Question about Rheem Water Heaters
Found water in the pan under bottom of my 60 gal Rheem Marathon model CMR 75245 electric hotter tank. There is no other source of water goes in the pan. Tank is only 4 yrs old. Is the tank leaking?
  • 575 Answers
Is it sitting in the pan or is it elevated over the pan? It is hard to see the leaking if it is sitting flat in the pan. Check all the connections, top and bottom. Wipe them dry and then run your hand over the connections and feel for water. Also check under the heating element covers for leaks. Good luck!
Posted on Dec 13, 2016
Rheem marathon vacuum valve
Copy following link for Rheem marathon parts and resources:
Add a comment March 2013 and describe problem in detail.
Mar 22, 2013 | Rheem MR50245 Marathon Electric Water...
How do I replace the heating elements in my Rheem water heater
Replace heating elements can be found at amazon, click here and take a look: Amazon com rheem heating element . I hope this was helpful... cheers
Jan 31, 2013 | Rheem 82V40-2 Fury Electric Residential...
Rheem Marathon Water Heater leak at pressure relief valve
Unless you are getting more than 150 PSI, you should just replace the valve. It has dirt in it.
Dec 27, 2012 | Rheem MSR50245 Marathon Electric Water...
Rheem marathon tripping breaker
Turn power off. Open covers and inspect for burned parts.
Test elements. Marathon takes specific element, and does not use generic element from hardware store.
Oct 27, 2012 | Rheem MSR50245 Marathon Electric Water...
How do I turn up the water temperature on a Marathon 85 gallon electric water heater? I don't see any visible temperature control settings.
The temperature is controlled on the thermostats in the tank. They are under the two covers you see on the outside of the tank. There is an upper and lower thermostat. Make sure you shut off the power before you begin. Remove the cover and peel back the insulation covering the thermostat. Use a flat head screwdriver to adjust temp. There should be a pointer showing the temp its on now. They are probably set at 120 degrees. WARNING--turning your hot water temp above this point can cause scalding and burning in less than 3 seconds. You may have a burnt out lower element. This link below should help you
This is the manual to your tank. Good luck.
Apr 23, 2011 | Rheem MSR50245 Marathon Electric Water...
How do you set tempature to make the water stay hotter longer? I have a Rheem 82v66 2 (65 gal) and cant fill my bath tub with out running out of hot water.
65 gallon water heater should fill more than 1 bathtub since typical bath only uses 12-14 gallons hot water. First hour delivery on your tank should be greater than 60 gallons.
Since you have such a small amount of hot water, it sounds like bottom element is burned out, or one of the thermostats is bad. There are two thermostats, and two 4500 Watt elements on 65 gallon tank.
If upper element was burned out, or water heater was not getting 240V electricity, then you would have NO hot water. So we know upper element is good and circuit is good.
Ordinary tank-type electric water heater is fully repairable by homeowner and parts are available at hardware or home center.
I suggest taking 30 minutes and doing troubleshoot before replacing any parts.
Buy cheap multimeter from home center.
When testing voltage, rotate multimeter dial to 240-250-277 VAC
When testing elements or continuity, rotate dial to Ohms.
Add a comment for more free help. I can answer questions as you fix the water heater.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on heater.
Jan 11, 2011 | Rheem 65 GAL ELEC Water Heater 6YR Self...
Just installed new marathon water heater and hae
check the water control valve to see if it is fully opened
Mar 07, 2010 | Water Rheem MR40245 Marathon Electric ...
There is no hot water
Do you know were your hot water tank is?
How old is your hot water tank?
Is it a gas or electric hot water tank?
Aug 15, 2009 | Water Rheem MR40245 Marathon Electric ...
Water Heaters Logo
Top Rheem Water Heaters Experts
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
