Rheem classic 90, M RGTA-07EMAES, S EJ50702F460002714 won't ignite right, get clicks and after playing with it i can get a flame but it won't heat to set temp. Do you have any Suggestions Thank you
meBNme
  • 334 Answers
SOURCE: Where is the re-ignite switch on a RUUD achiever 90 plus furnace?
Te flame symbol on the T-stat is just telling you that the T-stat is calling for heat.
What you need to do is go to the furnace and see if there is a blinking light. If there is count the blinks and look for a blink code list on the wiring diagram.(Usually found on the main panel.)
After you have done that, disconnect power to the unit, and then reconnect after a few minutes. This will reset any auto switches if they are tripped.
Chances are the problem will occur again even if the furnace does fire back up, but it "may" get you through the night until you can either diagnose the problem or get a service tech in.
Ideally, have someone else turn the power back on, and the thermostat, while you are watching the furnace to see exactly what is happening.
If it does not operate properly at that time, let me know exactly what it is/is not doing and we can go from there.
Posted on Dec 29, 2008
  • 1015 Answers
SOURCE: gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Posted on Dec 21, 2009
Testimonial: "I did not expect such a quick response. These are hard times for us and we really appreciate your help. Thankyou for sharing your expertise."
  • 20 Answers
SOURCE: my Rheem Corsaire furnace is
Try blowing air thru the pilot tube. You may have a spider web in the burner tube.
Posted on Oct 15, 2010
  • 102 Answers
SOURCE: What would cause a furnace
You could have plugged orfices in the line coming out of the gas valve. Next you could have a plugged gas regulator.The only way your going to find this out is to check gas pressure before the gas valve during a call for heat and then check it after the gas valve during a call for heat you could have a bad gas valve. Try this let me know what you find Thanks and please leave feedback
Posted on Dec 16, 2010
gargac
  • 39 Answers
SOURCE: Heater: Rheem Classic 90 Model
Failed control board. Replace circuit board.
Posted on Jan 27, 2011
I have a rheem classic quiet 80 . furnace starts up but the igniter will not kick in to start the flame
This problem can be one of two things:
1) Bad igniter.
2) Control board not sending 120 volts to igniter.
You will need a multimeter to verify if the igniter is receiving 120 volts.
Sep 07, 2015 | Heating & Cooling
What is the AFUE of my Rudd Achiever 90 Plus with model number UGRA-07EMAES
Per Rudd's website and also as the name implies, the min rating is 90. The 90+ can be as high as 93 but is stated as "plus" to cover the many possible installation scenarios which will impact overall efficiency of the unit.
Sep 11, 2014 | Heating & Cooling
Rheem Rudd G91-200 will not start. After waiting 10 minutes, it does fire up for about 2 minutes, then it locks out. Bad gas valve?
ive never seen one of these water heaters but most gas apps have a thermo-couple which the ignition flame needs to heat the top of.if the ignition flame is missing the top of this the main gas valve will shut off.it may just be a bit of dirt in the flame director.which aims gas at the couple and main gas burner.hope ive helped.good luck
Mar 16, 2013 | Rheem Tank Water Heater G91-200, 91 Gallon
The blower fan comes on several minutes before the
Bad fan switch. It may also be called a fan limit switch. If your furnace is less than 5 years old, the switch is part of the circuit board and you will need to replace the board.
Jan 11, 2010 | Heating & Cooling
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Dec 21, 2009 | Heating & Cooling
My rheem quiet 80 ignition flame keep going out. it'll turn on and then go out.
I have a Rheem Classic 80 furnace that would ignite but not stay lit. Cleaned the ignition sensor which was easy to get to and the flame sensor which was under the burner plate and it fired up and stayed lit. The flame sensor was about 6" under the burner plate. Easy to get out, but tough to get back in. Used the old piece of paper shim trick to get the screw to "stick" in the socket and it was much easier to position the screw and get it back where it belonged.
Jan 16, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
