Question about Inverter Electronics - Others
So back to my previous problem my inverter is a eliminator 3000 watt both fans are on along with the high pitch squeal if it's the over load what should I do to fix it
  • 46 Answers
SOURCE: Inverter not working
unless you are into electronics it is cheaper to replace it! take it to a repair shop for an estimate
Posted on May 28, 2009
nitrospawn
  • 290 Answers
SOURCE: Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
Posted on Feb 27, 2010
motor1258
  • 6674 Answers
SOURCE: I have a 1000 Watt Inverter, along with a regular
Yes, just be sure connections are heavy enough wire, and obviously the inverter uses 12 vdc input. Hook jumper wires positive to positive, negative to negative, on all 12 volt batteries. Deep cycle batteries will work better than car batteries. Just remember, when re-charging them, that they last longer when charged slowly, so don't use a high amp setting on charger and to monitor them closely, and do it in a well ventilated area, away from any ignition sources.
Posted on Apr 15, 2010
  • 4 Answers
SOURCE: I have a vector VEC051C 3000 Watt inverter, the
If it has a 12 volt fan, you can replace it with one designed for computers that has a built-in thermistor. These fans will automatically increase or decrease their RPM depending on the ambient temperature. I have seen them in 70,80,120mm sizes. As long as the inverter is on, you do not want the fan to ever be completely off because even without load some heat is generated and can build up inside if no ventilation is present. Although the fan will never completely turn off, this might be the easiest solution if your goal is to make the inverter quieter (and use less energy) when not in use.
Posted on Oct 21, 2010
  • 185 Answers
SOURCE: i bought two veco51d 3000 watt inverters made by
Hello, I hear you. Was the reason to supply 240 volts? When you try the inverters separately, do you get 120Volts output? Let us look at the units working individually first and go from there.
Posted on Feb 06, 2011
3000 watt eliminator with OLP and LUP CODES any Ideas
Assuming you have a 12VDC In 120V AC out 3000W inverter.
LUP indicates battery voltage is low, so firstly make sure:
1. You 12V battery is good, it's large enough a minimum of 75AH and probably much larger is recommended and it's fully charged.
2. Verify you are using the correct size copper wires from battery to the Inverter DC INPUT(s). If you keep wire short the wire size can be smaller, but if the DC input wires are longer then you will need to use thicker copper wires.
At MAx load you would be taking 250 AMP from battery, so for a 5% Volatge drop of .6 V for a 10 ft length of cables from battery to Inverter you would need to use a 1AWG copper cable.
http://www.calculator.net/voltage-drop-calculator.html?material=copper&wiresize=0.4066&voltage=12&phase=dc&noofconductor=1&distance=10&distanceunit=feet&eres=125&x=37&y=8
OLP is a overload condition, which means you may have to many high powered AC powered things connected to the Inverters AC outlets or maybe something that has large start up surge, ie devices large electric motors.
Or it could be all due to a faulty Inverter.
Oct 22, 2016 | Eliminator Electronics - Others
Blower fan makes a high pitch squeal.Replaced fan but squeal is still there.
'high pitched squeal' sounds like the serpentine belt on the water pump, not the heater fan.
Dec 17, 2015 | 2011 Hyundai Tucson
What does ocp mean on the 3000 motomaster power inverter
Unit is overheating.
1. Check fans are running. and unit is in a cool place where air can flow freely.
2. If fans not working try using an external fan to see if the OCP error goes way.
Reduce the load on the outlets (Disconnect some stuff i possible)
Apr 04, 2014 | Eliminator MotoMaster Mobile Power...
High pitch squealing when i turn on fan
bearing gone or rotor blade scraping against outer cover
Dec 12, 2013 | Lasko 3520 20-Inch Cyclone Fan
I bought two veco51d 3000 watt inverters made by vector and conectted with two positive and two negative cables to a good battery 12.6 volts load test at 750 cranking amps and both inverters light up and...
Feb 06, 2011 | Vector 3000 Watt Continuous 6000 Peak Dc...
I have a vector VEC051C 3000 Watt inverter, the vent fans run continously without load, can it be modified to cool only when, the temperature increases..
Oct 20, 2010 | Vector 3000 Watt Power Inverter
When I switch the power on the inverter, it squeals briefly and then shuts down.
Two possible problems; input voltage too low, or the output load too high. If input remains at 12v or higher and it shuts off with no load, then the inverter is bad.
Mar 19, 2010 | Vector 750-watt Power Inverter Power...
High pitch noise
For laptop repairs & parts, pls try here. Not really that hard a fix but major concern is how soon do you get the parts and how to confirm your diagnosis.
You may want to consider other possibilities such as:
1. mechanical problem (fan motor bearing, CD/DVD spindle, HD platter; and/or
2. CCFLamp inverter.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 14, 2007 | Compaq Evo N610C Notebook
Electronics - Others Logo
114 people viewed this question
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
