Question about Mitsubishi WS-65511 65" Rear Projection Television
Mitsubishi WS65511 Rear Proj. TV still have resetting problem after DM caps & conv. IC replacement. Any other ideas or tests to do ? Any TV old timers that remember how to diagnose boards ?
My Mistubishi WS 65511 Rear Projection TV runs fine for 15 minutes, Then kicks off & has the blinking green light while it resets. You can turn it on again & get another 15 minutes. Over & over, Then it may work fine for 6 hours or more. Seems to be worse when cold. And the problem has been more frequent with months. So I replaced the 7 Elec. Caps on the DM board. They weren't bulging & looked fine, But I put in 7 new ones. Did not improve at all. Same problem, Same time, 15 minutes. While in there I looked at everything. Nothing bulging, burn't, or visual. Something is going bad & causing a over load that triggers a shut down & reset. Any Help or Ideas PLEASE ! Any possible parts that I can try that might have done the same for you. I can solder in parts, But don't know what to try with it being so erratic. Also, does anyone have a service manual with wiring diagram. OR should I just try buying used boards off EBAY & try replacements. I really want to keep this monster in the living room. I've grown accustomed to her face. And the wife likes to pile nick-nacks on top. There should be lots of these replaced with flat screens by now. When it works, The picture is perfect, sometimes all day long.
2 Suggested Answers
claudeinmo
  • 9098 Answers
SOURCE: TV keeps turning off & resetting every 15 minutes & up to 10 hours. When it is running the picture is PERFECT & BEAUTIFUL ! Can anyone tell me where to start after the DM Elec. caps ?
WHY DOES IT KEEP TURNING OFF - Fixya
www.asksbook.com/support/t24227796-keep_turning_off
Apr 24, 2014 - These, like most newer tvs have self-checks that shut the tv off if the fault could .... Mitsubishi WS-65511 65" Rear Projection Television Logo ...
[PDF]871D3547B10 (V21 OG) 52 through end.indd - Mitsubishi
https://www.mitsubishi-tv.com/asset/file/owners_guide/WS-55511.pdf
Projection Television Models ... WS-65511 WS-65611 WS-65711 WS-65712 ... which can be determined by turning the equipment off and on, the user is encouraged ...same stationary images on the screen for more than 15% of your total TV
Posted on Jan 19, 2016
My tv is a mitsubishi model ws65511 our power went out when it come on tv wont work just flashes green reset wont help
thats caused by failed DM caps which discharge during power outage and then cannot be recharged when power is restored. the mitsubishi repair kit called the WS48511 - WS65511 DM repair kit available from www.tvrepairworld.com should solve the issue it has the replacement capacitors and the CD with repair instructions.
Jun 02, 2012 | Mitsubishi Televison & Video
I have a mitsubishi rear projection tv model ws65511. When i turned it on this morning all the timer light started to blink green. I tried to reset and it still blinks. unplugged and plugged back in and...
that's a very common problem for that model which is almost always caused by bad DM capacitors. Replacing them should solve the issue. You can get the Mitsubishi repair kit called the WS45511- WS65511 DM repair kit from www.tvrepairworld.com which has the caps and the CD with detailed repair instructions.
Oct 04, 2011 | Mitsubishi WS-55805 55" Rear Projection...
Power in house was shut off today, when restored, the timer led light by the power switch has been blinking constantly and the power to the TV will not come on...
Thats a common issue for that model which is caused by weak DM capacitors. When the power is down the caps discharge then they cannot recharge when power is restored and the led blinks non stop. Thw WS48511 - WS65511 DM repair kit from www.tvrepairworld.com has the caps and the repair instructions which usually solve that issue.
Aug 04, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Green light on front of TV keeps blinking after power outage. I have tried powering back off and on and resetting the tv. Nothing works
Thats caused by weak DM capacitors when power is lost even for a minute the caps drain and then cannot charge again when power is restored so the led will blink non stop. The Repair kit called the WS48511 - WS65511 DM repair kit should solve the issue. The kit contains the caps and the cd with repair instructions. The kits available from www.tvrepairworld.com
Aug 02, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The power wet off and now the timer green light is flashing and it wont turn on model # ws 55511
Thats caused by the 7 capacitors on the DM power board. They discharge when the power is lost and then cannot recharge when power is restored and the indicator light will blink non stop indicating the DM has not completed the boot sequence. Replace the DM caps. The WS48511 - WS65511 DM repair kit is the correct repair kit for your model. You can get the repair kit from www.tvrepairworld.com
Jul 08, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Green timer light justs blinks and the tv will not come on
I have a Mits rear proj screen ws-55613 replced the 4 caps on the DM and still have th fast blinking green LED any Ideas?
Jan 03, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55413 timer light flashing. tv will not power on
you have some caps that have failed in the dm module
that will have to be replaced to correct the problem
if your know how to change them and have the tools the caps can be obtained through most electroinc parts suppliers
there 1000mfd 16v we increase working voltage to 35WV
if you can change them let me know and i can give you locations on the board and the dm stands on the right side of chassis at rear
Oct 24, 2009 | Mitsubishi WS-55413 55" Rear Projection...
Blinking Green Light Mitsubishi TV
the problem is in the DM module there are caps that break down and vent and cause this problem
the caps are replaceable we use a higher temp and grade cap in servicing them
but i understand a place called tv world .com sells these kits and a cd on how to if you have the tools to do this
Oct 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd-62725 rear proj green timer light will not reset
you need the V26 DLP DM repair kit at the following link. The kit contains the replacement capacitors and the cd with instructions.
http://www.tvrepairworld.com/
Jul 19, 2009 | Mitsubishi WD-62725 62" Rear Projection...
check ur dm board it could have caps as well
Dec 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
43 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
