Question about Cell Phones
Can not access salestrak in order to get to webmail also need help on adding my auto signature. In tells me in webmail, select options in lower left corner of screen.
SOURCE: Touchpad going crazy...
pritamkoo7, do U have a Dell computer? I do and there is no easy solution - just type Dell touchpad problems in Google and see all the problems that people are having with all makes and models. I am extremely upset with Dell over this because some of these complaints date back to 2004 and they STILL haven't corrected it yet. Haven't found a solution yet - my cursor takes "trips" on it's own and the left button sometimes will not click - or acknowledge that it is being clicked - and I have found that clicking the right button and then clicking the left button again gets it working; temperarily. I need answers also.
Posted on Jun 17, 2008
marked
  • 6487 Answers
SOURCE: unlock apex tv model # AT2702
  • If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
  • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
  • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
Hope that helps..........
Posted on Jul 20, 2008
SOURCE: Fifa 09 (Wii) problem adding second controller
First, make sure the Wii Remote is connected if not press home, wii remote settings then reconnect and the reconnect all wii remotes.
Posted on Jan 09, 2009
  • 27 Answers
SOURCE: help with auto signature
Go to the text message settings and go to signature and apply it or type it then it should work!!
Posted on Nov 13, 2009
  • 8 Answers
SOURCE: I recently purchased my MP4 player but I am having
1. Set the correct date and the Mid Button is the OK the center orange.
2. Volume is only changeable in the Music or Vidoe Player
3. to calibrate just press with your stylus on the center of the box with the cross lightly ( it calibrates the sensetivitys )
Posted on Nov 26, 2009
How do i put a signature on a pantech link
Text message signatures are the post scripts at the end of text messages. Some people use text message signatures to provide an unrelated, off-top status update to the recipients of their text messages. Other people use text message signatures to attach a favorite quote with every outgoing message. If you own Pantech's Link handset, you use the device's messaging templates to attach a signature to your text messages.
steps:
  • Press the right "-" button to access the Link's menu. Use the handset's directional pad to navigate to "Messaging" option in the menu. Press the center of the directional pad, the "OK" button, to select the "Messaging" option.
  • 2
    Select the "Templates" option from the "Messaging" menu, using the directional keypad. Select "Options" from the "Templates" menu, using the left "-" button and then select "Add New."
  • 3
    Key in your text message signature using the Link's QWERTY keypad. Select "Options" with the left "-" and then select "Save" from the "Options" menu.
  • 4
    Press the red "End" button to exit the "Templates" menu. Press the right "-" button to return to the Link's main menu. Select the "Messaging" option from the menu.
  • 5
    Select the "Create Message" option in the "Messaging" menu. Compose your message with the Link's QWERTY keypad.
  • 6
    Select the "Insert" option before sending your text message. Select the "Templates" from the "Insert" menu. Select your text signature from the list of available templates and then select the "Send" option to transmit your text message.
  • Dec 02, 2011 | Pantech Link P7040 Black Rubber Feel Hard...
    Tip
    3 Quick Solutions to Repair Juno Webmail Script Error message
    If you have an Ad-blocker or a popup blocker installed on your computer system, you may get many script error messages while connecting with the Juno Webmail. You can prevent these mistakes from encountering by configuring the pop-blockers / ad-blockers correctly. If you're often getting a Script error message whenever try to start Juno or log into the webmail account, then you will require configuring the ad-blocker programs to operate with Juno webmail; otherwise, you may face the Juno sign in problem. There are three methods to do that:
      1.Add Juno Mail to the exclusion list of your ad-blocker
      2.Set up the ad-blocker to enable banner ads
      3.Disable the filtering feature in the ad-blocking program If you're using the AdSubtract tool, you should follow the instructions given below. In the case of any other pop-up blocking or ad-blocking software, refer to the documentation of your blocker tool for the accurate guide on configuring the software to enable ads from Juno Mail. You can get connected to the Juno webmail support experts and solve these error messages in a proper manner.
      Solution 1 - Insert the Juno Webmail to the Bypass Site list
      If you want to add the Juno website into an exclusion list, right-click anywhere on the web page and choose the 'AdSubtract: Bypass Site' option. You may require repeating this procedure on other Juno web pages on which you get the script error messages. On the other hand, speak with the Juno professionals to repair your email account issues.
      Solution 2: Configure AdSubtract to enable banner ads
      This solution will fix the script error messages that can prevent you from accessing your Juno email account, but will also cause in other banner advertisements showing on other websites you access.Here's how to setup AdSubtract software to allow banner ads.
        1.Launch the AdSubtract program and click on the 'Block' icon.
        2.Deselect the Banner Ads field from the selection on the left.
        3.Click the 'OK' button to save and apply the changes. If this workaround doesn't work and you're still getting the script error messages, then either you can get in touch with Juno customer care executives or go to the next.
        Solution 3: Disable AdSubtract tool filtering
        This workaround not only resolves the script error messages for the Juno webmail site but also causes in disabling all of the AdSubtract's filtering efficiently.
          1.Launch the AdSubtract tool.
          2.On the main dialog window, click on the 'Disable Filtering' option under the 'Ad Blocking' section.
          3.Click the 'OK' button to save and apply settings. However, if you still have any kinds of technical issues with your Juno email account, or continue to face the script error even after attempting all these solutions, or any further queries, it's highly recommended to call on the Juno webmail support phone number and ask the help to solve all Juno-related issues within a short span of time.
    Juno Customer Support Phone Number
    on Apr 11, 2017 | Miscellaneous
    How to add signature on text messages
    There isnt an exact way to add a signature at the end of the txt. In order to do so, you have to create a template with your signature, then insert the template at the end of your txt. However, know that it will count towards the 160 character limit. Instruction from the user manual (pg 38-39) below. Hope it helps!
    Message templates
    When you often use the same phrases, you can save the message under template messages. Adding the message as a template
    1. Press Menu > Messaging > Templates.
    2. Press Options > Add New.
    3. Write the frequently used message > Options > Save.
    Sending a message with template
    2. Select the message to send.
    3. Edit the message > Options > Send.
    note: You can add a template while writing message. Write a message > Options > Add Template. Choose Text or Multimedia and select the message to add.
    Mar 08, 2011 | Pantech Cell Phones
    How to paste a picture in the email content
    • Access Yahoo! Mail wit Windows Internet Explorer.
    • Select Mail Options from the navigation bar.
    • Follow the Signature link
    • If the HTML toolbar is not yet visible, click Color and Graphics.
    • Make sure View HTML Source is checked
    • Insert the image using the HTML <img> tag.
      • To place an image at the left of your signature, insert '<img hspace="5" src="http://0.tqn.com/h/gp/email.gif" align="left" width="55" height="50" />' (without the outer quotes) at the beginning, for example.
      • Make sure the image is accessible on a web server and reasonably small in proportions (not higher than about 75 pixels).
        • Uncheck View HTML Source to test your signature.
        • Click Save.
    Dec 24, 2010 | Yahoo Mail
    Add a signature in body of email
    It is possible to add a signature in body of email. Follow the below mentioned steps.
    1. Log into your Yahoo Account.
    2. Click on Options and then select Mail Options.
    3. Now on the left handside click on Signature.
    4. Select the option where it says Show a signature on all outgoing messages.
    5. Now you can create a signature and then click on save. All your outgoing messages will now have a signature by default.
    Oct 11, 2010 | Yahoo Mail
    How do you change auto signature for text messages and email messages on HTC Hero?
    From your Inbox, press the "Menu" button. Select "More" then "Settings" Select "General settings" Select "Signature" Edit your signature, then select "Save"
    Dec 02, 2009 | HTC Hero Smartphone
    Is there a spell check feature when sending e-mails? In additon, is there a way to insert an e-mail signature when using Outlook webmail on the Droid?
    i dont know about the spell check on emails. i think u can make a signature by going to outlook webmail, then going on menu, then settings, and there should be sometimeg that says signature at the top of the screen, just click on that and type in your signature, then press ok.
    Nov 10, 2009 | Google Android
    I want to attach my name and a small animation in my Yahoo email. I cannot seem to be able to do this. Thanks.
    Hi
    Open yahoo>go to the top right side of yahoo mail>click on options>select mail options and then go to the left side and select Signature.
    Mar 27, 2009 | Computers & Internet
    On the razor you cannot get an signature no matter what. I had an razor and wondered the same thing. The sms signature doesnt work.
    Tell me if this helps :)
    Nov 09, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
    How do i set my autosignature ?
    ok on cingular/at&t its not possible but there is a ghetto way of doing it go to ur quick notes and go down 4 lines then type what u would want as your autosignature then when u get done typing ur message press insert>then go to quicknotes then choose what u wanted as ur autosignature then send.
    Jan 28, 2008 | Motorola Mobility RAZR V3
    Cell Phones Logo
    26 people viewed this question
    Top Cell Phones Experts
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
