Why do i get error message "server disk full" when i scan files to email
Bubbabear64
  • 2794 Answers
SOURCE: Scanning to C352 server connect error
Check you smtp server settings in admin settings. Verify there correct. If your smtp server needs your email address and password to send, that should be populated as well under them smtp authentication settings.
Posted on Oct 20, 2008
mohanchennai
  • 490 Answers
SOURCE: cannon capture perfect 3.0
Check the location where you are directing the scanner/computer to store the scanned image. If it is full, obviously it cant store. Change the location where there is space.
S. Mohan
Posted on Nov 08, 2008
SOURCE: brother 5460cn won't scan to email,file,ocr,image
Brother Scanner error message.
After much time with Brother Tech support. The solution finally turned out to be as simple as downloading this file to reset the drivers.
http://support.visioneer.com/utilities/twain_reset.exe
Posted on May 13, 2009
  • 214 Answers
SOURCE: Unable to scan to email after switch to Exchange 2007
check the server settings, maybe user authentication is needed, check from server side, what the printer is trying to do and where it fails. check printer e-mail settings, try these setting in computer.
Posted on Oct 15, 2009
SOURCE: message "the disk in a destination drive is full"\...
Right Click USB > Properties > Hardware TAB > find your USB or general usb flash disk usb device , Double Click it > Go Policies TAB > Optimize for perfromance
then Click Yes ,
don't press the emergency restart
then format it ,
right click > format file system , choose NTFS
then wait ,,
copy and paste
Posted on Dec 03, 2010
What does server disk full mean? And how do i fix it?
The server stores everything that is on your PC or any other PC that is connected to it. You need to clean it out. IE/ Delete all old files in the trash, temp files etc etc. The server disc full means that there is no room left on the hard drive for more data to be stored. If you are not sure what to delete, get someone who has a bit of PC knowledge because If you delete system or program files, the server will crash next time you reboot it, or some programs may not work correctly. Hope this helps.
Sep 18, 2015 | Konica Minolta Office Equipment & Supplies
Server disk full in bizhub 420
malfunction was detected cs remote care c2403
Aug 21, 2012 | Konica Minolta bizhub 420
I have to Konica Minolta printers one a BizHub C220 & the other BizHub C353. All the scan to email function except for to users that have a large email account. I did setup an alias and forward the...
Hi Tim,
Can you please let me know the exact error message that you get , while you attempt to use the scan to email function?
May end users believe to scan-to-email to themselves internally, and then send it externally.
and the find it as a probably better option, as we get to preview the attachment before it goes out.
If you are using an exchange server then the exchange cannot handle the message size or attachment size, as well as when there is actually not enough space on the server probably it's full or near full.
Try setting up the email account again and then check if the problem persists, most probably this problem would not persist after a reset of the email account.
Hope this helps...:)
Aug 29, 2011 | Konica Minolta bizhub C250 All-In-One...
What is error 4? and how to solve.balance is stuckedup
What does particular error code mean "General failure". Particularly for "General failure", the SFTP server should provide you more details, that you will see next to "Error message from server". Unfortunately, SFTP server shipped with OpenSSH (or Sun SSH) does not. That is, why you see there just "Failure" (very useful).
Some situations when OpenSSH (Sun SSH) server issues this useless error message:
a. Renaming file to name of already existing file.
b. Creating directory that already exists.
c. Moving remote file to different filesystem (HDD).
d. Uploading file to full filesystem (HDD).
e. Exceeding user disk quota.
thank you
Aug 02, 2011 | Computers & Internet
Server connection error when scanning
have you set up your scan Email account with you page Scope disk with the copier. is the server set up for scan to email. Also check the konicaminolta web site for scan operator manual. Down load the scan programs
Mar 24, 2010 | Konica Minolta Bizhub c203 Copier
SamsungCLX 3160FN Software problem with scanning to OCR and Email
you may have to set up the email server address.ie the SMTP Server address in the file sharing settings. you cant scan to email without this. you need the email provider address and you may need to set up your admin email. you can use your own for this. if you can scan to a folder you can always forward as email from your docs folder if you have a problem.
Dec 08, 2009 | Samsung CLX 3160fn All-In-One Printer
Unable to scan to a file
do you have your smtp server set up and an email address in your printer
Nov 15, 2008 | Office Equipment & Supplies
MS server 2003 prem with exchange mounting mailbox store
DOWNLOAD THIS BOOK FOR FREE AND SOLVE ANY PC HARDWARE, SOFTWARE OR OPERATING SYSTEM PROBLEMS.
DOWNLOAD NOW......
Download mirror 1 ( Hosted by HostingDude)
Download mirror 2 ( Hosted by Softpedia )
Download mirror 3 ( Hosted by Soft32 )
Download mirror 4 ( Hosted by fileflyer )
Download mirror 5 ( Hosted by Rapid Share
358
Oct 18, 2008 | Microsoft Small Business Server 2003...
COULD NOT LOAD OS - TRIED 2000 & 2003 SERVER
Reinstall OS without repairing. Sometimes people make the mistake between a choosing repair and a full reinstall. Also backup any files before doing so.
Sep 20, 2008 | Acer Altos G530 Server
How to scan to email
dear customer,
these are some of the ways to do it.. hope its useful..
VistaScan - Scan to Email
VistaScan's direct email link requires either a MAPI (Microsoft Exchange compatible system) or VIM (Lotus cc:Mail system) messaging program - these are commonly used on corporate networks and aren't installed on normal consumer PCs - home and small business users can scan-to-email via PageManager or by attaching images as described below.
VistaScan 3.1 scan-to-email preferences for the commercial MAPI and VIM messaging systems - to reduce the size of file attachments the JPEG file format is recommended.
MAPI programs include Microsoft Outlook 97 and 98 (which can also be used with normal Internet mail accounts) and the latest Netscape Messenger client.
Outlook 98 is a commercial software package (not included with Windows), with support for Internet mail systems, Exchange Server or Lotus cc:Mail messaging servers. outlook98.gif
VistaScan 3.1 application used with Microsoft Outlook 98 - scan-to-email is selected as the destination for the image When VistaScan is used with either a MAPI (Exchange) or VIM (ccMail) mail system it will detect the presence of the software via the Windows registry and automatically launch the client and a new message window, with the single file attached - the message must then be written and sent before the scanner driver can be used again.
Sending images to Email Clients using Presto PageManager 4.0
Presto PageManager is a useful way to capture and archive scans before sending them to another program (eg image editor, word processor) or to print. A few email programs can be linked with PageManager, allowing an image to be "dropped" on a Application Button to automatically open a new message with the scan attached. Microsoft Outlook 98, Netscape Messenger (aka Netscape Mail), Lotus cc:Mail and Eudora Pro 3.0 can all be added as email applications - Outlook Express, Compuserve and AOL cannot be directly linked (these are limitations of the mail programs, not of PageManager!).
pmoutlookbutts.gif comm46butt.gif OutLook Express cannot link with PageManager - a new email won't be opened when selected. PageManager adds an Outlook Express button automatically. Outlook 98 will correctly open a new email and attach the scan(s). PageManager won't setup Outlook 98 automatically, it needs to be Registered as a new application. Netscape Mail will correctly open a new mail with attached scans when selected. The Application Button is setup automatically by PageManager.
Preparing Files for Email Clients
As many Internet email programs do not support Exchange or cc:Mail, the two commercial mail systems integrated with UMAX software, you may have to prepare your scans: the images to be sent need to be saved on your hard disk in a suitable file format, ready to be "attached" to an email.
In general it is better to send as small a file as possible by email, as the image has to be transferred to the Internet over a relatively slow modem link - most users prefer a compressed file format such as JPEG (.jpg). This compresses your scan to a fraction of the original size, although it does slightly reduce the quality of the images.
There are three ways you can save your scans to disk:
1. If you use the VistaScan program (Start, Programs, VistaScan 3.x, VistaScan) you have several choices in the "Scan To" box (Advanced mode).
Click on the Floppy Disk icon - this will then use the settings in the VistaScan preferences:
For emailing scans we recommend the JPEG format - check where the scans will be saved (which directory). File names are created automatically - scan1.jpg, scan2.jpg etc.
2. If you normally scan your images in to PageManager you can export them to your hard disk - right-click on the thumbnail view and choose 'Save As...':
Choose a file location and select the "Save as type" file format.
3. If you are aquiring the VistaScan driver via any other application (eg Adobe PhotoDeluxe) then you should have options to save the images and to change their formats - please refer to the instructions for each application for for further advice.
Attaching images to an Email
All email client programs will allow you to combine file atachments and your text in to a single message for sending - although there are small differences in the way attachments are encoded you normally only need to customise options if sending to someone with an Apple Mac, which supports slightly different graphics file formats. Below are instructions for attaching files in some of the more common email programs:
America OnLine (AOL) (3.0I)
In the Email menu choose Compose Email (Ctrl+E):
At any time while you write and address your email you can click on the Attach icon on the left of the window - this then lets you select the files to be sent.
Compuserve (CIS) (4.0)
In the Compuserve program choose "Create New Mail" from the Mail menu:
During writing and addressing your mail message you can click on the button "Attach File:" - this lets you browse your computer to select the scans to be sent. To make finding the files easier, change the "Files of type" setting to "Graphics Files". Once the files are selected Compuserve shows a second window of encoding options - the default (Binary) will be suitable for almost all emails.
Microsoft Outlook Express
Outlook Express is one of the most common Internet mail clients, and is included with many Windows 98 systems and on ISP disks - this basic mail program also lets you attach files to your emails. Click on the Compose Message button:
While writing your email message you can click on the paper clip icon (shown above) or choose "File Attachment..." from the Insert menu.
Netscape Mail / Netscape Messenger (Communicator 4.6)
The most recent version of Netscape Mail can be linked to PageManager or the VistaScan driver, however many users want to attach scans in the normal way - click the New Msg button to open a Composition window:
While writing your email message click on the Attach button and choose File... - locate and select your scans.
Jul 09, 2008 | HP PSC 1610 All-In-One InkJet Printer
42 people viewed this question
jasbo
jasbo
