Question about Tools & Hardware - Others
Hi I recently purchased a Chicago plunge router item #67119 it came with a 1/4 collet can I use a1/2 collet for 1/2 router bits
efs_perpends
  • 1996 Answers
SOURCE: how do you fit 6mm collet cone on new produce
You have, I presume, already locked the spindle and loosened the collet nut with the wrench, have you not?
Once the nut is loose, you should be able to remove it by spinning it off the threads by hand. Then insert the 6 mm collet cone into the collet,
carefully thread the collet nut back onto the collet, and tighten it with the bit in place.
Sometimes bits are a snug fit, especially into a new collet. If you have some fin sandpaper you can gently chamfer the very end of the bit where you first insert it into the collet, and this may help to insert it. If you have to, push a bit.
I have noticed that some companies tend to mill the shafts of their bits a little too close to the exact tolerance, or even oversize them slightly, and this can cause frustration when inserting their bits. In exceptional circumstances, I have resorted to polishing a couple of small bit shafts with very fine (600 grit or so) emory cloth, just to allow the bit to enter the collet. I would not recommend this with a new router collet, unless you have checked the bit with a micrometer and it is oversize. Odds are you just need to break things in a little.
The force need not be brutish, but you may need to use some force, yes.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Mar 29, 2009
SOURCE: How does one change from one collet size to
I just did this on my black and decker router. You need to unscrew the nut that holds the collet and remove it altogether. Then slip out the collet in there and replace it with the new size. Take care to notice how it goes in when you take the old one out. Then rescrew the nut that holds it in place and tighten. My router had three collets and only one of them works for each size, so if it doesn't tighten properly, it may be the wrong size. Good luck.
Posted on Apr 28, 2009
  • 142 Answers
SOURCE: Collet on Freud router won't release bit
a new collet won't hurt, but you may try sanding down the inside of your existing collet with 120 - 180 grit sandpaper. also, buff down the router bits
any condensation or moisture that may have gotten on these items can cause almost invisible oxidation that you can remove easily by sanding. DO NOT USE WD40!!!
Posted on Dec 05, 2009
Testimonial: "Tks! Will try sandpaper inside collet. Not sure buffing bits will help, since likelihood of ALL of them having a surface problem is pretty low."
SOURCE: Black and Decker router comes with 3 collets for
I put in a bit that fitted the existing collet. When I took this out, the collet came with it.
Posted on Dec 22, 2009
  • 3 Answers
SOURCE: How do you remove collet from porter cable router
'remove the collet' not sure on your question. but the collet is the part that holds the cutter and sits in the collet assembly. the collet is held in to the nut with a spring clip, if you remove the spring clip the collet comes out.
Posted on Feb 18, 2010
How do you put a router bit in a Makita router model 3612BR
Inserting the bit should be the same on all versions of the Makita 3612 router. It does depend on the bit size. Press the shaft lock to keep the shaft from turning. I think the lock is close to the handle on one side of the router when you hold the router with the bit/collet up. For small shaft bits, insert the appropriate collet sleeve into the collet cone. Then insert the bit completely into the sleeve. For larger shaft bits, insert the bit completely into the cone. Use the wrench to tighten the collet nut securely. Unlock the shaft lock. Do not over-tighten or leave the bit loose in the collet cone/sleeve. Over-tightening can break the collet cone. Leaving it loose can result in the bit flying out of the collet cone. Either way, injuries can occur. To remove a bit, loosen the collet nut and then remove the bit (or bit and collet sleeve).
The manual is available on the product page: https://www.makitatools.com/products/details/3612 . The direct link to the manual is https://cdn.makitatools.com/apps/cms/doc/prod/361/df12a409-2bd0-48c3-aa38-d635a480a76e_3612_IM.pdf . See page 8.
I hope this helps.
Jul 11, 2017 | Makita Drills
Router bits wont fit on my router collet nut is to small.
The two sizes (in the US) for router bit shanks (and collets) are 1/4 inch and 1/2 inch. Some routers use only a 1/4 inch collet. Routers with a 1/2 inch collet also come with a 1/4 inch collet. You need a 1/2 inch collet to hold a 1/2 inch shank. Good luck.
Jan 16, 2013 | Tools & Hardware - Others
I have an old router Sears 315.17400 with 1/4 inch bits but no collet, nut, or manual. I'd like to get this working as it is mounted on my new router table and I would like to use my new one as a plunge...
have you tried sears for the collet and nut, should be able to get it there , on on line from there., As far as manual, what questions did you have., I can help.
Mar 25, 2011 | Craftsman Tools & Hardware - Others
The sleve that holds a 1/4" bit came out and will
That's called a 'collet'. Sometimes you have to squeeze a collet to get it to go where you need to, but look both the 1/2" and 1/4" collets over carefully for a burr or flat spot that is causing them to not go together first.
If you see a spot that's keeping them from going together, work it on a fine oilstone. Any little irregularity can keep a collet chuck from gripping the tool well, so you want to be sure that there is no damage to them, also that there is no sawdust or sawdust residue in either collet. Once a collet tightens unevenly the tool will slip and you'll have trouble with it forever.
Once all is well, just get your little pair of Vise Grips and give it a gentle squeeze and it should slip right in.
If that doesn't do it, get back to me on the 'comments' tab and we'll go from there.
lp
Jan 11, 2011 | Makita & Plunge Router
How to connect 1/2 inch router bit into dewalt router
Are you asking how to put a router bit with a 1/2 inch shank into a router with a 1/4 inch collet? You need a 1/2 inch collet. Most routers with a 1/2 inch collet can also use a 1/4 inch collet. But smaller routers cannot use a 1/2 inch collet.
If this isn't clear, please ask again.
Thanks for using FixYa.
Al K
Mar 29, 2010 | Dewalt DW621 Routers
Dec 05, 2009 | Freud FT2000E 3 Router
Need router for table sears 25479 what new routers fit this table
Hi there. You will find that all of the non-plunging routers will fit. I recommend that you buy the most powerful one you can find for the money you want to spend and one that has a 1/2 inch collet, or ideally both 1/2 and 1/4 inch collets. Enjoy your new router.
Apr 12, 2009 | Craftsman Tools & Hardware - Others
Hi I have A freud 2000 and have had it for several years but I only recently removed it from the box (long Story) I was trying to put in the 1/4" collet adapter ad it would not go in at all as long as the...
I have had a similar problem with my hitachi m 12 v. I ground the end of a long flat piece of metal so that it would fit around the collet. Mine had sort of a lip on it that the home made tool would fit under. the thing I made was shaped like an  open end wrench. I had to grind it down so it would be thin enough to fit under the lip and just fit around the collet. Then I hit it with a small hammer. a few times on each side of the collet. I kept going from one side to the other until the collet popped out.
Jan 30, 2009 | Freud FT2000E 3 Router
How to adjust the collet easily?
Look for a button that will lock the collet in place. This will allow you to adjust the collet with a single wrench, without having to wrestle with several wrenches.
Aug 27, 2008 | Porter Cable 75300 Height Adjustment Knob...
Tools & Hardware - Others Logo
35 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
