Question about Cell Phones
Galaxy gran prime phone shows is offline
Can,t used wi-fi
gomartymo
  • 20 Answers
SOURCE: could not connect to the internet using wi-fi connection
need to configure modem/router. just put ip address off modem into address bar on web browser. use admin as name and password for password. Check out portforward.com and all info will be easily found to solve problem.
Posted on Oct 26, 2009
sardanadixit
  • 813 Answers
SOURCE: I bought used touch diamond recently. But, the
Try resetting your device to factory settings, but before doing so, please take a backup of everything (contacts, messages, calender etc.)To reset the device:
1. Turn off the phone and pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
"This operation will delete all your personal data, and reset all your settings...."
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
It might take a while to start the phone and check the WiFi after the phone has restarted. In case it still has the same issue, then it might be a hardware fault.
Posted on May 10, 2010
Testimonial: "this might be hardware fault after tried"
virtualhost
  • 2185 Answers
SOURCE: My Samsung Galaxy 3 -
To be able to find out the MAC address of your Samsung Galaxy phone, please do the steps below:
1. Press the Menu button, under the display on the left hand side.
2. A menu panel appears onscreen. Press Settings.
3. The phone's Settings menu appears. Press Wireless Controls.
4. From the Wi-Fi Controls Menu, press Wi-Fi Settings.
5. Press the Menu button (to the left under the display).
6. A menu pops up onscreen. Press Advanced.
7. The 12-character MAC address is listed in this menu.
There you go, you just have to add the MAC address where required in the appropriate place in the Wi-Fi router's configuration set up.
Please let me know if this helps you. Thank you for using FixYa.
Posted on Oct 13, 2010
SOURCE: Unable to Connect to WI-FI with my Samsung Galaxy
I just had this same problem - I suspect it may have been a new app I installed that changed some settings.
I fixed mine by going into Settings>Mobile Network settings, then tick "Use packet data". Worth a try.
Posted on Dec 25, 2010
  • 326 Answers
SOURCE: I have Samsung Galaxy 5 GT-15503. Android 2.1.
Wi-fi has been known to eat up the battery life on ALL devices it's on.
That's just the way it functions.
If you really want to save battery on your phone, disable wireless, bluetooth and 4G connections you may have, dim the screen to it's lowest setting and change the display timeout to a very low time.
Posted on Mar 10, 2011
How do i get a signal on my galaxy prime core I cannot get internet
Hi Christopher, If no Wi-Fi and you're trying to connect to your home Wi-Fi The password is on the back of the modem in the house, Write it down then go into your phone and tap "SETTINGS" and tap "CONNECTIONS", Then tap on "Wi-Fi" and make sure it's switched on(should be a slide switch there), Once switched on it should start scanning automatically for networks, but if not then there's a scan button there somewhere. When it finds the modem just tap on that WiFi setting and a small window opens for the password, Type in the pass word tap "OK" and you're connected... Below is a link to a short YouTube video explaining pretty much the same thing I said..... I hope this helps..., CHEERS..
How to Connect My Phone to My Internet Using Wi Fi Wireless Keeping Up...
May 08, 2016 | Samsung Galaxy Cell Phones
Install hot spot in galaxy prime core
From the Home screen, touch Apps .Touch Settings .Touch More networks .Touch Mobile Hotspot.Touch the slider to turn Mobile Hotspot on . If you are connected to a wireless access point, you will be disconnected before you can use the hotspot. Touch OK to continue. The Wi-Fi hotspot icon is displayed at the top of your screen when the hotspot is on.
Mar 11, 2016 | Net10 Samsung Galaxy CORE Prime 4G with...
Galaxy S6 wifi issue
First, try restarting the Galaxy S6. To do that, hold the power button on the right side of the phone until prompted. Hold it down again to turn the Galaxy S6 back on. It's a simple process but it has been known to dislodge Wi-Fi issues
If that doesn't work, Galaxy S6 users will want to try rebooting the local router if that hasn't been done in awhile. We recommend unplugging the router for a good 30 seconds and then plugging it back in. Users can do the same for the modem as well. Galaxy S6 users might also consider updating the routers firmware. This process will be different depending on make and model. If those simple fixes don't work, it's time to head into the Galaxy S6's settings.
If the Galaxy S6 isn't getting a solid connection, it's time to force the device to forget the Wi-Fi network in question. To do that, head to the desired connection in Settings. On the Galaxy S6, this can be found in the Connections portion of Settings. Once there, select Wi-Fi. Tap on the desired network and select the Forgetoption. Users will then need to reconnect to the Wi-Fi network. Make sure the password is readily available or the device will be locked out.
If that doesn't work, head into Wi-Fi, tap More in the top right corner, and select Advanced. Ensure thatAlways allow scanning is turned on. You'll also want to make sure that Keep Wi-Fi on during sleep is set toAlways.
Jun 09, 2015 | Samsung Galaxy S6 SM-G920F 32GB FACTORY...
How do i find a user manual for galaxy fame phone?
I have searched for Galaxy fame manual and found a website you can download it directly from. Good Luck!
http://ee.co.uk/help/phones-and-device/samsung/samsung-galaxy-fame/samsung-galaxy-fame-user-guide-interactive-manual-and-troubleshooting/samsung-galaxy-fame---user-guide
Mar 06, 2015 | Samsung Galaxy Fame GT-S6810P Smartphone -...
How do I get the Wi-Fi signal on my pc?
I'm wondering if this is an issue with DHCP with your router.
Do you have any additional security settings enabled? MAC filtering? What kind of router do you have?
Hope this helps. Feel free to respond to this message and I'll try my best to help some more.
Sep 16, 2014 | Gateway DX Computers & Internet
When i connect my samsung galaxy express to wi-fi my computer's wi-fi stops working
Hello Ricardo.
How are You? I Guess you need to
1- Check your wi-fi router model.
2- Check your wi-fi settings.
also please check how many devices are connected to your wi-fi at same time. because some routers can only support upto 5 device. you can check this in the settings and also routers manual.
Please let me know, once you done with it.
Regards
Nov 22, 2013 | Samsung Cell Phones
How to install broadband to android tablet pc?
Share 01 Feb
2011 How to configure IP address of wi-fi connection on a Android Phone (Samsung Galaxy Tab) Posted in: Gadgets Tagged Under: Android, Galaxy, Samsung, Tab 7 Comments samsung_galaxy_tab-small-1.png
By default Androids phones (including Samsung Galaxy Tab) are set to automatically configure IP address, Gateway, Netmask and DNS address of wi-fi network.
But if you want to manually assign IP address, Gateway, Netmask and DNS address of wi-fi, here is how you can do. Method below is described for Samsung Galaxy Tab, but it will work for all Android phones.
  1. On Home screen, press Menu key.
  2. Tap Settings
  3. Tap Wireless and network.
  4. Tap Wi-Fi Settings.
  5. Press Menu key again.
  6. Tap Advanced.
  7. Enable "Use Static IP".
After you have enabled "Use Static IP", you will be able to manually assign and configure IP address, Gateway, Netmask and DNS address of wi-fi network.
Sep 23, 2011 | Android Apps
Galaxy samsung phone. He can't find wi-fi
He should read the manaul or call his cell phone provider's tech support.
If he still can't find wi-fi the wi-fi is turned off or hidden which can be corrected by the person who manages the wi-fi acces point.
I hope this helps him.
Jun 16, 2011 | Samsung Galaxy S GTI9000 Smartphone
Wifi saying unable to scan networks
Hello!
Here are the things you can try for a malfunctioing Wi-Fi on your Galaxy S:
Try turning off your Wi-Fi then turn it on again.
  • Sometimes, this works for me as the Wi-Fi might need a restart so it can try scanning again. You can do so by going to Settings > Wireless and Network > Wi-Fi Settings and ticking the Wi-Fi checkbox.
Turn off your handset then turn it on again.
  • An app that was running on your handset might be messing with your Wi-Fi, so to make all things better, you can restart your handset for a fresh boot. :)
Check if there are actually Wi-Fi networks in your area or the Wi-Fi is too weak.
  • If there aren't any Wi-Fi networks to detect, it can't do anything at all in the first place. Try moving to an area with better Wi-Fi signal.
You can ask me if you have any queries! :) ~azukibean70
Feb 23, 2011 | Samsung Galaxy S GTI9000 Smartphone
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
