Xeror 4000 erorr 061-321 what do mean? - Office Equipment & Supplies
Inside yellow
please i need how activation code xeror 7120 workcente
Jan 14, 2014 | Xerox WORKCENTER 6505DN COLOR LASER MFP,...
LSU Error xeror work centre PE220
if u can hear humming sound during warming up kindly check the wires of laser unit situated in the centre of machine just above toner cartridge but u need to open the whole machine
Jan 17, 2011 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox phaser 6180n :erorr msg 1) "motor erorr" 2) "error 042-325"
Your main drive motor is either not statting or the main board is not sensing it. You can remove the covers, WITH THE MACHINE UNPLUGGED !!!!!!!!!!!!!!!! and reset all the connectors, check the drive motor, and see if maybe a gear is broken., If the machien is less than 1 year old. Call 1-800-835-6100. You will have some kind of 1 year warranty, Either on site or in depot repair, which would mean they will ship you a new machine with a box to return the one you have. If you call, make sure you have the serial number handy so it can verify the warranty.
Dec 01, 2008 | Xerox Phaser 6180N Laser Printer
Unable to print to the Xerox m15i with mac OSX
Xeror does not list a Mac driver for this unit. There is a Xerox Global print Driver, which supposedly "drives " all Xeror printers. But again I do not know if it will work on Mac's.There is a phone for this driver support @ 18773626567
Good luck,
Please remember to rate Techs who assist you for free :)
Oct 08, 2008 | Xerox WorkCentre M15 All-In-One Laser...
Sharp ARM207 E7-11 erorr code. What does it mean?
E7-11 Shading trouble (white correction) I beleive it is the white metal plate of the glass.
most copiers now have a white plate that it uses as reference;
take off the copy glass and clean the white plate ( with machine off) and put back.
Sep 08, 2008 | Sharp Office Equipment & Supplies
Erorr code c 62
error 62 means sorter is not closed . open and close your sort, the part on the left with the bins. it has a front cover and a relase that allows it to slide left away from the machin. open and close these and see what happens.
Jan 09, 2008 | Ricoh 3310LE Copier
Mp3 dosnt work
format as new.i mean u need to format it by use computer.
Dec 28, 2006 | MPMan MP-FUB26 MP3 Player
