Question about Locks & Locksmithing
Hi, trying to install 355 deadlock, when case goes over the mounting place the hub does not engage, si deadlock and key don't turn?? Would appreciate advice cheers
pakis
  • 86 Answers
SOURCE: 1993 Isuzu Trooper auto locking hubs not engaging
Just have your auto - locking hub cleaned and use your 4wd more often, it get stock usually for non usage. dont use grease after cleaning, use oil or thick silicone oil.
Posted on Dec 05, 2008
  • 26 Answers
SOURCE: 96 f150 4x4 5.0L 4wd is not engaging
is it push button if it is make sure the relays are working if they are working make sure you are getting power to the servos in the transfer case
Posted on Nov 23, 2009
  • 85 Answers
SOURCE: have a 1993 f150 4x4 transfer case sounds like its
Try removing the front drive shaft from the transfer case to the front differential. With the vehicle on 4 jack stands and the front drive shaft removed attempt to place the vehicle into 4 WD. You may have to start the engine if the vehicle uses a vacuum actuator module to engage the front wheels. When you get an indication that the vehicle is in 4WD try turning the front wheels by hand and see it you hear the same grinding noise .... engage the hubs and try again. Usually if the transfer case is ok then the problem is in the front differential or one of the many universal joints that connect all of the elements together. Check the U joints on the front drive shaft for play as well as the U joints on each of the front wheels.
Posted on Dec 04, 2009
SOURCE: volkswagen t5 caravelle central locking not working deadlocks on!
Turns out the problem was a broken wire at a junction below the carpet below the drivers seat. Took my mechanic 4.5 hours to fix it nightmare had to take seat out handbrake lever etc to get to it!!
Posted on Jan 21, 2010
  • 1949 Answers
SOURCE: I have a 1989 F150,
repair or replace transfer case it sounds to me.hope this helps
Posted on Nov 14, 2010
Buna vreau si eu un cod dblocare nokia c7-00
hi pute?i ob?ine codurile de pe acest site prounlocking aici, pe care le presteaz? codul de deblocare pentru toate modelele de telefonie mobil? GSM, ?mpreun? cu instruc?iuni despre modul de utilizare a codurile din telefonul mobil.
Oct 23, 2011 | Nokia C7 (8 GB) Smartphone
Warn hubs, installation
Warn Hubs Installation
A truck or SUV with a four-wheel drive suspension uses locking hubs on the front wheels to engage or disengage the front axle shafts from the hubs. This way, you can drive the truck normally with just rear-wheel drive, or engage four-wheel drive mode when you want to drive off-road. These hubs can wear out, and one improvement is to install a set of Warn hubs. Installing a set of Warn hubs takes about an hour.
1.Park the truck and put on the parking brake. Lift the front of the truck with the jack and put the jack stands under the front axle. Take off the front wheels with the tire iron and put them to the side.
2.Disengage the locking hubs using your hands by turning the knob on the hubs. Remove the snap rings holding the hub locks in place with the snap-ring pliers. Pull the hub off the axle.
3.Install the lock ring wheel from the Warn hub kit in the axle with the factory snap ring and the snap-ring pliers.
4.Make sure the Warn locking cap dial is turned to the "Free' position. Install the locking cap onto the lock ring wheel and hub body with a hex-head key. Reinstall the front wheels with the tire iron and lower the vehicle off the jack stands with the jack.
Thank you for using FixYa. Hope this will help your problem and don't forget to rate me.thanks,
Reymond
Oct 18, 2011 | Cars & Trucks
Buna ziua am si eu un tel nokia X3-02 si nu merge, cind bag o cartela in el imi spune (enter restriction code) ma-m tot uitat pe net si nu ii gasesc un cod de deblocare, tel la-m primit. este adus din...
Bun? ?nseamn? c? telefonul mobil este blocat la re?ea, ave?i posibilitatea s? debloca?i telefonul mobil prin coduri debloca .. mod sigur cea mai buna si de deblocare este de coduri debloca ?i cererea mea personal? este c? nu merg pentru programul de deblocare, deoarece, uneori, software-ul s-ar putea ob?ine corupt ?i poate datele dumneavoastr? vor fi pierdute din cauza c? ?i, de asemenea, dont du-te pentru deblocarea gratuit, deoarece codul generat de circula?ie pot merge gre?it uneori, sa-mi experien?? nepl?cut?, a?a c? am mers pentru deblocarea de codurile din superunlockcodes ?i unlocked.you pot ?ncerca prea dar se vedea ?n acest dac? ?ara dumneavoastr? ?i furnizorul este listat .. deoarece pentru unele servicii sunt disponibile numai coduri .. verifica cu faptul c? ?i ?n cazul ?n care furnizorul de ?ara dumneavoastr? este listat, apoi ob?ine coduri ?i de a debloca telefonul mobil ..
Sep 21, 2011 | NokiaFree Unlock Codes Calculator
My 2004 f150 does not always work in 4 wheel drive but I replaced a vacuum line that goes to the front acuator on the front axel, then i replaced the right front hub assembly with a used one and the 4...
The IWE is operated by a common vacuum system. When you say does not work, not sure what you are getting at ( only 1 wheel locks into place, or neither ).
Could be you had the vent and vacuum lines reversed, and this did not keep the IWE gear pulled out and it rounded off on the one you did not replace.
Is the issue the front axle does not lock in, or does the drive shaft not lock in at the transfer case ?
Lift and support the front of the truck so the front wheels are off the ground ( take safety precautions, chock wheels, jack stands, etc )
Key on, engage 4x4 and try to turn the front drive shaft.
If it turns it is a problem with the transfer case.
If it doesn't it is a front axle engagement problem.
When you get to this point, post back a comment to this problem with the info.
Nov 10, 2010 | 2004 Ford F150
I have a 2000 4wd tacoma with manual locking hubs and the 4wd does not seem to be engaging after locking the hubs and shifting the lever into 4 hi or 4 low
Sounds like one of your hubs is sticking and not engaging. You can check them by engaging the hubs and the transfer case and jacking up each front wheel independently if it doesn't spin your good, if it does you found your problem. As far as fixing a hub goes, it may be just dry and need some grease, or there are some very good aftermarket hubs available from Warn.
Hope this helps
Dec 08, 2009 | 2001 Toyota Tacoma
Have a 1993 f150 4x4 transfer case sounds like its engaging but there is a grinding noise when she goes in 4x4 only checked transfer case its fine could the hubs be gone over the summer with out use.
Dec 04, 2009 | 2000 Ford Excursion
My front door has a Roto R627 lock. I can't get
If the deadlock moves a little bit, The deadbolt may not be lining up with the hole. Put some lipstick on the deadbolt tongue and try to turn it. Then check where it is hitting the frame. You might have to just tighten up the hinges to shift the door position.
Jul 03, 2009 | Locks & Locksmithing
Deadlocked S80. Seats don't fold down. Keys in
hi there i presumed as you have told us that the back seats don't fold down that you have access to the inside of the car, if this is the case you could remove the backrest of the back seat and fish for the keys throw the holes in the back panel. regard John
May 16, 2009 | 1999 Volvo S80
Warn manual hub install 2000 f-250
THE KNOB ON THE DASH ENGAGES THE TRANSFER CASE, WHICH TURN THE AXLES. THE MANUAL HUBS LOCK THE WHEELS TO THE AXLES.
DCL
Nov 29, 2008 | 1995 Ford F250
Locks & Locksmithing Logo
130 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
