Question about Kitchen Ranges
Replace hinges on gas oven IAG IOC9Sg2 - Kitchen Ranges
3 Suggested Answers
SOURCE: Amana ACS3350AS gas range oven door is bent and
With a hammer, carefully flatten the areas of the door on both sides where it is sprung outward. I then drove self tapping screws into the side panels of the door just above where the bulge formed.
This formed a bond between the outside panel of the door and the inside panel.
Posted on Dec 09, 2010
Daniel S
  • 4323 Answers
SOURCE: How do I replace the
Please check this video for hinges replacement:
Hope this helps...please post back for further assistance.
Posted on Sep 13, 2011
Installing lower oven door on GE profile gas oven`
Removing or Reseating Oven Door To remove most oven doors:
  1. Open door to the BROIL POSITION, where you feel hinge catch slightly.
  2. Place your hands on both sides of the door near the handle.
  3. Lift the door up and away from hinges.
  4. If the door does not readily lift off, there may be 2 phillips head screws on the inside of the door down near the hinges that are holding it on.
To replace the door:
  1. Place your hands on both sides of the door near the handle.
  2. Resting door against knee, line up door with hinges and slip into place.
For instructions specific to your model, check your Owner's Manual or Installation Instructions. Download a copy of your Owner's Manual and/or Installation Instructions
Aug 11, 2016 | GE Profile 30" Self-Cleaning Freestanding...
Door will not close completely leaving 1cm gap at top.
If the door closes fine till that 1cm gap hinges more than likely wont solve it you need to replace the supports that the hinges slot into
Dec 13, 2013 | Electrolux EOG6330 Gas Single Oven
I ordered and received a replacement door for my 2002 spacemaker ge microwave. The lady I spoke with said I would be able to install it myself. I figured there would be directions in the box explaining...
Below is the solution to replace your microwave door.
Unplug the oven from the outlet and/or shut off the gas valve. Open the old door completely and unlock the hinges by pushing the hinge out toward you and down toward the door. Slightly close the door and lift the door up and toward you.
Install the new door. Make sure the wall oven door hinges are aligned to go into the rectangular wall oven slots. Place the hinges into the slots. The hinges should "catch" on the slots comfortably.
Ensure the door is fully opened and push the hinge locks into an upright position. The two hinge locks should rest on top of the two hinges that are inserted in the wall oven slots.
Close the door and open it several times to make sure the door is properly opening and closing. Replug the oven back into the outlet and/or turn the gas valve back on.
Sep 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
After 2 years, the hinges have already warped and broken. Can they be replaced, or will I need a new oven? Is this a problem with this particular oven?
Generally speaking, it is possible to replace the door hinges on the majority of ovens be they gas or electric.
Please leave feedback.
Nov 13, 2009 | Frigidaire FGB24T3EC Gas Double Oven
My Amana gas range's oven door will not stay shut. It is not snug against the oven. Repair says I need new hinges. Are they easy to replace?
they're not too bad, you may need to take apart part of the door to remove the hinges, just remember where everything goes as you take it apart. bring the door to the first stop, then bring the hinge pin locks into place to secure the door hinge lock, then remove door, or just slide the door up. then replace the hinges as needed.
Jul 09, 2009 | Amana ACF3355AS Gas Kitchen Range
Oven Door Hinge Squeaks
its not the hinge,,its the sping in the hinge,,you have to replace it,,,be careful with ludes on stove...onthejob
Dec 20, 2008 | Magic Chef 31000 Gas Kitchen Range
Oven element in IAG stove suddenly wont heat past approx 100dg does glow a dull red .Grill element ok
Sounds like the thermostat is faulty but odd that both ovens fail to the same degree. It would probably be worth having the thermostat tested. Our IAG IOM6SE2 had the beeper volume go to a quarter volume - perhaps a similar problem. It is under warranty but IAG are not too keen to fix it. They first said, if it is a setting then we will bill you, and then, if it was caused by a power outage then it is not covered. (How can you tell?) They also suggested we claim against our home insurance. I have tried to find a service manual on the web, but no luck.  If I had a circuit diagram I could be of more help.
Sep 15, 2008 | Kitchen Ranges
Replace left hinge or order for hinge spring. if you want to use the old one, the same problem might happen in short period of time.
Jun 09, 2008 | Frigidaire FGB24S5A Gas Single Oven
Kitchen Ranges Logo
46 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
