 1 - Circuit Malfunction
Possible Cause:
Malfunction Indicator Lamp (MIL) active.
Wiring from/to Camshaft Position Sensor (CMP) faulty.
Camshaft position (CMP) sensor faulty.
Timing misaligned.
Possible Solutions:
Check Wiring from/to Camshaft Position Sensor.
Check Camshaft Position Sensor.
Check Timing.
EOBD II Error Code: P0500
Fault Location:
Vehicle Speed Sensor (VSS) - Circuit Malfunction
Possible Cause:
Malfunction Indicator Lamp (MIL) Non Emission Fault - No warning light.
Wiring.
Vehicle speed sensor (VSS).
Engine control module (ECM).
Dec 13, 2012 | 2001 Toyota Yaris
What does p1357 mean intermittent secondary frt efi
wow test .....hope this helps.... Engine light being on. That is the sign there is a Code that is stored. This may help you.
Harley iagnostic Codes
To access codes
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word ¡°diag¡± should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" (on mine the ¡°t¡± looks more like a ¡°¨\¡± )with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC¡¯s the code will be displayed or the word ¡°none¡± will appear if there are no DTC¡¯s. Push the odometer reset button again to view additional codes if they exist.
1 - Record the codes.
2 - If DTC¡¯s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC¡¯s again by repeating steps 1 to 3 If the code is current it will reappear.
4 ¨C Press and release the odometer reset button to continue to the next module.
5 ¨C Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
HFSM = Hands Free Security Module
TSM = Turn signal module
Priority/DTC/Fault condition
1. P0605 ECM FLASH Memory Error
2. P0603 ECM EEPROM Memory Error
3. U1300 ECM Serial Data Low
4. U1301 ECM Serial Data High
5. U1097 Loss of Speedometer Serial Data to ECM
6. U1064 Loss of TSM/FSFM Serial Data to ECM
7. P1003 System relay contacts open
8. P1002 System Relay Coil High/Shorted
9. P1001 System Relay Coil Open/Low
10. P1004 System Relay Contacts Closed
11. P1009 Incorrect Password
12. P1010 Missing Password
13. P06415 V+Vref 1 Out Of Range
14. P06515 V+Vref 2 Out Of Range
15. P0373 CKP Sensor Intermittent
16. P0107 Map Sensor Open/Low
17. P0108 Map Sensor High
18. P0374 CKP Sensor Synch Error
19. P1600 EFI Module Processor Internal Error
20. P1270 TGS Validation Error
21. P2107 EFI Module Processor Internal Fault
22. P2122 TGS1 Low/Open
23. P2123 TGS1 High
24. P2127 TGS2 Low/Open
25. P2128 TGS2 High
26. P2138 TGS Correlation Error (Twist grip sensor)
27. P0120 TPS1 Range Error
28. P0220 TPS2 Range Error
29. P0122 TPS1 Low
30. P0123 TPS2 High/Open
31. P0222 TPS2 Low
32. P0223 TPS2 High/Open
33. P2135 TPS Correlation Error
34. P2119 EFI Motor Throttle Body Range Performance
35. P2100 EFI Motor Circuit Open
36. P2101 EFI Motor Circuit Range Performance (Actuation Error)
37. P2102 EFI Motor Circuit Low
38. P2103 EFI Motor Circuit High
39. P2176 EFI Closed Position Not Learned
40. P1514 Air Flow Fault
41. P2105 EFI Forced engine shutdown
42. P1501 Jiffy Stand Sensor Low
43. P1502 Jiffy Stand Sensor High
44. P0572 Brake Switch Low
45. P0117 ET Sensor Low
46. P0118 ET Sensor High
47. P0112I AT Voltage Low
48. P0113I AT Voltage Open/High
49. P1351 Front Ignition Coil Driver Open/Low
50. P1354 Rear Ignition Coil Driver Open/Low
51. P1352 Front Ignition Coil Driver High/Shorted
52. P1355 Rear Ignition Coil Driver High/Shorted
53. P1357 Front Cylinder Combustion Intermittent
54. P1358 Rear Cylinder Combustion Intermittent
55. P0261 Front Injector Open/Low
56. P0263 Rear Injector Open/Low
57. P0262 Front Injector High
58. P0264 Rear Injector High
59. P0562 Battery Voltage Low
60. P0563 Battery Voltage High
61. P0501 VSS Sensor Low
62. P0502 VSS Sensor High/Open..
63. P1356 Rear Cylinder No C...[Message truncated]
Sep 25, 2011 | Harley Davidson FLHRC Road King Classic...
What does e 62 error code refer to?
E62: Overheating during washing this is real ans now iam giving u more tips abt error -
E11: Difficulty in filling during wash phase
E13: Water leakage.
E21: Difficulties in draining .
E23: Malfunction of drain pump triac.
E24: «sensing» circuit of the component (triac) that controls the drain pump faulty
E33: Incongruence between closure of anti-boiling and 1st level contacts of pressure switch
E35: Water level too high
E36: «sensing» circuit of anti-boiling pressure switch faulty
E37: «sensing» circuit of 1st level pressure switch faulty
E39: "HV" «sensing» circuit of anti-overflow pressure switch faulty
E40: Door open, Interlock, wiring or main PCB
E41: Door open
E41: Problems with aperture of door
E42: Problems with aperture of the door
E43: Problems with the triac which actions the door interlock
E44: Door closure «sensing» circuit faulty
E45: Problems with the «sensing» circuit of the triac that actions the door interlock
E51: Motor power triac short-circuited
E52: No signal from the motor tachymetric genetaror
E52: No signal from the tachymetric generator
Procedure for checking commutator motors
E53: Problems with the «sensing» circuit of the triac which powers the motor
E54: Motor relay contacts sticking
E61: Insufficient heating during washing
E66: The contacts of the heating element power relay are always closed
E71: NTC washing sensor faulty.
E82: Error in reading the RESET/OFF position of the programme selector.
E83: Error in reading the programme selector code
E93: Incorrect machine configuration.
E94: Incorrect configuration of washing cycle
E95: Communications error between microprocessor and the EEPROM
E96: Incongruence between control panel version and configuration data
E97: Incongruence between selector version and configuration data
EA1: Drum positioning system (DSP) faulty (top-loaders only)
EB1: Incorrect mains frequency
EB2: Mains voltage too high
EB3: Mains voltage too low
E32 INCORRECT CALIBRATION OF ANALOGIC (ELECTRONIC) PRESSURE SWITCH. IF THE MACHINE IS DRAINING OK, THEN IT IS THE SWITCH
E32 relates to the electronic pressure switch, normal pressure switch,inlet valves,poor water mains pressure and finally the main control board
E90 means theres a fault on the main control module so A;will need a new control module or B; get an engineer to try re-configureing the module
May 16, 2011 | Hoover Washing Machines
Asko w6 222 has a F1 error. how do I fix it. thanks Rose
Hello Rose, here is a chart to help you identify what the problem is with your asko
Failure
Code
Condition Check/Repair F1 Water supply/low water fill · Check water supply to machine
·Replace water inlet valve F2 Water level too high · Plugged/Bad water pump
· Faulty water valve F3 Pump problem Check pump trap and clean. F4 Thermistor problem · Open thermistor, replace
· Bad wiring to thermistor F5 Fault in thermal cutout or heating pause fault. Selected temperature not reached in 90 minutes · Check heating element
· Check thermostat F6 Motor fault · Check wiring to motor
· Replace motor if necessary F7 Door lock release fault · Bent pull-rod for door latch
· Bad door latch solenoid 00 00 Machine did not spin Check load for out of balance Redistribute load and restart
usually this means the water valve that the hoses are connecting into the machine has gone bad and needs to be replaced if your looking to order the part online i would suggest marcone appliance parts they seem to be the cheapest when it comes to repair parts and they are also one of the biggest I hope this opinion has helped in your appliacne situation and if i can answer any further questions please message me back. Please also remember to rank how this opinion has helped in your appliance situation
Thanks again
Rick
Nov 28, 2010 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
