My tv was working perfect i turned it off and went to the store for 10 mins then when i came back it wouldn't turn on, the green light come on but no picture no sound.
    Master:
  • 708 Answers
    New Friend:
    Problem Solver:
  • 5 Answers
What model TV? How old is it?
Posted on Dec 07, 2016
Testimonial: "sanyo, and i can't remember and find find the book. sorry if thats no help"
Broksonic Flat Panel TV, tried to turn back on TV and Green LED light is blinking and screen pops up a few sec with white and colored lines and the turns off
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 21, 2014 | Broksonic Televison & Video
I stored my TV for 2 years and when I went to turn it on the green power light came on for 10 seconds then turned back off. That's all the TV does now. The screen is blank and the TV does not come on.
Try this:
1- Unplug power for 10 minutes.
2- Plug in and turn on again.
if it doesn't turn on then The power supply is bad. Usually the power supply unit can be replaced, but you have to open the case to see how it looks like before order the same one.
Jul 03, 2009 | Mitsubishi HD1000U DLP Projector
Magnavox lcd tv not turning on
Also changed swollen C2074 and C2081 and it now works perfectly! a bit daunting for a novice like myself but with a steady hand and decent 'put it back the way you took it apart' skills, all went well!
Mar 22, 2009 | Toymax Magnavox 37MF231D 37 in. LCD TV
Mitsubishi WD-62827---PICTURE TURNS GREEN
I had the same problem. I deducted that if my TV worked fine for an hour or so and then the colors became bad (green, people's faces purple...), it must be a overheating problem. Simple logic, right? So, I picked up a few tools and a small vaccum and went to work.
I went first for the main source of heat: The lamp. Just a few screws, and I removed it. The lamp cage has a fine screen to prevent the dust to cover the lamp. Mine was covered with dust! And the fan behind the lamp was also covered with dust! Bingo!!! That's my problem! I cleaned everything and vaccumed all the air vents on the the back of the TV. I put the lamp back and checked that the fan was working. The TV works like new since!
Before you are out of a TV for days and spend an arm and a leg for a "Technician" to fix it (replacing expensive parts that didn't need to be replaced in the first place), try what I described above first. It's very simple and it takes only 15 minutes.
Since my TV is 2 1/2 years old, I purchased a replacement lamp. I know that one of these days it will burn out. I'll be ready and my TV will be working again in 15 minutes!
Since my problem was solved, I didn't go to the next step. There must be one or two other cooling fans inside the TV, but they must be working...
Good luck,
alecoz@roadrunner.com
Oct 06, 2008 | Mitsubishi WD-62827 62" Television
NO WORK
you have 3 bad capacitors they are green and gold 2200uf and two 220uf 35v.If this is not what is wrong replace deflection board.
Sep 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
KP51ws500 turns green and shuts itslelf off
There may be several causes but, one is that when any color gun is being over driven, the Sony shuts down the gun to protect it. Try this. Remove the front of the set by removing the two screws from each lower corner. Next remove the black panel held on by 5 or 6 screws. Now you should see a panel with 6 potentiometers on it. Turning the ones on the bottom row CCW reduces the drive. Turn the color down and if all the guns stay lit, SLOWLY turn them up until you get the color balance that you like.
May 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Televison & Video Logo
Top Televison & Video Experts
