Onkyon control remote model tx SR705 - Audio Players & Recorders
  • 14 Answers
SOURCE: Onkyo TX-SR705 Muting Problem
if what Dark_Orbit said does not work try doing a master reset by ressing and holding the dvr/vcr button and stand by button simultaneously. This would erase all your assignments so you would need to reassign all your sources hooked up to your onkyo.
Posted on Mar 05, 2009
  • 3 Answers
SOURCE: TX SR705 Receiver not respomding to Remote
My wife inadvertently placed an item on top of one of the remotes in our "remote graveyard" (we use a Harmony 880). This resulted in the unused remote continuously sending a disruptive signal that was interfering with the receiver. This explains why getting close to the receiver fixed the problem (because the disruptive signal was blocked by my body).
Posted on May 05, 2009
VOTIT
  • 2071 Answers
SOURCE: TX-SR705 Hum problem
This a problem of input grounding,the cable input is already loose or crack solder that why you hear a hum or distorted sound because not properly grounded it is a loose contact already thats why also is need to warm up and it will come.First change the cables with a new one with identical size and value then if problem still exist open the back cover ,when open look for the cable input connection parts joints reworks or resolder all soldered joints there .Then checks if it works then cover the unit.If you have no knowledge of electronics dont attempt to open to avoid electric shock.Find a electronics repairman or bring this to a authorized electronics repair shop maybe it cost you only $50.
Good luck;
Dont forget to rate...
Regards:
VOTIT
Posted on Jun 29, 2009
smarthome2
  • 1114 Answers
SOURCE: TX-SR705 60 hz. Hum
If you have a Home Theater Line conditioner on this receiver, not a power surge protector, even a "Monster" surge suppressor, your problem Is AC related. For troubleshooting; first if your AC power cord is three pronged, go to Lowes, Home Depot, etc. and get a three prong to two prong adapter. Your problem is a "Ground" issue, however it may not be from the receiver, it could be "Anything else" in your home. Even an actual outlet with a loose wire. It can be very very time consuming to "hunt down". An adapter will take the rest of the house out of the picture. Disconnect all other input sources like Cable, DVD, etc. then turn the unit back on. If you still have a humm, yes the problem is internal and needs serviced. If it stops, re-connect one item at a time until the noise re-appears and you have your culpret. If you don't have a line conditioning noise eliminating Theater surge protection unit; Get one! best few hundred bucks you could ever spend. It will protect all your electronics and could save you thousands! Panamax, Furman, Monster, are your top 3. If you still have issues, post a comment and I can help you further. Hope this helps.
Posted on Aug 23, 2009
pabloloco
  • 2335 Answers
SOURCE: I own an Onkyo av receiver and I want the remote
Samsung Blu-Ray player code for Onkyo universal remotes is 33001.
You can download Onkyo universal remote codes with instructions here.
I hope that helps.
Posted on Apr 20, 2010
I have onkyo TX-SR705 AVR and an older DX-C120 CD player and want the connect the CD player remote to the AVR to use both with a universal remote (harmony one). the remote turns on both the AVR and CD,...
Your don't explain which Logitech Harmony you own. I have seen on some harmonys that the auto programming for a specific device isn't sufficient to give useful enough functionality, the desired functions must be added manually. I'm assuming the device in question is listed for your remote. If it's not you are dead in the water. Your only option is to go back online with harmony, verify the device can be added and learn how to add functions manually. That's all I can help with the limited information you have supplied. Regards.
Dec 10, 2017 | Onkyo TX-SR705 Receiver
Need Onkyo tx-nr616 remote code so ATT U-verse remote can control Onkyo
I used 5002 and it works for on/off only. This is better than nothing. You can try codes from other Onyko devices to see if you can get one that provides more functional control.
Dec 31, 2012 | Onkyo TX-SR705 Receiver
Need remote control codes for Onkyo TX-NR690
The only way to get them is from the manual, Or from a allien,
Nov 29, 2012 | Onkyo TX-SR705 Receiver
Where is remote sensor located on the front of the TX-SR705
Usually on the right side. get a flash light it will help.
Apr 08, 2011 | Onkyo TX-SR705 Receiver
Need remote control for onkyo 904 reciever
Go here http://www.replacementremotes.com/store/prodthumbs.cfm?categoryid=67&keyword=940&x=36&y=3 and you should find what you are looking for. If you need anymore help let me know.
hardrocko
Thanks for using FixYa
Feb 19, 2010 | Onkyo TX-SR705 Receiver
Standby light is on and i can't turn my reciever on or off.
Try to use the control panel switch to turn on. Or maybe your remote battery need a new one.
Jul 26, 2009 | Onkyo TX-SR705 Receiver
My sansung remote control 2 dvd at the same time...how to have only one remote for each
When attempting to increase the volumn on the television either using the remote of turning the reciever knob by hand the volumn increases dramatically. I am concerned the speakers might blow. Does anyone know how what the problem might be.
Jul 05, 2009 | Onkyo TX-SR705 Receiver
Dish Code for TX-SR806
Dish Network
System
00775, 01505,
01775
Jan 27, 2009 | Onkyo TX-SR705 Receiver
for your mute button:
check your setup:
*press setup
*go to Miscellaneous
*go to volume setup
*go to muting level
*make sure that the muting level is on minimum (press the left arrow or the left preset button)
*if it shows a negative infinite sign (its measured in decibels) its ok.
you can now mute it without the loud noise.
Abaout Remote:
Please make sure that the remote ID is set to 1. this would be on the setup menu of the receiver. The remote ID on the receiver should be the same as your remote. Please refer to page 94 and 98 of your owners manual. it would give you the exact procedure in how to set it.
Jan 11, 2009 | Onkyo TX-SR705 Receiver
 Grubhead
Grubhead
