Question about Frigidaire Dishwashers
I have a Frigidaire dishwasher GLD2250RDC3 I press "Normal setting" the light flashes. Then, if I press start, it also flashes.The washer DOES start up but won't actually run.Just makes steady sound.
  • 248 Answers
SOURCE: 665.17019401 - Kenmore diswasher
It indicates a water temp problem. If water temp doesn't rise at a certain rate, by the heater, it goes into this error. Probably a problem with heater or wires to it.
Posted on Nov 22, 2007
SOURCE: Washing light flashes on Frigidaire FDB1050REM dishwasher
1) Turn off the breaker to the machine.
2) Wait 30 seconds and then turn it back on.
3) All the lights will be flashing. At this point turn the dial to "rinse only" and then press "Heat dry" and "Start/Cancel" at the same time.
4) The Machine will go into maintenance mode going through all the cycles quickly.
5) After this is finished the problem should be solved.
Posted on Jan 28, 2009
  • 19396 Answers
SOURCE: GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Posted on Mar 13, 2009
  • 3 Answers
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
Posted on Apr 01, 2009
SOURCE: ''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Posted on Jun 16, 2009
Blinking lights on frigidaire dishwasher
Hello - Try resetting the dishwasher by disconnecting the power to the unit. This will clear most flashing lights. You can disconnect power by flipping the circuit house breaker off and back on for approximately two minutes. If this does not prove to be successful, contact a professional to move forward accurately. Dishwasher could possibly have a faulty control board or wiring failure.
Oct 10, 2012 | Frigidaire 24 in. PLD2850 Built-in...
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
When I press the start button the light flashes but the washer does not start
Sounds like a faulty latch. The dishwasher thinks the door is open. Should be part number 154529403, but double check it with parts store, as the model number provided is missing a couple digits.
Apr 05, 2010 | Frigidaire 24 in. GLD2250RD Built-in...
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts:
Feb 03, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Won't start
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Jan 13, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Lights flash but wont start
If the dishwasher is still under warranty, best thing will be to conntact for manufacturer service !! The problem you describe could be cause off : * A Defective switch level that doesn't "shows" that there is enough water in the dishwather and therefore will prevent program's advance. * A defective heater- If water will not reach need temperature it will prevent program's advance as well. * Defective timer - Dishwasher's heart. In case your washer is over its warranty period and you would like to solve your problem by yourself, let me know and I will instruct you step by step how to to find the defective part and how to fix it. Good luck !
Jun 09, 2006 | Frigidaire 24 in. GLD2250RD Built-in...
Dishwashers Logo
47 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
