Question about Yamaha Music
Manual for Yamaha ds-49c what is the power point for?
Need a Repair manual for Yamaha Electone HC-4 home organ or source to purchase Motherboard for same
Request the repair manual directly from Yamaha. Fixya is unable to identify a source for the motherboard other than Yamaha.
Mar 19, 2018 | Yamaha Music
Hi I need the audio output IC of Yamaha FE30 where can I get
Hi. There are two ICs, the left and right STK465 (30W+30W) power amp is one and the Centre STK085 (60W) the other.
Ebay might be of some help.
The service manual is on Elektrotanya YAMAHA FS20 FS30 Service Manual free download schematics eeprom repair...
Oct 03, 2016 | Yamaha Music
How to factory reset my Yamaha PSR S500
According to the manufacturer, the reset procedure is documented here and on page 42 of the instruction manual:
http://faq.yamaha.com/us/en/article/musical-instruments/keyboards/digitalkeyboards/portable_keyboards/psr500/656/2085/psr500-psr500m_factory_reset_procedure
  • Turn OFF the Power.
  • Press and hold the 'Custom' [RECORD/END] and [CLEAR] buttons.
  • Turn ON the power. The screen will display 'clr'.
  • Release the 'Custom' [RECORD/END] and [CLEAR] buttons.
  • Dec 05, 2015 | Yamaha Music
    Can I connect only one speaker to a yamaha emx 312 sc power mixer?
    First it is certain that you would not want to plug both outputs of the stereo power amp into one speaker combining both channels into the same speaker. (see image from manual below - also link to manual)
    Next I would be very concerned about only using the one side of the main amp out as it could cause an unbalanced load, or you could be driving the load into dead air connection and any of these conditions are destined to cause premature failure of the power amp.
    Taking a quick scan of the manual for this unit, it appears what is pretty common to most powered mixers, hook up two matched speakers/loads to each chanel of the output.
    Your best bet is to shed those monster cabs, there really is no need for them especially with this sized powered mixer, and get yourself a nice pair of full range cabs like EV1202;s, EV SX300's, or some nice 2 or 3 way 15" JBL's/
    Just my opinon.
    Link to Yamaha EMX 312 Owner's Manual:
    Yamaha EMX Series Owners Manual
    Dec 06, 2013 | Yamaha Music
    Dgx 230 dc in connector bad
    This type of keyboard is well know for the power socket breaking away from the main PCB. You will need to unscrew lots of screws to reveal the circuit board with the power socket on. If you look closely at the solder side you will probably see that the track that the socket is soldered to has broken. Simply link the solder joint to the circuit further along the track by bridging between socket and next point along the track. You may need to replace the socket if it has become damaged. If you can use a soldering iron it is fairly easy but if in doubt contact a repairer.
    If you need a socket Google :
    Yamaha PSR power socket ( KPA3 / PA130UK / EPA3 ) (LB30226R)
    Jan 25, 2013 | Yamaha Keyboard w/ 76 Graded Action Piano...
    Drum kit won't power up
    Get a voltmeter and check the power to see if it is working at the plug. the voltage should be 12vdc. If you don't have a meter, just take the power adaptor to radio shack, or any electronics supply house.
    They'll check it for you. below is a copy of the manual. Good Luck!
    Download Yamaha DTXPLORER User manual
    Sep 01, 2011 | Yamaha DTXplorer 5 Electronic Drum Set
    Need yamaha psr170 keybord manual and a/c adapter! can anyone help? was given to me, don't know if it works.
    Click on the following link:
    http://www.yamaha.com/yamahavgn/CDA/ContentDetail/ModelSeriesDetail.html?CNTID=2258&CTID=205000
    If you then click on the "Resources" tab, you'll be able to download the manual. The A/C adapter you're looking for is the "Yamaha PA3B Power Adapter", which has now been discontinued. You can use an universal power adapter instead using these specifications:
    Input: AC 120V, 60HZ
    Output: DC 12V, 700mA
    Polarity: Center Positive (+)
    Hope this helps. If so, please rate. Thanks.
    Apr 19, 2010 | Yamaha Portable Keyboard
    I have a YAMAHA GA 24/12 mixer and 10 aux (all) no
    Check that you have the gains INTO the aux channel from each strip you want routed there turned up... AND... the gains OUT of the aux turned up. Two places to adjust the gains.
    The AUX LIKELY use TRS balanced outputs... check that you are using those.
    These are a starting point, I do not have a manual for this device.
    Feb 11, 2010 | Yamaha Music
    Yamaha Keyboard SY77 has no power. I've tested with a multimeter the power button and all the fuses that share that same circuit board. All seems well. Any troubleshooting ideas from this point forward?...
    Try finding the bridge rectifier which is the device that converts the incoming alternating current into direct current which powers the circuits. Test it using the diode test function with a multimeter if you have one and see what results you get. There may only be a voltage rectifier or just a series of back to back diodes but that is what you want to test. I don't at this point have a schematic or service manual for that keyboard. Hope this helps.
    Aug 19, 2009 | Music
    Music Logo
    Top Yamaha Music Experts
    Michial Gueffroy
    Mike
    Are you a Yamaha Music Expert? Answer questions, earn points and help others
