Question about Electrical Supplies
Does anyone know where I can find a replacement switch and light socket for a Ledu L445WT Professional fluorescent/incandescent swing arm clamp-on lamp?
SOURCE: Dark Screen
almost all LCD use a flourescent lamp, some very new and expensive types use OLED.
Posted on May 27, 2008
SOURCE: light bulb socket uses intermediate base bulbs, not standard bulbs
I found the solution on the web. The only place it looks like that has this adapter is voss lighting. Here is a link to the adapter.
Posted on Nov 11, 2008
  • 23 Answers
SOURCE: 2wire 3800HGB-B interference
I would increase the wireless power inside the modem. This will boost the signal allowing it to stay connected more often.
- open IE
- browse to
- homenetwork icon
- wireless settings
- enter your system password
- If your on channel 1 or 11 the power will only be able to go to 4.
- Change to a wireless channel between 2 and 10
- Increase the power to 10
- Save
Posted on Mar 24, 2009
  • 32281 Answers
SOURCE: Accidently broke Fluorescent Lamp in scanner whilst cleaning
LCD Parts supply CCFL lamps for LCD screens, maybe they have one that suits the HP. Check them out Use this link to their WEB site :-
Posted on Sep 04, 2009
Testimonial: "Thanks Geekman. I looked at this site you mentioned and only one fits the bill but is thinner. It needs to match specs. I will email them. Thanks"
  • 107 Answers
SOURCE: We have an existing wall mounted occupancy sensor
This is not a surprise. Many wall-mounted devices such as occupancy sensors and dimmers operate by leaking a little bit of power through the light fixtures. In the world of incandescent, this was rarely a problem - that little bit of current wasn't enough to excite the bulb. But now that we're living in a world of low-wattage lamp types, that little bit of current is now enough power to excite the lamp and cause what you're seeing. The added detriment is that little bit of pulsing that you see in the CFL can actually wear it out pretty quickly.
The short-term solution is to use the older-style, incandescent lamps.
Another short-term solution would be to attempt using another manufacturer's CFL or try an LED lamp - that's by no stretch a guarantee, you'd be rolling the dice with each lamp choice you made. The higher wattage the lamps, the less likely you'll see an issue.
There are two long-term solutions:
1) Add another lamp - the more lamps the control sees, the less leakage current that goes through each lamp. Several people have solved this by adding a 'dummy' incandescent load (like a 15W or 25W lamp) somewhere in the lighting circuit to take the brunt of the leakage.
2) Change the wall-sensor. Lutron makes one (MS-OPS6M-DV-WH) that has extremely low leakage current and may solve the problem. But the best way to guarantee it won't be an issue is to use a wall-sensor that connects to the neutral wire in the wallbox. Those devices take that leakage current and dump it out the neural wire rather than run in through the light fixture. Lutron makes one of those as well (MS-OPS5AM-WH)
Posted on Oct 20, 2010
I have a 2002 Buick Rendezvous and the radio and heater control backlights have shut off simultaneously and now only the vent control and trunk release lights work.
I would take a look see at the ground circuits for the none working lights . The incandescent back lighting lamps are then grounded at G200, G301 and G302. You would need factory service info for the location of the grounds .Like this from buick
Right side of the I/P, secured on the underside of the cross car beam, behind the I/P compartment . The I/P compartment is the glove box ,don't know why they just don't say that . You could also check out the power and ground from the componet that's not working ! You can find factory like service info. from alldata . Check out some videos on youtube
Interior Lamps Dimming
The second group includes lamps which may be dimmed. This group may use a combination of vacuum fluorescent (VF) illumination and of incandescent lamps.
• The door switches and the window switches
• The HVAC control head assembly
• The radio
• The instrument panel cluster (IPC)
• The steering wheel controls
• The heated seat switch
• The HUD switch
• The lift glass window release switch and traction control switch
When the ignition switch is turned to the ON position, the vacuum fluorescent (VF) displays (radio and HVAC control assembly), incandescent lamps, turn on at maximum brightness. When the park lamps are on and the ambient light sensor indicates low light conditions, all incandescent back lighting turn on at the dimming level indicated by the IP dimmer switch. At the same time all vacuum fluorescent (VF) displays dim to match the indicated dimming level. The BCM L fuse in the console fuse block, supplies battery positive voltage to the BCM. The I/P courtesy lamps supply voltage circuit of the BCM, supplies battery positive voltage to all the dimmable lamps. When the headlamp switch is placed in the PARK position, the BCM will then dim the interior lamps to the dimming level indicated by the IP dimmer switch. When the driver selects a dimming setting by moving, the IP dimming switch potentiometer, all incandescent back lighting lamps are provided with a specific voltage. The incandescent back lighting lamps are then grounded at G200, G301 and G302. When the IP dimmer switch is moved from MIN to MAX, all vacuum fluorescent (VF) displays, as well as all incandescent back lighting respond from Minimum intensity to maximum brightness in response to the IP dimmer switch.
The driver may select parade mode by manually turning on the park lamps during daylight conditions. The front park lamp circuit supplies voltage to the instrument panel cluster, radio and HVAC assembly for a park lamp on input, and the displays will become full bright.
Dec 03, 2016 | 2002 Buick Rendezvous
Can't get the night light to go on. Changed the bulb. What is my next step? GE Profile gas oven. Model 317B6034
If its a mini fluorescent bulb replace the started, its probably bad. If incandescent bulb make sure you have 110Vac at the bulb socket and the new bulb is actually good! Don't overlook the obvious, you may have a bad switch or blown fuse.
Aug 19, 2014 | Kitchen Ranges
Lutron s-600 don't seem to function
That switch says on it that it is for fluorescent lights only. I don't know if you can use compact fluorescent bulbs on that system, perhaps verify if you can or not. The switch has electronics in it and may need that ground wire to get 120 volts to operate. If you have incondescent light bulbs return and get the correct dimmer.
Mar 16, 2013 | Lutron S-600-wh Skylark Incandescent...
A 40 W fluorescent lamp gives out more light than a 4o W filament bulb.explain whether the fluorescent lamp is actually using electrical energy at the same rate as the filament bulb??
The lamps are both using 40 watts of energy, but the fluorescent lamp gives more lumens (visible light measurement) than the incandescent.
Fluorescent gives at least 5000 lumens for 100 watts.
Incandescent gives 1750 lumens for 100 watts.
You can see that if you had a 100 watt incandescent, it would be 1750 and you would only need 35 watts of flourescent.
Feb 19, 2011 | Vacuums
Have 3- 13 watt mini spiral bulbs on fixture. When switch in auto mode, lights hum, flicker and not maximum brightness. When switched to on position, lights stop flickering and humming. Full brightness as...
-Replace the compact florescent bulbs with regular incandescent bulbs and see if problem continues.
-Lighting controls are made for different kinds of bulbs.
-Your package should say what the watt rating and type of bulb.
According to the PR180 manual:
-I am looking at the Leviton PR180 occupancy sensor manual, and the PR180 sell-sheet, and these documents say for incandescent and fluorescent (rapid-start magnetic ballast only).
-Compact fluorescent are supposed to have a magnetic ballast.
-The manual does not specifically say it works with 'compact fluorescent'
-The manual does not say there is a minimum amount of wattage either. Some controls will not work correctly if the overall wattage is low. Your overall wattage is 39watts.
Read the product package (if this is a new installation and you have the package)
Try the incandescent bulbs.
If the PR180 is not your product, add a comment with product number and I'll look for information
Nov 06, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
The dimmer switch will turn on and off but wont dim the lights on a chandelier. model 6681-w. tried 2 different ones with the same results.
The Leviton 6681 is a push-button rotary-type incandescent dimmer with 600Watt capacity
If you have incandescent bulbs, the dimmer should work.
If the dimmer has different color wires, try reversing the wires.
If the dimmer replaced a 3-way switch, then this is not the right dimmer.
If you have compact florescent bulbs, you need a dimmer that also dims florescent.
Link shows the Leviton 6673 incandescent and florescent dimmer
But you also need dimmable compact florescent bulbs.
Oct 31, 2010 | Leviton #L11-06681-00I Ivory 600 Watt Push...
Hampton Bay 54" Covington Ceiling Fan light problem
Solids state fan controls don't work correctly with fluorescent bulbs. If you check the tail end of you remote's instructions it will say something like "Max light watts: 300 (incandescent only). So replace your energy saver bulbs with 60 watt "regular" bulbs to solve your problem.
Aug 22, 2008 | Heating & Cooling
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
