Question about Refrigerators
3 in 1 what wires do i hook to 3 in 1 power for refrigator
    Novelist:
    Habit-Forming:
  • 112 Answers
Look for wire diagram on back of refrigerator. Sometimes it shows how the wires go.
Posted on Dec 08, 2016
We have a dometic Rm3762 Rm3962 and will not work on gas or electric--shows EO
E0 means No communication between display and power modules.
The control system will revert to full automatic operation selecting the best energy source available with AC,
GAS priority. The temperature setting will be maintained at the mid positions. The power module will continually
attempt to reestablish operation of the display module.
I can tell you how to find the problem , but , it is a little work .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and , when to cycle off due to temp satisfied
Apr 20, 2012 | Refrigerators
I have a new water heater, and the hook up terminals are labled 1-2-3 are they hooked the same as in the panel 1-2-3 ?
No. You have to find out if you have 3 phase or single phase power. If this is a new unit you will find a wiring diagram inside the front cover. 3 phase power has 3 "hot" wires. Single phase has 2 "hot" wires. There is a big difference when you hook it up wrong. I don't know if this is a new installation or if you are replacing an old one. The terminals are numbered for 3 phase. If you look in your breaker box, 3 phase 208 will haven a breaker with 3 spaces hooked together by one bar. Single phase will have two spaces hooked together by a bar. So if the breaker kicks out it will flip all 3 space on 3 phase or 2 spaces on single phase. If you already have wires to the location of the booster heater, you may have to use single phase if that is all that is at that location. If you have single phase power you will have to look at the wiring diagram and you will see the terminal block represented for both single and 3 phase. Normally running from the terminal block will be six wires marked 1 through 6. The wireing diagram will say something like "for single phase put 1,3,5 on terminal 1 and 2,4,6 on terminal 3. Leave terminal 2 out all together. Of course at this point your 2 hot wires will go to terminal 1 and 3. There are other considerations as well. With 3 phase the circuit wires will be smaller gauge and may not carry the current you need for single phase. This is a booster heater. You need to hook up your hot water line to go into the heater and the boosted hot water to your appliance. It will not work to heat your water for other purposes. It is meant to take 140 degree water and boost it to 190 degrees. Good luck, hope this helps
Sep 11, 2010 | Hatco Corporation Compact Electric Booster...
Freezer defrosted completely. fridge is barely cool. fridge is running though. dont hear condenser though
The compressor relay is bad on the main control board . Unplug the refrig and pull the refrig out and remove the 8X10 small panel on the back . You will see a blue plug with 3 larger (120v) wires going to it . Remove this plug . Looking at the plug , you will see : wire1 , wire2 , space , wire3 . (this is on the plug NOT the board ) . Using a short piece of insulated wire , with about 1/4" stripped off both ends , insert 1 end into wire1 and the other into wire3 . Plug the refrig back in . This will start the compressor to verify the main control board is bad . Pt # WR55X10942 .
Aug 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
On my GE refrigerator is not getting cold at all in the refrig nor the freezer. When I open the door the light is on and the fan is running. Is there an enteral fuise?
Aug 19, 2010 | GE PSS25SGNBS Side by Side Refrigerator
Do not know cubic size. It is a side by side approx 10 years. Motor is running but coil is freezing up in freezer, refrig side is not cooling. Evaporator fan not running so changed evaprorator motor. Fan...
The problem is still from the fan, try to settle down and try to connect the wire properly. if the wire is fix properly fan will work and refrigerator will also work.
Goodluck
Jun 28, 2010 | Amana SXD524VW Side by Side Refrigerator
Ice build up in back freezer wall & refrig on reg side is not cold enough
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board ( you already know , since you changed it ) . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off .
Jan 19, 2010 | GE Refrigerators
My GE side by side Model # GSS20IEPA has frost on
Is the fan in the freezer working ? May have to press the light switch in to test . If not , main control board is probably bad . not the fan moter . Pull refrigerator out and remove the small 10"X13" metal cover . Unplug refrig first . Then remove the blue plug with 3 wires attached to it . The wire sequence on the plug looks like this : wire 1,wire 2,space wire 3.
Use an insulated jumper wire with both ends stripped and insert one end into wire 2 and the other into wire 3 . Plug refrig back in and look in freezer at the bottom . If the heater and defrost thermostat are good , the a red glow should appear . No red glow , either bimetal or heater is bad . Most likely heater pt# WR51X10101 . Do not forget to reinstall the blue plug with refrig unplugged or could cause main board dammage .
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Breaker that powers my sub-zero side by side keeps popping off
The refrige has a name plate what is the rated amps for the refrige and what size breaker u have for it. How far is the refrig from the breaker panel. If you give me more info i can help with this. I can only suggest now or guess 1.) Breaker is bad 2.) Compressor motor is starting to fail. With an A.C Ammeter right at the breaker panel go to the breaker that supplies power to your refrig and measure how much amps it is using and compare it to the name plate specifications
Jul 23, 2009 | Sub-Zero 685/S Stainless Steel Side by...
Dometic refrig,curcuit boards
thats normally a problem of either parts wear and tear or spiking in the the AC line ... if something like a water pump or something that turns on and then off suddenly is on the same line as the refridgerator it can cause such a problem also if the wires in the wall outlet or panel box have begun to run slack it can cause such problems as well ....
May 19, 2009 | Dometic NDR 1062 Refrigerator
Refrigator compressor motor
No fuse. Check for retracted pins in molex connectors in back. See if any pins are sticking up farther than others on side of plug where wires enter. If so unplug connector and push wire in. Re-connect and recheck. Also have seen this in connector in console on left ceiling of refig. section.
Nov 15, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
