Question about Cell Phones
Phone shows offline - Cell Phones
My phone is N95.it shown the offline mode bt when i changed the profile and select the general profile after that it does not work.pls help me how i can open my phone lock..........
This is not a lock.This problem occurs when Sim card IC is damage,Sim Case damage.But one thing you can try is Clean the sim Case and Sim card.Insert the sim and switch in the phone .If the problem still persist Contact mobile repairing shop.Good luck Thanks
Jul 25, 2011 | Nokia N95 Cellular Phone
My nokia 5230 shows me am in offline mode, i need to come out of it
I think you are using the handset without sim if it is so try inserting a SIM Card and while trying to switch on phone it will opt you whether u want to continue with offline mode or not.......simply click on no and your handset will be out of offline mode
But if you have inserted the sim card and its still showing offline try going to profiles and select General mode from there....if it is changed then its superb and if not then visit your nearest service center to get the software updated for your device
Jun 19, 2011 | Nokia 5230 Cell Phone
MY NOKIA 6630 goes to offline line mode hw can i change it now
offline problem in my phone when changing another sim card
Sep 03, 2010 | Nokia 6630 Cellular Phone
My Nokia N70 dropped and since then it shows offline.
sir/ma'am,
in some other phone offline means insert sim, so u have to try to put the simcard properly then test, if the problem still, it is need to repair go to service repair center to fix the phone,
Jul 29, 2010 | Nokia N70 Cellular Phone
PHONE IN OFFLINE MODE . hOW DO YOU CHANGE IT TO on line mode
Ok let me give you solution about this problem....
Offline mode is the mode in cell phones which barred your every calls sms and even your internet connection simply you can say that...
It stops all of your connection......and you can use only those things which do not need the connection or network.
So to deactivate this offline mode their is two way
1. You can restart your phone after inserting sim card and if the sim card is in good condition and readable then the cell phone will ask you wheather to continue in offline mode?
Just press no that is upper right button of your cell phone and it will be deactivated.
2. Just press on/off button gently and it will show you profile i.e. to select mode
General, silent, meeting etc. you can select any of them except offline mode.and again it will be in normal mode.i hope that it will help you,
By: Neuron
http://www.digixtream.blogspot.in
Jun 15, 2010 | Nokia E51 Cellular Phone
Nokia n71 shows offline message. We did the hard reset, **** still it shows the same message. We tried with another card. No luck.
hi
seems the sim gate could be damaged if its not reading no sims and you get same offline message all the time
Sep 18, 2009 | Nokia N71 Cellular Phone
My N72 phone is showing in disply as OFFLINE ,
take out the sim and insert it again or reinstall the phone software.
Aug 21, 2009 | Nokia N72 Cellular Phone
6630 offline
press the side button or check the phone's user profiles, there you will need to select the phone to connect online.
you will need to set your phone to become connected
Nov 22, 2008 | Nokia 6630 Cellular Phone
N72 mobile working only in ''offline''mode.
The phone is showing Offline, hence I have inserted the sim card and switched the phone on, and choose general profile too. But it is showing Please Insert Sim Card. Please help with a solution.
Nov 22, 2008 | Nokia N72 Cellular Phone
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
