Question about Epson Office Equipment & Supplies
I have an Epson WF-4630 that is acting up, I suspect dud firmware. Does anybody else have the same problem, starting last few days. Is there is a key combo to force a factory reset at startup? Thanks!
Printer is turning on - does all the normal things and then waits a while and resarts on its own. It can be seen by the PC, but nothing will print in the ten seconds it stays on. looks like dud firmware release over last few days. Cannot find info on any startup keys that could be used.
  • 43 Answers
SOURCE: Prints gobble-de-gook
try another USB port
Posted on Jan 23, 2008
SOURCE: DP-1820E shutdown the Print Spooler's Windows Service
I had the same problem so went to http://www.bayshoreoffice.com/drivers/#DP-1820E and downloaded the relevant driver. I needed the vista one. As suggested above just replace the old one with the new one. The zip file I downloaded also had instructions on how to do that.
Posted on Jun 27, 2008
SOURCE: Samsung ML2551N: Initialization problem on startup
Replace all electrolytic capacitors in power supply section on mainboard. caused by poor quality lower voltage caps being used in powersupply. Problem will reoccur every 2 to 3 years if 105oC caps are not used. If mainboard is replaced with new mainboard problem will reoccur within same timeframe. Fix old mainboard using higher voltage and higher temp caps and problem will be gone for good.
Posted on Jan 06, 2009
TechiFriend
  • 11 Answers
SOURCE: The printer is taking to long to print....
1) may be your print spooler is full
to set it right kindly do this:
click start and then go to run type cmd.in vist asearch for command prompt.
Opens a Command Prompt window is open.
key the command
sc config spooler depend= RPCSS
note :THIS COMAND IS CASE SENSITIVE so type it exactly as shown and there is a space between rpcss and the = and there is no space between depend and =
restart your computer
open a Command Prompt window again.key the commands
net start spooler
note this command is also case sensitive.
__________________
thsi should resolve ur issue
if this does not kindly upgrade the ram of your computer.
that means u ned to buy more memory for ur computer.
it was supporting printer earlier but after printer has started working its getting more load thts why prnter now isslow.
its like a small kid inicilly may like the school but after few days kid gets burdon n gets slow n less excited.
if u have HP printer
u can also visit
http://welcome.hp.com/country/us/en/support.html
although i hav worked as tech support fr 2 years for DELL and 1 year for HP all in one printers. i am sure my steps will help u
rate me 100% when u issue gets fixed ;)
Posted on May 17, 2009
SOURCE: EPSON PRINT MONITOR pops up on startup!
Hello I think I might have a way to solve this problem. I had a similar issue, and it was caused by having a file in the print queue that would not print.
Open Print and Fax Preference, then open the Print Queue button. Highlight any files in the queue and delete them.
Hope this works for you
Posted on Aug 12, 2009
Resetting factory settings on my epson wf 4630. forgot passwords
When you reset to the factory settings means it will be exactly as it was when you bought it. No programs and no documents. It is starting over from scratch and is really a big headache. Always make backups so you can restore the information you need, but you will also need all the original software programs so everything can be reinstalled. BIG JOB!
Aug 20, 2017 | Epson Office Equipment & Supplies
How to fix fuzzy lines on epson wf-4630 printer?
Go to menu on the printer and select "Maintenance" and print "nozzle test pattern".
Clean the printheads by going into menu again and select maintenance and then "cleaning"
Print nozzle test and see if page looks better.
Picture for example of bad and good nozzle test:
May 20, 2017 | Epson Office Equipment & Supplies
Ho do you reset the ink levels on an Epson WF-4630 (T7861)?
Ink levels are set by chips on the ink carts. You may be able to reset the chips with a "chip resetter", but that's not really recommended. Get refillable carts with automatic resetting chips...
Dec 08, 2016 | Epson WorkForce WF-4630 Wireless Color...
Epson WF-2530 keeps restarting.
I have the same thing. I suspect they have released a messed up Firmware :-(
I am trying to find a key combination at startup to see if that does something, the printer is otherwise completely unresponsive.
Dec 07, 2016 | Epson WorkForce WF-2530
Epson Wf-4630 keeps jamming when i use the ADF to scan documents
It may be due to the corner of the paper is bend or not exactly parallel.
Nov 04, 2016 | Epson WorkForce WF-4630 Wireless Color...
MY EPSON WF-4630 PRINTER IS STUCK ON oxf4 AND WE CAN'T CLEAR IT. WHAT DO WE DO??
If you are lucky, the 0xF4 error indicates a foreign object (a scrap of paper) in the gears. That would translate to PF driver mechanism overload. Another cause would be a contaminated encoder scale. Fixing either of these will require you to disassemble the printer. Here are some tips for taking apart the printer: https://www.ifixit.com/Guide/Repairing+EPSON+B-510DN+Error+0xF2+or+0xF3/11767 .
However, the 0xF4 error could mean that the encoder board or the motor have failed. These errors can only be fixed by a service technician. If your printer is under warranty, you should call for service. Otherwise decide if you want to risk taking it apart and finding that you can't fix this error. It may be cheaper to replace the unit.
I hope this helps.
Jun 20, 2016 | Epson WorkForce WF-4630 Wireless Color...
How to resolve error 0x97 on Epson WF-3640?
Error code number 0x97 is most common error in Epson printer, well there is lots of way to get rid of this issue i suggest you to watch this video n get rid of this error hopefully it will work
Jul 03, 2015 | Epson WorkForce WF-3640 Wireless Color...
Why is my wf-4630 not recognizing initial cartridges?
if they are not epson original cartridges,they wont work,you cant refill or by refilled cartridges to use in this printer,if buying used cartridges,you have to be able to reset the printer,some cartridges reset the printer but most dont
Aug 07, 2014 | Epson Office Equipment & Supplies
26 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
