Question about Freezers
Manual for Zero chest freezer gas/electric - Freezers
Why my chest freezer run but can not freeze?
It probably has a gas leak and needs more refrigerant gas. Or is could be a faulty thermostat, or a failed compressor. You need a service engineer to look at it. They have the gauges, the gas and the knowhow.
Apr 17, 2016 | Freezers
We have a Frigidaire Model FFC25C8CWO 25cf commercial freezer chest. The alarm keeps going off. The temp is below zero and we can't get it to get warmer. What can I do? Is it to cold is this why the
Hello Judy, thanks for your post!
From my understanding the alarm on your Frigidaire commercial chest freezer continues to go off. You have explained that the temperature is at zero degrees. It sounds like you could have a potential issue with your thermostat or sensor. I would recommend having a professional technician come out to properly diagnosis your freezer to avoid any unnecessary part purchases. Good luck. -Matt
Dec 14, 2014 | Frigidaire Freezers
How to fix a chest freezer by kenmore
The clicking is the compressor trying to start. Probably a better bet to replace rather than try to repair with new compressor and electrics, drier and gas.
Jul 03, 2012 | Kenmore 5 cu. ft. / 142 liter Chest...
My GE chest freezer stop freezing. the light is on no sounds from the freezer. what could be the problem?
There are many reasons why is not working. 1.if the compressor is not running, Relay or overload burn, they are attached to the side of the compressor 2, thermostat may not be working. 3. if all of the part i mentioned are working fine your compressor may need to be replace.4 if the compressor runs but still don't get cool, there is a internal gas leak inside the freezer. The only way to find out theses issues, is by having the necessary tools and experience.
Jan 17, 2011 | General Electric Chest Freezer FCM7SU
Is there an ambient temperature range outside of which the freezer won't work well? Will it go down to zero degrees?
It seem ambient temperature will not affect so much inside temperature since any freezer has good insulation. Normally freezer will go down to below zero degree
Oct 10, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
Unit runs continually with gurgling sounds
defrost fully once a year or more if you notice it frosting should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
Feb 17, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
Can a chest freezer be used in an unheated garage where the temeprature falls below freezing for an extended period? The garage is insulated so it doesn't get as cold as outdoors but it does drop below...
why not then when its down to zero shut the unit off and open the lid and free electricity required....remember pop machines sit out in all types of weather
Sep 15, 2009 | Kenmore 5 cu. ft. / 142 liter Chest...
Kenmore Deep Chest Freezer
Correct temperature for residential freezer for food is zero degrees Fahrenheit
Jun 07, 2009 | Kenmore Freezers
General electric 5.0 chest freezer has water coming all over the floor.
The reason this happens is because the defrost timer is not turning back on when it needs to, causing the freezer to thou out and overfill the drip tray sitting on top of the compressor. A new defrost timer should be available from the local refrigeration wholesalers in your area.
May 11, 2009 | General Electric Chest Freezer FCM5SU
Freezers Logo
139 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
