Question about Cameras
How to plug a recharge on my camera--do not have direction help me someone
  • kakima Dec 07, 2016
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model camera?
Why doesn't lantern turn on when not plugged in?
I have a rechargeable spotlight and the directions specifically say not to turn it on while connected to the charger.
Mar 10, 2016 | Coleman Cpx 6 Rechargeable Power Cartridge...
Recharging a lithium ion battery
You can buy a power converter on Amazon that plugs directly into the wall and then the usb plug goes into it.
http://www.amazon.com/s/ref=nb_sb_ss_c_0_9?url=search-alias%3Delectronics&field-keywords=ac%20to%20usb%20adapter&sprefix=ac+to+usb%2Caps%2C255
You can probably also buy them at any electronic store.
Mar 17, 2014 | Cameras
I got problem with my Canon powershot sx100 IS camera. It is giving only 4-15 pics with new alkaline batteries after that LCD screen will become dark on the screen change batteries message will appear. can...
You can use rechargable cells with high current( mA) rating. So try and use any rechargeble cells with above 2000mA . Also you can use a rechargeable adapter externally to charge these cells.
Aug 17, 2011 | Canon PowerShot SX100 IS Digital Camera
My ipod won't charge. keeps saying "please wait. very low battery" what's wrong with it?
I had the same problem. Went to the Apple store and the technician said that the IPOD battery ran down to low (battery level showed red) and the USB port on the computer was not strong enough to recharge it. He used a rechargeable adapter that pluged directly into the wall (adapter cost about $30) and recharged it enough for me to take it home and recharge it on my computer.He said to never let the battery level drop below 5% unless you are going to recharge it using the adapter that pluged into the wall. I bought an IPOD rechargeable travel kit from Target for $20 and used it to recharge my IPOD. My IPOD works fine now. The Technician also said at some point the battery will need to be replaced (in a year or two depends). Will cost about $59 to replace it (don't quote me on the timeframe or price of replacement, this may have been just for my IPOD but thought this would be useful info for someone.
Nov 24, 2009 | Apple iPod MA446LL/A MP3 Player
Camera won't recharge
Clean all contact points on the battery. If you are using an external charger, clean the contacts on it as well. If you are simply pluggung in a charger directly into the camera, check the plug where it attaches to the camera. It may be faulty at that point. If the plug appears okay, it may be a wire ot even transformer problem.
Sep 07, 2009 | Casio Exilim EX-S880 Digital Camera
Charge
You need a separate battery charger for this camera. It does not have a battery charger built into the camera itself and can not be recharged thru any cords connected directly to the camera. The USB cords only transfer the files to the computer, they don't recharge the camera.
Dec 30, 2008 | Sony Cyber-Shot DSC-P50 Digital Camera
Vivitar vivicam 4000 replacement battery required.
Here's one I found that works:
http://www.buy.com/prod/kodak-easyshare-rechargeable-camera-battery-lithium-ion-li-ion-photo/q/loc/33409/90130097.html
(Kodak part # 8499741)
Don't recall where I found the info that it works as a replacement, but I've been using it successfully since July 2007. Don't know yet if I'll experience the same "memory" problem I had with the original battery.
Dec 17, 2008 | Vivitar ViviCam 4000 Digital Camera
Jazz dv179
The Charger has a standard two pronged plug to go into the wall. The other end goes into the camera at the back bottom. You will see the female received for the male plug.
Dec 18, 2007 | Jazz DV-179 Digital Camera
Fuji f-401 not recharging.
There is only two possibility why the battery didn't charge.
1) cradle ( socket at camera side ) faulty.
2) the power adaptor faulty ( no dc voltage,can use volt meter to confirm ).
it worth repairing .Thks
Dec 13, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
