Question about The Video Cameras
I am trying to install a corsair H100i V2 on my asus rampage extreme iii mother board. my case already takes up the usb connection on the board. I was wondering it there was a second one I could use>
I cannot see one and the only ones that I can see that would fit the connection for the usb part of it are the OC station one and the IEEE 1394 port.
  • The Master
  • 5,412 Answers
You can get PCIe card to extend the number of USB ports available, if you have spare slots.
Posted on Dec 07, 2016
I installed a new G31M3 L V2 MOBO because my old one (same model) died. Also gone with it was the intel cpu (I guess because of the heat problem). With the new mother board I upgraded my CUP to an Intel...
Make sure that the Power connector are properly connected, also check if the CPU is properly seated to get POST from the Board, since the CPU is new as well as the board you can clear NVRAM on the board take the CMOS Battery out for a couple of seconds then put it back in the CMOS slot then try to turn the unit back on, also check all the rams if properly seated.
Nov 23, 2011 | MSI G31M3-L V2 Motherboard
I have bought parts for a new PC. When starting it up for the first time I just got a 'No Signal' message on the monitor screen. The motherboard is the Rampage III Extreme. The red led is lit on the...
When you turn the computer on, it should "beep" once, if all the hardware (RAM, CPU, video) is working correctly. If it beeps more than once, something is wrong. If there are no beeps, check that the PC Speaker is correctly attached to its pins on the motherboard.
Try the RAM and the video in another motherboard, to confirm that they are working correctly.
Try a different power-supply -- it should output several different voltage-levels, but if it's not 100%, then the motherboard won't function at all.
Oct 23, 2010 | ASUS Rampage Extreme Motherboard
I can't find how to connect my dvd writer to the Asus Rampage II Extreme motherboard. The missed pin in the connection cable is in a different location
If you are trying to connect your DVD Writer using an IDE cable, then:
1. First, make sure that you are connecting the IDE cale in the correct direction. Make sure that the Red (or colored) wire in the cable aligns with pin 1 in the connector.
2. If the cable & connector are aligned correctly, then try to find a replacement IDE cable without a missed pin or with the missed pin in the correct position. This can cause no harm to neither the DVD Writer nor the motherboard.
Jul 11, 2009 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Jumper setting
you can keep master either hard disk or rom not both. there must be one slave and one master for one ide slot
Jun 12, 2009 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
My computer restarts when the board is in case. When out of the case everything works fine. Mainboard is the ASUS Rampage Extreme, Graphic card us MSI 3870x2, sound card Soundblaster X-Fi and the case is...
Hi friend i think this is an issue related to software and this will be solved. This may happens when the computer is running on full load i.e ram capacity is low when compared to your computer OR your pc might have some errors use Registry booster program to solve this.
May 03, 2009 | ASUS Computers & Internet
Unable to boot up
The problem is of the display side so if possible connect the pci
display card or can repaire the mother board, If not then only solution is to change the mother board.
Thanks
Sep 08, 2008 | ASUS P5B-E Motherboard
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
Video Cameras Logo
Top The Video Cameras Experts
D. E. Hev
Are you a The Video Camera Expert? Answer questions, earn points and help others
