Question about PRINTER Office Equipment & Supplies
Shortly after power on, the printer powers down automatically after the wifi signal light turns green. The printer will power cycle like this until it's unplugged.
  • 2 more comments
  • kakima Dec 07, 2016
    Hi Matt Perakes, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
  • Matt Perakes
    Matt Perakes Dec 07, 2016
    Epson WF-7510
  • Sherrick Murdoff
    Sherrick Murdoff Dec 07, 2016
    I have this exact problem with my WF-4630. It just cycles on and off - I cannot connect from my Mac to do any firmware upgrade. How can I physically restore to factory settings so I can start over?
  • Sherrick Murdoff
    Not sure if the Add Your Answer worked, so I will copy it here:
    Spoke with Epson Tech Support and here is their solution that worked for me:
    ?Unplug your printer
    ?Turn off your wifi router
    ?Turn on your printer
    ?Turn off google cloud print services (under Setup - System Administration - Google Cloud Print Services)
    ?Turn off the printer
    Turn on your router, wait until its back online (test using a browser)
    ?Turn ?on your printer
    ?This should solve it.
    ?She also said to "Leave off Google Cloud Print Services" for now as they have had multiple calls, cases and issues with it lately. No ETA on when they might get it fixed.
    New Friend:
Unplug your printer
Posted on Dec 07, 2016
My canon ir 5180 blinks only d green light but d screen does not open
Start with the printer OFF:
1. Hold down RESUME and then hold down POWER
2. release RESUME
3. press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
0 - green - Pressing power button will turn off printer
1 - orange - Service Test Print
2 - green - EEPROM Information Print
3 - orange - Initialize EEprom data
4 - green - Reset Waste ink Counter
5 - orange - Mode to set Destination code
(1: Overseas, 2: Domestic)
6 - green - Refresh printhead (cleaning mode)
I assume the printhead is cleaning and you need to wait for it to finish cleaning. That could take over a minute and a half; I don't know what that delay is for your printer.
If that is not the issue, you may have to reset the printer. This may be possible as follows:
  1. Hold down HELP + OK button and unplug printer (could experiment with regular power-off, but I opted for brute force)
  2. Hold down HELP + OK button again as you plug the printer back in. Then power it on, if it doesn't power on automatically. Be Safe: keep holding the buttons until the printer turns itself off. (It took mine less than a minute.)
  3. Release the buttons and simply power it back on. (If you unplug it without powering it down, you may get an improper shutdown error message. If so, click OK on the printer.)
If you are looking at a blank computer screen after all of this, you might try uninstalling and reinstalling the driver.
If this does not fix the problem, you better look into troubleshooting on the manufacturer's site for help for your particular printer.
Jan 21, 2015 | Canon Office Equipment & Supplies
My wi fi orange light is blinking on my lexmark x4650 printer
The blinking WiFi light on your printer indicates either your printer is trying to communicate with your wireless network or your printer is not connected at all. For a quick fix, try to disconnect your printer from the power outlet. Power cycle your router and reboot your computer. Then, power on your router first, then your printer and lastly your computer. Check the WiFi light on your printer. If it goes to a solid green, that means you are connected back in your network. If not, you may reset your printer's wireless network adapter to its default settings. From the printer operator panel, press the Setup button > Network Setup > Reset Network Adapter to Default. The WiFi light on your printer will momentarily turn off then back on solid orange. Then try to run the Lexmark Wireless Setup Utility on your computer to reconfigure your printer to connect to your wireless network.
I hope this helps.
Nov 20, 2011 | Lexmark X4650 All-In-One InkJet Printer
How to stop wi fi from flashing orange on my x4650 lexmark printer
I hope this helps.
Nov 20, 2011 | Lexmark X4650 InkJet Printer
Looking for a solution to an error 6502 on canon printer mp510
turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be releasedbefore doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Jul 25, 2011 | Canon Office Equipment & Supplies
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
How do you turn off the "power saver" so the WiFi
If you are in power saver mode, the WiFi is still available. Power saver mode is indicated by the green power light dimming and becoming bright. If there is no green power light, the printer is off and the WiFi will not work. The printer will switch to power saver mode in 10 minutes if you are in Eco-Mode. The printer use 7 watts of electrical power in ready mode and 3 watts in power saver mode.
Nov 07, 2010 | Lexmark Pro901 All-In-One Inkjet Printer
"no signal" showing on tv screen
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 29, 2010 | Sony Playstation 3 (PS3) Console
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Set dosen't power on/off.
Replace the small signal board 310432842611.
Oct 02, 2008 | Philips 42PF9630A 42 in. Plasma Television
42 people viewed this question
Top PRINTER Office Equipment & Supplies Experts
Gene
Hardeepak Bhambh
Hardeepak Bhambh
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
