Question about Dryers
3 in 1 what wires do i hook to 3 in 1 power - Dryers
  • Dryers Master
  • 5,323 Answers
IT SHOULD HAVE COME WITH INSTRUCTIONS? YOU USUALLY HAVE 1 POWER AND THE OTHER 2 ARE THE RUN CAPICITOR AND THE START WINDING? WHICH ARE COLOR CORDINATED
3 in 1 what wires do i hook to 3 in 1 power - 26388878-bszy215dbxllk1sw2ym4qmfg-4-5.jpg
<3 in 1 what wires do i hook to 3 in 1 power - 26388878-bszy215dbxllk1sw2ym4qmfg-4-14.jpg/26388878-bszy215dbxllk1sw2ym4qmfg-4-14.jpg" alt="26388878-bszy215dbxllk1sw2ym4qmfg-4-14.jpg" class="h_mi" />
Posted on Dec 08, 2016
How to hook up a 2 wire system to a 3 wire system, help!
The 3 wire is a running light/turn signal combo. On the three wire you have neutral, turn sig hot and running light hot.
If you want the two wire bullet light to be a turn sig, you will have to hook up the neutral/ ground and the turn sig hot. The running light hot will be capped.
If you want the bullet light to be both a turn sig and a running light you will have to buy an aftermarket product to regulate the power to the lights.
Apr 14, 2014 | 1993 Harley Davidson XLH Sportster 883...
Tip
Car audio hook ups
when installing a car audio sytem it is always wise to leave the power wire the last thing you hook up.ive seen many brand new amps fry because of people hooking power up to fast,if it sparks your in trouble, amps power wires should always be connect to the amp it self before connecting to the power supply. saves on amps:] And your ground should always be less then 3 feet on an amp the shorter the better!
on Jan 02, 2010 | Car Audio & Video
Replacing a relay and overload protector with a 3 n 1 hardstart
2 BLACK WIRES IS POWER. ONE GOES TO NEUTRAL, ANOTHER TO THE HOT WIRE(LINE) AND IT DOES NOT MATTER WICH YOU WILL HOOK UP AS LONG AS ONE OF THE BLACK WIRES HAS NEUTRAL, ANOTHER ONE POWER. AND BLACK IS GOING TO COMPRESSOR COMMON PIN, WHITE TO START PIN OF THE COMPRESSOR AND RED TO RUN. I HAD ON THIS REFRIGERATOR START AND RUN CAPACITORS, I ILLUMINATE THOSE - THEY CAN NOT BE IN THE CIRCUIT WITH 3 N 1 HARD START KIT. SOME COMPRESSOR HAVE THOSE CAPACITORS, SOME NOT. I DID NOT UNDERSTAND WHY THIS ONE HAD CAPACITORS IT WAS ONLY 1/3 HORSEPOWER. HOPE THIS HELP YOU.
Jan 01, 2014 | Kenmore Refrigerators
Replaced Oreck power switch. 2 black leads and 1 white lead for switch. Posts marked 1, 2, and 3. 2 black wires to switch powers on. Connect white wire and breaker trips. Where does the white wire go?
Both black go to the switch. Power in - black to switch / white to white from motor.
From motor - black to switch / white to white from power cord
The black wire from the power hooks to the off end of the switch and the black wire from the motor hooks to the on end. Third post is not used. The two white wires are connected to each other with a small twist on wire nut.
Nov 01, 2010 | Vacuums
I have a new water heater, and the hook up terminals are labled 1-2-3 are they hooked the same as in the panel 1-2-3 ?
No. You have to find out if you have 3 phase or single phase power. If this is a new unit you will find a wiring diagram inside the front cover. 3 phase power has 3 "hot" wires. Single phase has 2 "hot" wires. There is a big difference when you hook it up wrong. I don't know if this is a new installation or if you are replacing an old one. The terminals are numbered for 3 phase. If you look in your breaker box, 3 phase 208 will haven a breaker with 3 spaces hooked together by one bar. Single phase will have two spaces hooked together by a bar. So if the breaker kicks out it will flip all 3 space on 3 phase or 2 spaces on single phase. If you already have wires to the location of the booster heater, you may have to use single phase if that is all that is at that location. If you have single phase power you will have to look at the wiring diagram and you will see the terminal block represented for both single and 3 phase. Normally running from the terminal block will be six wires marked 1 through 6. The wireing diagram will say something like "for single phase put 1,3,5 on terminal 1 and 2,4,6 on terminal 3. Leave terminal 2 out all together. Of course at this point your 2 hot wires will go to terminal 1 and 3. There are other considerations as well. With 3 phase the circuit wires will be smaller gauge and may not carry the current you need for single phase. This is a booster heater. You need to hook up your hot water line to go into the heater and the boosted hot water to your appliance. It will not work to heat your water for other purposes. It is meant to take 140 degree water and boost it to 190 degrees. Good luck, hope this helps
Sep 11, 2010 | Hatco Corporation Compact Electric Booster...
Kenmore dishwasher power cord.
The green is the ground wire. Attach it to the screw inside the junction box.
Feb 20, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Attaching Power Cable
The two outside wires of the flat power cable are the power wires. The middle wire is neutral or ground.
Hook one of the red outside wires to the red, the other to the black, and the center one to white.
Feb 13, 2009 | GE Dryers
Where do you connect the blue wire
Next time don't lose the instructions.....
Black is your answer...
If just simply hooking the blue and black together with the black from the switch/power supply does not work you need to replace the wire going to the fan with a 12/3 wire(white,black,red,ground) along with a switch, what you have now is a 12/2(white,black,ground)
Here is the following way it should be hooked up using 12/3 romex to the fan from wall switch.
White,Black, ground power supply
Make sure 12/3 is fed to the fan location.
From the power you Y off the black to the red with a piece of red wire to the switch.
Then from the switch is red wire.
Then at the fan red connects to blue, black connects to black, white to white, and ground to ground.
Nov 15, 2008 | Hampton Bay 24750 Huntington III Ceiling...
New cd player made in china
The yellow wire does not get used unless you have a power antenna to hook it to. The red wire is suppose to be hooked to the wire that was used as power for the stock stereo, so it turns on and off with the key. If you have it hooked to constant power, it has power coming to it even when it's turned off. That and the fact that you may need a better ground is most likely the reason you're getting the moise even when turned off. You may also want to check your speaker connections.
Oct 08, 2008 | 1993 Ford Explorer Limited
Dryers Logo
32 people viewed this question
Top Dryers Experts
